Question about Eclipse (EA4000) Car Audio Amplifier
Amp installation 500watt amp installation how do u do it?
I was given a EA4000 to use, but there was no instructions in the box. now I need to know how to install it in my truck
Posted on Nov 10, 2008
    Genius:
  • 1,665 Answers
Warwick xtreme bass amp no sound
get a new amp or try buying a new guitar i do not no ask the people
at gutair store sorry if i can not help
Mar 24, 2014 | Warwick Music Equipment Warwick XTreme 51...
Where can I get my Fender passport PA system services in Brooklyn, NY
Here ya go:
  • Jeff Bloch's Amp & Guitar Center 1700 10th Ave Brooklyn, NY 11215 Ph: (718) 369-7080
Authorized Fender electronics Service Center
Sep 17, 2011 | Fender Passport Deluxe 500watt Sound...
Do i need a amp to connect equalizer to car stereo
hello yes but you will get the same audio output as you would without using an amp iff you are using high watt speakers it would be best to give them a bit of power you may connect the amp in line with the equalizer hence giving them the boost make sure you set the sound levels correctly on your stereo first like ballance both speakers then you can ajust the equalizer with your amp remember 2 /500watt speakers in line will accur a 500 to 1000 watt amp nothing more or you will blow your sound system
goodluck
Mar 29, 2011 | GPS
What fuses can i use fo a hifonics 500w 2 channel son of boltar
First off, it is not a 500watt 2 ch amp. Specs are as follows:
150w x 2 @ 4 ohms
250w x 2 @ 2 ohms
500w x 1 Bridged @ 4 ohms
The Son of Boltar uses 60A of fusing
Dec 21, 2010 | Hifonics Apollo Son of Boltar Car Audio...
The protect light is the only light that comes on
Either one of the amps or the power supply has blown. The protect light means the power supply has been shut down due to overcurrent. Take unit in for repair. These are hard to work on due to packaging.
Oct 10, 2010 | Fender Passport Deluxe 500watt Sound...
I just bought 2 plsq10d/ 10" square Pyle subwoofers. I've got some questions. What would be better, one amp or two? How many watts for the amp(s)? Do I need to mess with my alternator to power this system?...
Hi, tech specs say 1200 watts peak. what you want is RMS value and quick guide I use to comvert watts peak to Rms is divide by 3 (approx=400Wrms) Ok to drive a little harder - use 500Watt RMS amps per speaker. decision to use 1 or 2 amps depends on amp capability -use 2 x 500wrms 2 channel amps(1 per speaker bridged mode) or 1 x 1000wrms 4 channel amp (bridge 2 channels for each speaker). Whether you need to do anything about your charging system will depend largely on the capability of your alternator and the various vehicle loads that need to be supplied on a day to day basis ( use winter for worst case scenarios) as this system could be reasonably expected to consume 60 amps on large bass notes (dead giveaway is to add the fuse ratings on nominated amps). there is vast amounts of knowledge for this subject and what has been touched on here is just that
Aug 10, 2010 | Car Audio & Video
Amp goes into protect mode as soon as switch is turned on. Pasport 250
There is a problem with the internal amp itself. These are extremely difficult to access. Contact Fender for a local authorized service center.
Dan
Mar 11, 2010 | Fender Passport Deluxe 500watt Sound...
Having problems with the installation of the brutus 2008d amp in my truck. how many channels is it? how do i connect the subs? do i connect the rca cables from the radio to the input or output.
The rca cables from your stereo go to the "input" part of the amp. Now, if there are four speaker connections in your amp, then it's a 2 channel. If you have eight speaker connections then you have a four channel amp. Note, some amps can be briged to provide more power to the speakers. On a two way amp(2 speakers), the connections can be briged to only one speker providing more power, usually whatever the amp power rating is, say a 500watt amp will put all 500 watts to that speaker. The same goes for a four way amp(4speakers), can be bridged to two speakers(250watts per speaker). Hope this helps.
Sep 04, 2009 | Car Audio & Video
Car Audio & Video Logo
154 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
