Question about Belling XOU492 Electric Double Oven
How do i replace a thermostat
Im not very impressed with my 3 yr old belling xou492
last year the heater element was replaced (just outside of guarentee period) and now 11 months later the main oven wont get hot enough/stay hot.
its not the heating element/ring so i bought a thermostat - but i dont know how to change it!! there appears to be too much disassembly from within the oven that i think it may be replaced by removing the oven from the unit ive got it built into and changing the stat from the rear of the appliance....
any help/advise appreciated!!!
3 Suggested Answers
  • 193 Answers
SOURCE: Belling Electric Cooker - Main oven keeps tripping electrics
yes use an ohm meter to test it
Posted on Apr 29, 2010
SOURCE: Belling built in fan oven (XOU60FP)is overheating
Have same problem, I am repairing our 648HM double oven. Top oven overheats. I am an electronics engineer. I found that top oven fan has failed, this is the first thing to replace. The grill element also failed which maybe due to the overheating oven. NIGEL
Posted on May 10, 2010
Belling 492 bl short out when oven turned on
Sounds like the oven element is broken, replacement at
http://www.elementreplacement.co.uk/belling-elecr11budget-332-p.asp
Check dimensions with the one shown
Mar 16, 2014 | Belling XOU492 Electric Double Oven
Tip
How to diagnose, fit and change a Belling fan oven element
If your fan oven is not heating up properly the Fan Oven Element for your Cooker is usual culprit. Fitting an oven element is generally very easy, as demonstrated by The Apart4u video on How to change repair and replace your fan oven element:this fan oven element can usually be changed without taking the appliance out of situ. Belling Elements
on Aug 25, 2010 | Belling XOU492 Electric Double Oven
Switch on main oven starts to heat then trips out is it the heating thermostat
Yes this is a frequent problem with thermostats. The thermostat is an electric switch which from overheat and long time use they malfunction and you need to replace it.
Nov 25, 2010 | Belling XOU492 Electric Double Oven
How do I change the oven element on a belling format 800 oven
1, If your Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
Jan 03, 2010 | Belling XOU492 Electric Double Oven
No fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
Jun 28, 2009 | Belling XOU492 Electric Double Oven
Noisy fan
it has to be replaced the bearings are shot on it I'm afraid well knowen problem in are trade.
Apr 12, 2008 | Belling XOU492 Electric Double Oven
My fan doesn't work
fan not fixable - replace. possible be that there is crap jamming the fan.check that the fan blade turns freely
Mar 13, 2007 | Belling XOU492 Electric Double Oven
Belling XOU492 Electric Double Oven Logo
175 people viewed this question
Top Belling Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
RudeRude
Are you a Belling Oven Expert? Answer questions, earn points and help others
