Ok there are 2 causes of this, te first is a dead player, the second a bad battery.. lets try the first one first..
TRY A DIFFERENT CHARGER OR USB CABLE..
TO DO THIS YOU WILL REQUIRE YOUR FIRMWARE UPDATE AND UPDATE UTILITY, GET THIS FROM YOUR MANUFACTURES WEB SITE.
1.) open up the player,
2.) look for the largest icon the board, usually a samsung,
3.) place the ic where you can read whats on it, on the right of the ic, count 4 pins down, and ground the other 4 off with a screwdriver,
4.) Connect your usbcable to it as you do this,
5.) reinstall your firmware.
6.) try it now
INCASE THAT DONT WORK
1.) open up the player, you will see a lithium battery on it,
2.) remove it
3.) take it to the shop and get a new one
4.) replace it
5.) TRY IT NOW..
If the above fails it means that your player's main board is damaged ..
Anyone recommend a good reasonably priced fm tuner for an ipod classic to turn into a radio and also...
(More)
Anyone recommend a good reasonably priced fm tuner for an ipod classic to turn into a radio and also to listen to ipod through car radio,
i found an ipod with the usb cord and all but it wont turn on, i plugged it in to my laptop to...
(More)
i found an ipod with the usb cord and all but it wont turn on, i plugged it in to my laptop to charge it maybe, but its still not turning on, and i already have itunes for my other ipod i already had before but its not recognizing this one i just found. plz help, i wanna get this one workin its better then the one i have lol.
my transcend t.sonic 650 mp3 player is malfunctioning. i switched it on once and then the loading...
(More)
my transcend t.sonic 650 mp3 player is malfunctioning. i switched it on once and then the loading symbol appeared and has remained like that ever since. it is not detected when i connect it to my pc. nothing seems to hapeen no matter which button i press. kindly help. ps - i had formatted the device recently and added new songs. thank you
