Home | Vtech | IP8100-2 Twin Cordless Phone | Model vtech ip 8100-1
Vtech IP8100-2 Twin Cordless Phone
Problem for Vtech IP8100-2 Twin Cordless Phone
By vinithleo on Jan 18, 2008
It seems to be dead. LED is not glowing not but the power adapter is working good .i measured the voltage ie 5.2v.
Same Problem
Feb 28, 2009
-   I had the same problem. No LED light, but the page phone button still worked. I had a multi function adapter, that comes with several different types of plug ends, for a multitude of devices. You can find these at your local Walmart or electronics store. I plugged it in and wham, I had power. I've had my VTech for almost 3 years, but I am guessing the adapter failed to supply enough power. Hope this helps someone.-   Deathzone
Jan 05, 2009
-   I have the same exact problem: paging works, but no dial tone.  Vonage will send a replacement adapter in 4 days.
Since there were 2 mentions that a 6v worked, I gat a replacement adapter at fry's. Adapter specs are:
Rhino Univ AC Adapter 1800mA (PST-1800ME/FU) AC100-240v, 50/60Hz adjusting automatically. DC: 3, 4.5, 6, 7, 9, 12v, 1800mA max
I thought this would work at the 6v setting, but no go.
If some one can tell me an alternative adapter they are using besides the ones from Vonage, which I suspect are cheaply made, that would be helpful.
-   badtzuman
Sep 28, 2008
-   led lights don't come on. only paging works.
amazingly this is the 2nd one to konk out right after the warranty expired.-   susanhonglog
Apr 09, 2008
-   Identical problem as far as I can tell. Power adapter working (page function works) but no ready light and no phone functions. failed a couple of months after 1 year warranty ran out. All sources (Best Buy, Radio Shack, Buy.com, Circuit City and Office Depot) I have tried are out of stock. And I've been out of phone service for over a month.
Tried rebooting and new power adapter. No change. Vonnage help desk not much help and they are out of stock as well. I suspect a class action failure.-   Old Luddite
Feb 23, 2008
-   I have the same problem and vonage told me I will have to buy a new base unit, but they are currently running about $100. If someone knows how to fix this please let me know. Otherwise I will buy a different type of device that is not so expensive.-   aiabilly
Solution #1
posted on Jul 05, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I 2 have had the exact same problem twice .
Fortunately I have a lot of wallwarts around, and sure enough,
a 6v one does the job.
Why they don't let people buy replacement units and have them ship back the broken ones for reimbursement is beyond me.
Solution #2
posted on Jun 06, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
This is a known issue with the model of phone. I am now on my 4th unit and still have the same problem every 3 months or so. Vonage will send you a new power adaptor at no charge. This does fix the problem.
Solution #3
posted on Mar 03, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I too measured 5 volts and they couldn't explain how it could still be the "wallwart". I tried a 6 volt wallwart and it seems to work fine.
Popular Solutions for Vtech IP8100-2 Twin Cordless
Questions and Unsolved Problems for Vtech IP8100-2 Twin Cordless
Do you recommend Vtech IP8100-2 Twin Cordless Phone?
Answer
Answer
set up motorola modem with security protection, now Vtech modem comes on with yellow light only for... (More)
Answer
I have a similar issue with my VTech 5871 battery not holding a charge. I am going to try cleaning... (More)
Answer
One by one both of my Vtech IP 8100 phones have gone into permanent "Searching..... mode."... (More)
Answer
vtech 8l55 2.4 gigahertz i tried cleaning the terminals but that didn't help. i am just wondering if... (More)
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 25, 2008
I have the same problem which occurred after the cable companies line collapsed. There are no led's working.
John
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Vtech IP8100-2 Twin Cordless...:
Top Phone Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Phone Experts
Top Telephone Repair
(800) 513-9962
Component level repair and complete refurbishing...
BARCLAYENTERPRISESINC
(316) 262-7171
Cctv,Cable Tv Wiring & Outlets,Computer Wiring...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
