Question about Canon PIXMA iP3000 InkJet Photo Printer
Ip 3000 mechanism error
Hallo,
My printer keep on saying that a mechanism error has occurred and asked  me to turn it of and wait a few moment than turn it on, but still it keeps on sending the same error that something isn't right with the mechanism. It hasn't work for a couple of months, but still I think it should. So could you let me know  how to fix this problem and have it run again.
thanks  Romeo
romeofillms@hotmail.com
I have exaxtly the same problem!! HELP!!!! It is error 6b00 and it says turn off and restart but when I do it just keeps saying ERROR!! HELP!!!
Posted on Jan 20, 2008
Change your printer use - hp - 3050
Posted on Jan 18, 2008
Lens of my camera struk and there is an error "!TURN OFF THE CAMERA AND TURN ON AGAIN"
As long as there is a mechanical obstruction, this error will coming back. If you can remove the obstruction, without damaging the lens barrel, please do so. Then remove the battery and reinsert after a few moments. When the error keeps coming back, you should contact a certified Fuji repair centre. (don't forget to ask what a repair will cost, before sending in the camera in.)
Although all mechanical force to a camera should be avoided, sometimes a few taps on the camera, could help to release the lens.
But I should wait with that, if nothing helps and a repair is to costly.
Aug 28, 2014 | FUJIFILM FinePix JX650 16.0-Megapixel...
Error Code: E100 0000
http://fix-your-printer.blogspot.in/2009/03/canon-lbp2900-error-code-e100-0000.html
Error code E#100, ERR 100 or E100-0000 is a laser scanner unit error.
Solution 1:
Turn off the printer, wait 10 minutes, and then turn it on again.
Solution 2:
Flip open the top of the printer.
Look for a small shutter that holds the laser: carefully force this open with your hands and force the laser out into the center of the tracking cradle.
After you move the laser, unplug the printer for a few minutes.
Plug the printer back in.
Solution 3:
If the same error occurs, it's necessary to contact a service representative.
for other more help visit https://cbrtechsolutions.net
Jul 30, 2012 | Canon LBP6000 Laser Printer
I have a Canon 4300. It says "Error Number : 5100
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps!
Nov 29, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
When I try to print I get the following message: "Error Number: 5100 A Problem has occurred with the printer mechanism. Cancel printing and turn off the printer. Wait a few moments, then turn the power...
Did you follow the "cancel...." instructions?
Did the problem persist?
Did you contact your local CANON office, and ask for the location of the nearest authorized CANON Service Centre?
If so, what did they say?
Is your printer still under warranty?
Have you exercised the warranty, to get it repaired/replaced?
Sep 01, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Error message is this: Error Number : 6A00 A problem has occurred with the printer mechanism. Cancel printing and turn off the printer. Wait a few moments, then turn the power back on. If the problem...
Unplug printer power supply from wall or powerstrip. Wait 10 minutes then plug in power supply and turn on printer and try again. If problem persists and it is under warranty contact Canon for repair. Otherwise it might be time to buy a new one.
Dec 05, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
I have installed cannon pixma ip 2600 on my vista and it will not print says an error occured
Hallo
Some time ago I helped I friend with a simular problem, a Canon printer and Windows Vista. An error message came up when trying to install the printer driver. I looked through the windows register using regedit.exe and deleted all occurancies of Canon. (Be careful when doing this) . After doing so I restarted the PC, downloaded a fresh driver (by saving it to disk), doubleclicked to unpack it and finally installed. This might help you. Good luck!
effander
Jan 12, 2009 | Office Equipment & Supplies
Printer malfunction
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 03, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Both red lights on my printer are blinking
Blinking wit general error message : head carriage error. It cause by head cannot move to parking position or chip at ink tank not good connected. Try to use another chip. Just turn off printer for a moment for clearing epprom.
Nov 09, 2008 | Epson Stylus C83 InkJet Printer
Just not working
the printer is telling you the truth. when that happens, it's like a car starting to squeak too much. Mechanisms do wear out, you know.
got backup for your computer?
Jan 21, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
200 people viewed this question
old marine
old marine
