Philip's TV Model 55PP88620 Convergence Problems
Hi there my Tv's just 4 years old and I think the convergence Ic's are shot, there is blue lines which arc up in the top right and the bottom left corners. I have been reading how to change them and are pretty confident I can do it and was wondering if anyone had a Service Manual for this model and any other information to help me out as I was just quoted $480 to $680 to fix it and I've been off work for over 12 months with a crook back and can't afford that much when I know the parts aren't that expensive. Thanks Gazz.
  • Gazz_00 Jan 19, 2008
    Thanks for the advice the ics in mine are STK392-120, I will wait to hear from you if it's the Model that I need a new board and if you know where to get the board would be much appreciated as well. Cheers.
  • Gazz_00 Jan 20, 2008
    Hi there, I found 3 numbers on the back of the TV there was 3135 015 15181, as well as DPTV-325 and on the G Board with the ic's is 3135 037 10121. Thanks hope this helps.
  • 5,138 Answers
Let me look up your make and model number there is one phillips model that replacing ics does not fix problem most of the time you need to order new convergence broad ,if they are STK-392-110s up grade with 180s you can order these chips for 10.00 each at Electronix Parts they also have STK392-560s if these are the ones you need,call 1-800-223-3205, new broad i think cost 100.00 maybe less dont remeber but i can find out where to get broad if that is the case.let know how you come out!
Posted on Jan 18, 2008
  • ladywinn
    ladywinn Jan 19, 2008
    Hi again, I need to know your chassis number look for it on back of tv or printed on your broad like Dptv310,also look on broad that has STKs for number there! It may go like this 3135013 3092 301, let me know this asap and STK392-120 use STK-392-180s,to up grade with better ics ,/ I also have a number you can call to send your broad in for repair if this is the case- call Tritronics 1-800-638-3328- you can visit online as well www.tritronics.com
Had convergence issues, green was okay, red wouldn't move horizontal, and blue wouldnt move vertical. Also, functions such as pincushion and tilt wouldn't work with red or blue. Replaced convergence IC,...
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some images of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself.
Mar 06, 2011 | Mitsubishi VS-45609 TV
Where is the convergence IC located on the sony projection model tv model KP-46WT500?
On the large heatsink.
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 21, 2011 | Sony KP-46WT500 46" Rear Projection...
I have some distored blue color across the screen
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 15, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Everything on the screen is doubled focus and it seems like the screen is calapsd in the middle
What you describe is probably a color convergence collapse, usually caused by a power amplifier failure, refer to the following link: http://www.youtube.com/watch?v=esk4nYZKFcg if this video is close to what you see on your TV you will need to replace both power convergence IC, the model KP57WS510(model given in your post) calls for STK392-510 both are available through UED, email johnl@ued.net, the above link gives an idea on what is needed for the IC replacement, that is if you're thinking of repairing the problem yourself.
Apr 07, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Mar 27, 2010 | Panasonic PT-53TW53 53" Rear Projection...
JVC AV-48WP30 convergence drifting after IC replacement
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2010 | JVC AV-48WP30 48" Rear Projection...
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
PT-47WX53 blue convergence PROBLEM
Sounds like you have a blue foldover in the convergence. Since tv has been worked on it could be bad ic, maybe not original, generic. I would say if you can open set and look in, look for the blue it should be marked. look for a loose connection. If you can have someone to gently tap around that blue amp and see if it moves are go away, it might be a simple loose connection and needs soldering. If not then my have to change ic again. Becareful cause set would need to be on to really check. Hope this helps.
Aug 15, 2007 | Panasonic PT-47WX53 47" Rear Projection...
you will need to change or have the convergence IC's replaced I'm afraid. Good Luck
Televison & Video Logo
196 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
