Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
Sound problem one of the pc is connected 4.1 speaker,two speakers are working properly othe two speakers are not working.
    Master:
  • 788 Answers
The rear speakers will only produce sound when provided surrount sound content.
Try a first person game or DVD movie. The game or DVD player software need to be properly configured to use surround sound also. Look through their audio settings.
Posted on Jan 18, 2008
No sound coming out for my hartke amps?
Are the internal speakers properly connected via the rear-mounted 1/4 inch "Speaker Output" jack? If so and still no sound, try connecting a separate external speaker (floor monitor, pa cabinet) for a "low volume" test.
The OM says the internal speakers are 4 ohm so it's unlikely that a wiring problem with speaker connections would cause all four to stop working. With AC power disconnected from outlet check for an internal speaker protection fuse BUT be careful. Charged capacitors can hold a charge for weeks!!!
Oct 25, 2012 | Hartke VX3500 Bass Guitar Combo Amplifier
I have a 29" Philips TV model 29PT4824/94R. The
To make sure that the external speaker is good or deffective try to use others speaker.If the other speaker work it means that your speaker is deffective and if the other speaker not work it means that the problem is the sound output amplifier or driver of the TV.You need to check the inner part othe TV.The board of the TV inside at the sound section, just fallow the speaker wire to the board,that is the sound section.Check if theres a loose connection.
Jul 16, 2011 | Philips Televison & Video
No sound
HELLO, CHECK THE SPEAKER AND HEADPHONE ICON TO SEE WHETHER IT IS ON.IF NOT, SWITCH IT ON.IF IT HAS A BUTTON FOR SOUND MAKE SURE YOU INCREASE THE LEVEL
Nov 18, 2010 | Computers & Internet
My laptop is year and half old and couple of days back suddenly my laptop's speakers stopped working . i tried all option in the laptop to fix it .its not working.please help.
Steps to be followed:
1. check whether audio driver is installed properly ? if not install audio driver & check
2. check audio setting in control panel & confirm
3. connect external speaker in laptop and check whether sound is coming? if sound is coming then ur laptop internal speaker need replacement
4. if there is no sound in external speaker then need to check ur motherboard or sound card.
All the best.
Aug 16, 2010 | Computers & Internet
I bought these x 240 speakers used. do i need a driver to run them? where do i connect the plugs, black and green?
These are "decent" quality 5.1 speakers, new were on about $100.00 to $150.00, have two years warranty from time of purchase.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect.
Connect speakers as follows:
1. Audio from PC, orange, green and black connecting to front right speaker.
2. DB15 (D-SUB) connecting to subwoofer, subwoofer is serving as mixer, power board, amplifier and connection box
3. White plug is connecting to front left speaker
4. Red is connecting to front centre speaker
5. Black is connecting right rear speaker
6. Yellow is connecting left rar speaker.
Establish location of the speakers, from experience in ideal world:
1. Sub should be on about your knee level or below,
2. Front centre speaker should be about twice your hight distance from you, on front and slightly above your head.
3. Front left and right speakers should be at about 45degree from your axis, at distance of about 1.5 your hight and on the level of your head or slightly below.
4. Rear left and right speakers should be located similiary to front speakers, on they level or slightly above them, again, about 45degree from your axis.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not whil eyou are standing.
In reality... hang them higher than your head in four corners of your room, front centre higher than sides, woofer lower than sides and below front centre, if they interfere with each other - increase the distance. I hate reality...
After speakers are connected:
1. Plug power cord in,
2. Turn all sounds totally down, including subwoofer
3. Increase sound on PC to maximum, let play any known to you music, tufftuff or bach, whatever, do not bother with metallica as you cannot discredit on it correct levels.
4. Increase subwoofer volume, holding one hand on the front of the grill till you get some vibration from it
5. Increase sound on centre button of the right fron speaker till you achieve equality of the sound
6. Decrease sound volume on your PC to about 60% - 70%
7. Increse subwoofer volume till you feel sound on your hand in front of the speaker.
8. Increase sound volume on front/rear speakers as required.
Hope that short intro solved all your speaker problems, enjoy! if you require any additional help, do not hesitate to answer to this post with request.
Aug 06, 2010 | Logitech X-530 Computer Speakers
No sound on Logitech Z Cinema 2.1 speakers.
1. Check Output cable properly connected to the computer in Green socket.
2. Check computer Volume Balance.
- go to start- control panel-sound & game controller
- check ur volume mute/unmute, volume all balance
3. check sound drivers/update driver
- go to - My Computyer - right click - properties - hardware - device manager - check sound hardware - Uninsall all sound driver
- Then Scan in device manager. it will automatically install again.
4.Then check output volume.
Feb 01, 2010 | Logitech Z Cinema 2.1 2.1 Speakers
The speakers are intergrated in to the monitor and don't seem t.
First, find out if the speakers or audio is working properly. At your PC menu, left click Setting, Control
Panel, and Add hardware. Click the add hardware wizard and just follow the instruction until you will find all the installed hardware of your PC. Click at the Audio, and the sound driver of your PC to find if these are working properly. Assuming that this are working
properly, test the audio output of your PC by putting
in another set of speaker (borrowed or otherwise).
If you hear the sound, then it is a connection problem. The wire to the speaker could be broken, or
the speaker itself. Under this condition, it is your
option to open up your monitor and test the speakers.
Or to just buy a new set of speakers. Unless you
are familiar with handling an open monitor, you may
go ahead with opening the monitor Otherwise, it is
wiser to buy the speakers which is much cheaper
than a monitor that could accidentally get damage.
Nov 29, 2009 | NEC Speaker Wire Computer Speakers
I have acer al1917w A monitor but no sound
There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
Jan 09, 2009 | Acer AL1917W LCD Monitor
Center channel sound output
Its not working correctly I have a few different types of center channels and they all have equal sound no matter how many speakers are in them. Connection in speaker box is bad or you may have a blown speaker
Dec 31, 2008 | Pioneer VSX-455 Receiver
Bose amplifier does not work with a 6 speaker selector
your wall speakers may not be connected.... disconnect each speaker from the selector box and test with a small AAA battery to see if they are connected by putting the battery between each speaker's wires , you will hear it crackle ,then gradually connect each wall speaker onto the speaker connector box . If the first set does not work i suggest there may be a problem with your speaker selector box . Good luck
Mar 18, 2007 | Bose Lifestyle SA-3 2-Channel Amplifier
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
100 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
