Question about Brother MFC-5440CN All-In-One InkJet Printer
USB cable - where does it plug in?
Don't have the manual, and can't figure out where to plug in the USB cable. (!)
  • marshbrown Jan 18, 2008
    Never mind, found it!
    Genius:
  • 1,665 Answers
  • 832 Answers
You can download the user manual from www.brother.com
in case you wont find out how to do the settings.
Posted on Jan 18, 2008
LG Optimus L9 Screen blacks when charger/usb-to-computer cable plugged in.
sounds like you have a usb cable for charging only.You need a "2 way " usb cable,the kind used to transfer music and pictures to and from phone to computer.These one way cables are usually used in mobile chargering,as you don`t need to transfer things,just charge.Or you got wrong cable for your phone.
Mar 02, 2014 | LG Optimus Black Smartphone
Just bought an Ativa 7 port USB 2.0 Hub and don't know how to connect it to my computer. No manual came with it.
The ones that I have seen have 7 ports 5 in back 2 on top these are called Type A USB ports, to the left of the back ports the power port is there. To the right, there is a smaller port usually a USB Mini B or Micro A port that is where the small end plugs into and the Type A on the cable goes to your computer.
Jan 12, 2013 | Computers & Internet
Don't know how to recharge
Just use the combined USB/audio cable. Plug the standard USB side in your computer, or even in the back of some modern TVs, and then plug the other side with the smaller USB plug into the speaker.
Sep 29, 2012 | xMini X-Mini II Portable Capsule Speaker -...
Hello :) pls help ..... HAve a kodak c195 easy share , Used to work fine when downloading pictures . Now everytime i Plug into USB port it shuts off . I have purchased new batteries and tried another...
TAKE THE BATTERIES OUT TURN IT OFF PLUG IT TO A KNEW USB PORT ON YOUR COMPUTER ONE YOU DON`T USUALLY USE THE USB PORT SEND`S 2.0 VOLTS TO OPPERATE DEVICES TURN IT ON WHEN THE CONNECTIONS ARE MADE REFER TO USER MANUAL!?
Aug 30, 2011 | Kodak EasyShare C613 Digital Camera
My computer don't see mt toshiba 500 GB external disk. I had Win XP with SP3 and my external disk is connected to a USB hub with 8 ports. I had a pen connected to that hub and the computer see it. But...
Your USB hub cannot provide enough power for your external hdd, you can try to plug it in directly to any free USB port for the mean time to check if its detected or not, if it has a power button ( which is not normal for regular USB powered EXT HDD) make sure that it is on, if its still not working try to use a different cable, a known good cable or plug it in to a different computer to check if its your USB port, or the usb cable or the ext hdd that is causing the issue
Hope this help.
Jul 10, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
Just purchased lg cell phone ,can't figure out how to charge . it-- thanks patricia
hi.
there should be a charger in the package, and possibly a usb cable.
plug the usb cable into the charger and then plug into your phone's usb port.
Jun 30, 2011 | Cell Phones
I have an older(much) 2400p flatbed scanner. Our computer doesnt have the appropriate plug in for the scanner, which has a db25 female(to the pc) plug. I cant seem to find any info on whether the adapter...
This is a PARALLEL scanner and most of the much newer computers don always have these.
You can buy adaptors to install in the computer or USB adaptors that convert it to USB but by the time you have paid for one of those you could buy a new one.
Do a GOOLE search for parralell to USB and that will give you an idea of the cost.
Also do a search for parralel cards to get an idea of that route.
Prices vary from country to country which is why I have not given you any figures
Jan 27, 2011 | Visioneer PrimaScan Colorado 2400p Flatbed...
C5180 all in one is not connecting via ethernet.
Before you begin: Check requirements Make sure you have the following items:
  • One of the following types of wired access points or routers: Ethernet router, switch, hub, or wireless router with Ethernet ports
  • A computer that connects to the wired access point or router
  • A Category 5 Ethernet cable to use for the HP product. (Do not use a standard telephone cable.) Figure 2: Cable comparisonc01710115.gif 1 - Ethernet cable 2 - Telephone cable (do not use) Although an Ethernet cable looks similar to standard telephone cable, each has a different plug and a different number of wires. The plug on an Ethernet cable (also called an RJ-45 connector) is wide, thick, and always has eight wires. The plug on a telephone cable is narrower and has between two and six wires.
Are you changing from USB connection to Ethernet connection?If you previously installed the software for a USB connection and now want to change to an Ethernet connection, follow these instructions to remove the USB installation before continuing.
  1. Click Start , click Printers and Faxes , and then right-click the icon for HP product.
  2. Click Delete to remove the product.
  3. Disconnect the USB cable from the product and the computer.
Step one: Connect the HP All-in-One to the network
  1. Remove any plug or protective cover from the Ethernet port on the back of the product. Figure 3: Remove plugc01710117.gif
  2. Connect the Ethernet cable to the Ethernet port on the product, and then connect the other end of the cable to an available port on the wired access point or router. Figure 4: Connect the Ethernet cablec01710118.gif
  3. Connect the power cord to the product, and then plug it into an electrical outlet.
  4. Turn the product on.
Step two: Decide whether to install with the product CD or download the software Don’t worry if you don’t have the product CD! You can download the most current software available for your product from the HP Web site at no cost. The following information might help you decide which installation method to use:
CD Download For a new product: CD installation is a quick and easy method. If you do not have a CD, you can download the software you need. For an older product: CD installation might not work if you are installing the product on a computer running a newer operating system that released AFTER the HP product released. Downloading the software provides the best results for your older product. Even though it takes more time than using the CD, downloading the latest software can help you avoid installation issues.
Downloading is the recommended method if your computer operating system released after the HP product released. About the software: The software on the CD is current to the date of the product release. The software that you can download from the HP Web site is the most current software available for your product. HP often updates software and drivers AFTER the product and CD release to the market.Step three: Install the software
Jan 16, 2010 | HP Photosmart C5180 All-In-One InkJet...
Can't find the plug in for Sony Handycan DCR-SR82
HI, The manual for this unit can be downloaded from here.
http://www.docs.sony.com/release/DCRSR42.pdf
Look at page 19 and is shows the USB connection on the docking station for the DCR-SR82. There is no connection on the camera itself.
May 04, 2009 | Sony Part 996804671 Service Manual for...
Can't figure out how to use the mp4 touchscreen player
I found a manual that is readable:
http://www.curtisint.com/html/CustService/Manuals/SYL_SMPK8854B_EN.PDF
But it doesnt tell you how to copy music from pc to player1
But lets try anyway;
Turn on the player and pc and insert the usb cable!
Now wait for abt a min. and on pc in Windows explorer therer should be another driver which is associated with the your player!
Now you can copy song from your song folder and drop them in the new drive which apperead when you plug in the usb cable!
Hope this helps!
lemme know how it works out!
Dec 27, 2008 | Audio Players & Recorders
Brother MFC-5440CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
