Question about Nokia N70 Cellular Phone
My Nokia N70 is no more ringing
On the Net I have found some solution like putting a patch and get this problem fixed. But I have read some comments mentioning that it will play only default ring tones not the one which I wanted. Please advice why this problem started as it was working fine for the last 2 years and when I restart my nokia N70 it rings couple of times and then it dies.
Please advice what to do. Thank you
  • ipot Aug 25, 2008
    my N70 phone has no incoming ring call
  • 1,017 Answers
Check your phones software version, input *#0000# on your phone.
Then go to: on your PC.
The code required is under the battery, it looks like this, 0522157
When updating software on Mobs, be sure to:
And obviously don't unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again. But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you're up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
Posted on Jan 18, 2008
How do i delete comments i posted to my datpiff account
I just stop and watch this website and i found out that this is very nice and interesting. I love to read blogs and articles i already bookmark this webpage. I'm looking forward to read more and I'll be back for more updates .
thank you
May 05, 2012 |
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
My xbox is mod.i can play burn new games(ex-crysis2,ac brotherhood) are can't play.when disk insert it's only say 'play dvd'.my xbox mod with 2010 version. help. . . .
Having the same problem.
You get a error message like " UNREADABLE DISK "
You must update your iXtreme Firmware to LT+
This will fix the AP2.5 error, and you will be able to play Xbox Live safer too.
More info about iXtreme can be found on the link below
Please rate my solution.
Jun 21, 2011 | Microsoft Video Game Consoles & Games
Keep getting PS3 error codes when downloading patches. From what I have read, this is a popular issue and I have not found a solution. Something about a MAC address issue. Not sure, need help cant play...
contact ps3 and get the list of ports, that has to be forwarded from router... contact router tech support and ask them to for ward the necessary ports, also ask them to enable DMZ for your PS3 in the router....
May 06, 2010 | Computers & Internet
Need a driver for vista
I have found some information and the news is not all the good.. Please read below what I have found.....
Singer Sewing Company With the recent release of Microsoft's Windows 7 OP system, many consumers are enquiring whether the Futura CE-100 and Futura CE-200 are compatible with this new version of software. Unfortunately due to the driver capability in these machines, an update or patch for Windows 7 is not currently available. We are our research into creating such a patch, we ask for your patience during this time. If a patch becomes available we will announce it here. It will also be posted on our futura support site at See More
safe_image.php?d=4bde5f922d15447b35f002d7e7cb03b2&w=90&h=90& Futura-Support
This article as written was found here on FaceBook
here is the link to see it if wanted
Jul 09, 2009 | Singer CE-200 Quantum Futura Computerized...
Cant get west front to work with windows 2000?
I recently dug this game back out, it is really cool and wanted to play it again. It was still installed on my desktop Windows XP and worked fine but couldn't get it to run on laptop with exact same problem you described. After an hour of searching the net I found this patch which fixed it and now it runs fine. You can find it at the link below. Just select the appropriate one you need.
Good Luck,
Jun 20, 2009 | TalonSoft West Front Battle Pack
I own a KENWOOD DVR-7000 DVD player. I live in UK and bought the player for 1,200 Singapore dollars. It only plays original fixed DVD regions. Is there any code or fix I can enter so the DVD can read...
The region code is burned in to the firmware of the player. If this is an independent DVD unit for your TV set and not a computer, the firmware for this may be with the main circuit board, and not the drive itself. This is based on the particular design.
If you search around net using search engines, you may be able to find some kind of code or patch that you can enter in to your DVD player. With these types of patches, if they are not factory approved there is no guarantee that they will reliably work, or not cause other types of faults.
Jerry G.
Jul 11, 2008 | Kenwood Televison & Video
Code for remote
I don't think you mentioned the model no. of the one for all remote.You've only mentioned the TV.
Please let me know
Jun 26, 2008 | Televison & Video
Hi, click on the link below. Scroll down untill you see, Are You Tall Enough for This Ride?
Please read the specifications that a PC needs to play the game.
There is some talk about patches. After you're PC system is up to snuff, be sure to update the game
This all should help you.
Good Luck!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
May 20, 2008 | Computers & Internet
Xbox 360
hard drive not reading game, faulty hard drive, get it changed inc box. this is also a common microsoft fault with this console.
Aug 03, 2007 | Microsoft Xbox 360 Console
Nokia N70 Cellular Phone Logo
61 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
