Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
UAltra quite 1 water in tub water does not drain
Checked hose no blockage that i see, cleaned bottom drain. water is atthe level of the heater coil and was wondering if this is a fire or electic shock problem.
    Genius:
  • 1,003 Answers
SOUNDS LIKE TIMER OR WATER SOLENOID
Posted on Jan 18, 2008
Unit acts like it has received water then continues to cycle as if it hasn't, no water is pumped???
Symptom Check
Click on underlined items for further information Washer does not work and makes no noise Washer does not work but it does make noise No water is entering the wash tub
- or no hot water
- or no cold water The water fills the wash tub too slowly The tub does not fill with enough water
  • Test the water level switch
  • Check that the drain hose is positioned roughly as high as the top of the inner tub
The water overflows the wash tub Water drains out during the wash or rinse cycle
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
Wrong temperature of water is used
  • Water supply hoses may be reversed
  • Hot or cold water supply valve may be turned off
  • Water supply hose may be kinked
  • Check water inlet valve
Water drains out while it is filling
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the cam bar
Water drips into the wash tub when the washer is off Water does not drain out of the wash tub Water is leaking onto the ground
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Agitator does not move Agitator movement is weak or moves in only one direction
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
Drum does not spin
  • Test the lid switch
  • Test the centrifugal switch
  • Test the motor
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
Spin:
  • Test the motor
Cycle does not advance
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
Burning or electrical smell
  • Unplug the washer
  • Locate the source of the odor then read the instructions in the related section
Foul or stale odor coming from washer or clothes
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
  • Check for article of clothing stuck in the outer tub
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Goes out of balance too often Clothing is damaged
  • Inspect agitator for cracks or rough spots
  • Inspect for rust spots
Jul 11, 2015 | Washing Machines
Tip
The washing machine is draining but the water is coming back inside?
Check out this possibilities for water not draining in the washing machine: This problem relates to the hose connected to drain pump. The drain hose should not be in laundry tub more then 4 to 5 inches. Measure it and if it’s more then 4 to 5 inch then cut the excess hose in the tub. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly. But if the drain pump hoses are ok checked then this problem relates to slow drain of water from laundry tub. You can solve this issue by cleaning the drain pump blockages and dirt build up this will make the flow of water proper in the draining of the laundry tub.
This will help.thanks.
on Mar 18, 2010 | Washing Machines
Zanussi fle 1416w wont fully drain the water out and final spin leaves clothes quite wet. When i turn the drum manually i can hear the water below the drum sloshing about. What's wrong with it?
Hi.
Check for drain blockage, check position of the drain hose and check the pressure switch.
1) Access the drain filter and look for drain blockage. With Zanussi front loaders this located in front at the bottom right hand corner, there is an access door in there.Open the door, unscrew the cap and use a container to collect the water. Disconnect power before starting maintenance.
2) Check the position of the drain hose. Make sure that the height of the hose elbow is as specified in the manual or you get siphoning (water getting back from drain hose inside the tub) and drain does not end.
3)The machine has a pressure switch. It is a sensor connected to a long thin rubber hose. The pressure switch is located in control assembly. Clean pressure hose and switch. One way to test the pressure switch is by blowing into the switch, but manufacturers say this must not be done as you can damage a good switch.
The pressure switch is difficult to test in full. Testing is done either reading voltages while machine is cycling or reading Ohms at the switch with tub empty and full. For safety reasons I suggest users to avoid performing tests or maintenance that must be done with power on.
Here a page about drain/spin problem.
Start checking drain hose and drain filter.
Regards.
Ginko
Aug 18, 2011 | Zanussi FLE1416W Front Load Washer
Water remains in machine. Machine stops after a minute or so and diplays F11.
F11 means Drainage fault.
Water present in appliance and is not being drained off. The display shows Drain fault F11. The buzzer is activated for 2 minutes.
Background information:
After each drain pump step, the circulation pump operates for 2 seconds and heater pressure switch B1/13 checks the water level. If it is too high (large quantity of residual water remaining in the cabinet), the drainage time is extended. If, after a further check, the water level is still too high, then the program is interrupted, the fault code is saved and the drain pump is activated. Fault code F11 is also registered if heater relay 1K1 is not activated after the fault code F51 register check; see Section 080-3.18. Drain hose kinked. Remedy: Check the drain hose for correct positioning.
Cause: Drain blocked.
Remedy:
1. Clean the on-site drain.
2. Check the sump drain.
3. Check the filters.
4. Check the heater pressure switch and replace it if necessary.
Cause: Ball in non-return valve in sump has not opened (e.g., jammed).
Remedy:
Clean the non-return valve in the sump or replace it if necessary. Cause: Foreign objects in the drain pump.
Remedy:
Clean the drain pump and its impeller.
Cause: Drain pump defective.
Remedy:
1. Check the voltage supply to the drain pump.
2. If correct voltage is present, check the drain pump motor winding.
3. Replace the drain pump, if necessary.
Cause: Foreign objects in heater pressure switch.
Remedy:
Check the heater pressure switch for blockages and correct switching point.
Cause: Heater relay defective. Heater relay (coil or contacts) becomes defective during the drainage step (after fault code F51 register check).
Remedy:
Replace the heater relay.
Hope this helps to solve it.
Jul 05, 2011 | Miele G2432SCISS Builtin Dishwasher
F11 blocked inlet/drain
f11 error code says in the manual
Drainage fault
After each drain pump step, the circulation pump operates for 2 seconds and heater pressure switch B1/13 checks the water level. If it is too high (large quantity of residual water remaining in the cabinet), the drainage time is extended. If, after a further check, the water level is still too high, then the program is interrupted, the fault code is saved and the drain pump is activated. Fault code F11 is also registered if heater relay 1K1 is not activated after the fault code F51 register check; see Section 080-3.18. Drain hose kinked. Remedy: Check the drain hose for correct positioning. Cause: Drain blocked.
Remedy:
Cause:
Remedy:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
this is usually caused by a blockage in the drain but can also occur from other circumstances as listed above you can also see this at this link as well http://appliancehelponline.com/miele.html
if you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks again Rick
Jun 07, 2011 | Miele Dishwashers
Machine not draining water will spin but water left in machine clothes not washed keeps cutting out on cycle
Hi.
Move the machine and check the drain hose. If the hose elbow is set at incorrect height the water will be siphoned back inside the tub.
Access the drain pump filter (front-bottom access door or trim on most front-loader, underneath for top-loader). If there is blockage in there the water will not be drain completely.
Clean or replace the pressure switch and the rubber hose connected to the pressure switch. This device detects water level and stops drain when there is no more water.
In some rare case the main control module may be defective. Test all the rest first.
Regards.
Ginko
Apr 28, 2011 | Washing Machines
The hot water in my tub has slowed to a trickle. We have trouble with lime build up in our water. It is a single handle control. Should I assume that it is lime in the hot side stem. If so,how do I clean...
Does the hot water flow in your other household faucets seem OK? If not, the problem could be lime build-up on the heating coils of your hot water heater. You should drain your hot water heater once a year. You will notice a hose hook up at the bottom. Hook a water hose to that, drain the hose to a place outside that is LOWER than the hose hook-up (gravity), then open the valve on the water heater, BUT BE SURE THAT YOU HAVE TURNED THE ELECTRICAL BREAKER TO THE WATER HEATER OFF BEFORE YOU DO THAT. Once the water heater drains, turn the valve(faucet) on the water heater all the way to the right (off), and when it is filled throw the breaker in your breaker box back to "on"so the water can begin heating.
Now, to the problem at hand: If the ONLY hot water flow problem is the tub, you've got a blockage either in the hot water line between the water heater and the faucet, or a blockage/lime buildup in the faucet itself. Hope that it's the faucet, because if it's not, it could be ANYWHERE between the water heater and the bath faucet.
My best advice is that you have the tub faucet replaced. It sounds as though you are not sufficiently adept to do that yourself (no insult intended). While a qualified plumber is in there, he should be able to tell if the hot water blockage is in the faucet or further back in the system. By the way, you don't have to replace the faucet with a single handle unless you just want to. Good luck!
Jul 17, 2017 | Danze D302521 Antioch Roman Tub Faucet...
Maytag Quiet Series 300 won't drain all the way. I've checked the drain tubing and there is no blockage. Can someone help?
When you say you checked the drain hose, was top and bottom meaning did you pull out d/w. If you hadn't remove the bottom hose and check the bottom of the hose as well as outlets for the pump, clean out and run through cycle. If you had, then clean out the drain area in the tub of d/w. , should this not work, your pump is not working properly.
Oct 14, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher drains but leaves behind about 1/2" of standing water
Water standing in the bottom of the tub is normal.
A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated.
Jun 22, 2009 | GE Nautilus 24" Built-in Dishwasher
At the end of the cycle the water is not draining out of the tub. I vac'ed out the water, removed the filters and checked for debris but found non.
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump (not switching from recirculate to drain) , a wiring problem, or a faulty timer board can be cause the machine not draining.
May 06, 2009 | Bosch SHV46C03 Built-in Dishwasher
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
116 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
