Question about InFocus ScreenPlay 4805 Multimedia Projector
Blue colour spread
I have a Machine make of Infocus IN34. when i switch on the projector Blue colour is spreading. what need to be done. Velu
  • AVN Madhu Jan 18, 2008
    we have checked the cales and firmwares aswell still the problem persisting. Which component could be defective
I have the exact same problem except it's blue and it's a Sharp XG-NV6XU. It's showing the fault even there is no source at all. Please help.
Posted on Feb 20, 2008
I don't think it's good advise to suggest changing the lamp to see if it solves the problem. The lamp is too expensive to use as a hit and miss diagnostic procedure. If the brightness of the projector has deteriorated than maybe it would be the lamp although it there could still be other causes but showing a bluish image I seriously doubt that it's the lamp that's causing this. What we don't know is if the projector is showing this fault with either a computer source or a video source or both or even with no source at all. If it's just the computer source then the most common fault is the data cable used.
Posted on Jan 21, 2008
    Genius:
  • 1,142 Answers
  1. Reset the projector to factory defaults,Change sources. Try plugging the projector into another computer.If the color problem persists, check the cables for bent or broken pins. If any pins are damaged, the cable will need to be replaced with an InFocus-approved cable.
  2. Upgrade the projector firmware. If the projector still will not display the image, it is possible that there is an internal problem that requires repair.
Posted on Jan 18, 2008
  • Maanita Chadha
    Maanita Chadha Jan 18, 2008
    try changing the lamp or the projector bulb to fix this up
Does not turn on all 4 lights lit up on face of unit
Most likely the lamp is burned out. Check the lamp and if it is bad, replace it (unplug projector while you replace the lamp). If it turns on, reset the lamp counter and you're all done!
Be sure to weigh the cost of the new lamp vs replacing this 6-8 year old projector!
Jul 01, 2014 | InFocus Work Big IN34 DLP Projector
Infocus IN34 all indicator lights on
Power Supply problem. Check for "Bulged" capacitors in the output circuit ( 5 parts 470uf @ 16VDC). Also an indication of this problem is to remove the lamp cover and plug in the AC power cord. If the fans run slow....this is the problem.
Aug 29, 2011 | InFocus Work Big IN34 DLP Projector
How to adjust lamp light source projector lamp
Could you please explain a bit more what the problem is.
Apr 06, 2011 | InFocus Work Big IN34 DLP Projector
Projector Works for one minute then the lamp goes out.
sounds like a fan not working or a bad power supply/ballast. If it is a fan that is not working it will cause it to shut down. That would either be a bad fan or bad main board. But, if all fans are working, most likely it's the power supply/ballast.
May 10, 2010 | InFocus IN36 Projector
Infocus in34 bulb replaced now won't light back up can't get bulb to work to get to menus
looks like you power supply is defective. My best guess is that this is the first time in a while that you have physically disconnected the projector from power. If the power button on the projector doesn't come on its your power supply. Need to send it to a repair shop, or someone like me that can repair projectors.
Apr 20, 2010 | InFocus Office Equipment & Supplies
It says we need a bulb. Serial # ATMV 28 0276,
sp-lamp-019, but good luck finding one under $500.
Dec 14, 2009 | InFocus ScreenPlay 4805 Multimedia...
We have an InFocus LP70+. we have had a dark strip along the right side of the projected image. That dark strip has spread across so that now we only have a strip of the image along the left side. Not sure...
the light tunnel (integrator rod) has collapsed and needs to be replaced. you could either buy the part from an infocus service center or send it in to one for repair. it is, however, a pretty involved repair. if you are mechanically inclined, then try it. otherwise, send it in. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 10, 2009 | InFocus LP70+ Multimedia Projector
Blue transperant colour spread over the screen from the left.
IN THE MENU CHECK FOR A COLOR CONVERSION OPTION ,,USE IT ,,TO REALIGN THE COLORS
May 11, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
InFocus ScreenPlay 4805 Multimedia Projector Logo
158 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
