No spin zone
When my washimg machine load is done the clothes are still wet. When the spin cycle is on it is not spinniing well and the drum goeas back and forth. Is this something i can fix myself or is it time for a new washer. It is about 6 years old. It is a whirlpool. when it spins with nothing in it the drum does not go back and forth.
  • mannunziato Jan 18, 2008
    where is the filter?
    is the drum suppose to move back and forth ?
    President:
  • 1,294 Answers
Try this: Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 18, 2008
  • prem mathew Jan 19, 2008
    Of course the drum goes back & forth, this is how your clothes are washed. It turns clockwise for sometime then anti-clockwise for sometime. When it spins fast it goes only in one direction.
6ya staff
SOURCE:
During the spin cycle it spins correctly until the last 2-3 minutes and then it just fluffs clothes
Some machines used a variable speed slow down process to avoid clothing damage, this removes the items from the outside of the drum where if the clothing was left for a length of time after the cycle has finished it could damage the fibres, this way the clothing is also easier to remove from the machine and promotes airflow over the items
Jun 14, 2016 | Sears Kenmore Elite 3.9 cu. ft. Front-Load...
I have a WSXH208 ge front loader It started to fill was and then in the middle the water pumped out but did not finish and clothes were sopping wet, Drum stopped spinning. what could be wrong
all front loaders will not go into high spped spin if there is water in the tub.You should first remove the bottom panel and check the water pump for blockage.Some units have a sscrew style filter to catch debris befor it enters the pump impellor.when you unscrew the filter make sure you have a wet vac handy.
Apr 02, 2013 | Washing Machines
Clothes still wet after washed
There could still be water in between the drums. Have a look at the filter, pump and all outlet pipes for a blockage. the excees water that you have when you have clothes in will be what's left in the clothes, wih the machine empty you may just be seeing what shows above the inner drum.
Dec 27, 2012 | Kenmore 22422 Top Load Washer
The clothes are still very wet when the cycle is done, and there is a little water sitting in the bottom of the machine. Is something wrong with the spin cycle?
does the drum turn on high spin if it does is there a low and high for the spin also check the filter which should be located at the fort bottom of the machine it might be blocked
Oct 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Ca230 w. machine not spinning leaving clothe wet, no water in drm
It is possible that the belt at the back of the machine is slipping. try running the spin cycle without any load in the machine. I assume this is a front loading machine and you are in UK. the Belt is available on line for about 15 pounds.
If it is running the washing cycles normally, it can't be the motor.
Dec 06, 2017 | GE S8000E
Dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Jan 27, 2009 | Haier Washing Machines
Load remains wet after full cycle (including spin @ 1400 rpm)
Hi Paul, Assuming it is pumping out ok, Unplug the machine tip it back at an angle, underneath you will see a black hose that is attached to the bottom of the drum, remove this, take out the ball and discard it and remove anything that may be in the filter, replace the hose and try the machine.
Nov 30, 2007 | Hotpoint WMA64 Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
