Question about JVC HD-52Z575 52" Rear Projection HDTV-Ready Television
Vertical lines problem
I've owned a JVC HD-52Z575 for about 2.5 years, and in the past year I experienced the following problem: When I power on the TV, thin vertical light-blue lines (about 2mm in width) appear across the whole screen uniformly separated by about 3cm (1.25 inches). When the problem first occurred about a year ago, the lines disappeared after about 5-10 minutes or so. Now it takes much longer for the lines to disappear - maybe closer to 1/2 hour or 45 minutes. The lines tend to disappear more quickly when the TV has been used more recently. Is this a salvageable problem with a proper part replacement? I had a repair technician look at the TV last year when the problem first occurred and he didn't seem to know what to do, and claimed the cost for repairs would be more than the cost of a new TV. Any help would be appreciated.
  • JVC Master
  • 5,138 Answers
On your blue tube there is a crt broad that may have a bad capacitor 4.7uf 250 volts most likely it can be leaky not able to hold correct charge also it might have video ic on same broard breaking down, this will cause your problem unplug crt broad from bottom neck of tube turn set on see if problem goes away if so then it means you have problem with crt broad or it could be your tube.Hope this helps you out!
Posted on Jan 18, 2008
JVC HD-56G786 Green Vertical Lines
am thank if you see it in your menu..and on ever have a bad dmd bord or dmd chip
Dec 24, 2013 | Televison & Video
My ten year old sony plasma tv has vertical herring bone lines no picture just color lines. Is my picture tube gone.
If its 10 years old boards and or parts will likely not be available--average life on Plasma and LCD sets is 3-5 years.
I would retire it--recycle it and buy a new set.
May 16, 2012 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
1 Answer jvc television, im watching then turn off have a power but sadly it has a line at the middle of monitor and turn off.
You have a vertical amplifier failure or dry solder on the vertical IC. When cold if the TV works for some time and then you are getting a thin white line in the middle of the screen after some time -- its a dry solder problem. The vertical IC runs very hot in the TV and develops dry solder after a few years.Will run when cold and switch off when hot.
Are you well versed with electronics to do the repair yourself ?. If so, revert back and I will guide you if you mention the TV model #.
Apr 11, 2011 | JVC Televison & Video
Older JVC 32" TV has lines & fold over at the top of screen. TV is about 6 years old.
Check the vertical section .. You will find few Electrolytick capacitor..replace all with new one or replace the filter capacitor at vertical IC supply..
Jul 10, 2009 | JVC HD-52G787 52" Projection Television
The faint white lines at the top of the screen is the warning that the pump-up capacitor in the vertical output circuit is going bad and the output itself is about to short out. When the TV stops working, the vertical output IC has finally shorted out. Replacing the vertical output IC, the pump-up capacitor and possibly a small value resistor next to the flyback (B+ for the v-out) should bring the set back to life.
Jan 26, 2008 | JVC AV-27230 27" TV
Vertical portion pixelats then forms solid vertical lines. Problem intermitent but persistant. The tv is 2 years old, if its the lcd panel is it worth repairing? I think I have the same problem with a...
In some cases, there are minor defects in some parts of the screen. Points that do not light, points with
brightness different from that of the periphery, or points with color different from that of the periphery.
Some pixels will always be on or always off. Please note that this is not a malfunction. So what this says is that it's not the Plasma Cell problem, its more like a bad board inside. You will need more info like schematic and find out which area the bad part is in.
Jan 04, 2008 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
Aging 43H7143
Dec 24, 2007 | Toshiba 43H71 43" Rear Projection...
Bright Green Vertical Line on Plasma TV
two options 1 check ur power moudle for burst or swolling filter capacitors & check the electrolytic power capacitor in the primary side of ur power moudle .
Oct 24, 2007 | Audiovox FPE3206 32 in. LCD Television
JVC HD-52Z575 52" Rear Projection HDTV-Ready Television Logo
281 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
