Question about Samsung PCL542R 54" Rear Projection Television
So my PCL542R........
Decided that it didn't want to turn on the other day. Instead it made a scratchy noise in the rear bottom area the sound was definitley not coming from audio cause it actually came on briefly until it decided to say goodnight. Unplugged it and next day plugged back in and tried but nothing. Noticed when plugging it in it clicks and green light on front illuminates briefly. Ive looked at other problems on here that resembled mine on similar products and they alot of them point straight to flyback. I'm on the verge off ordering one cause they aren't too expensive. But I also know exactly where that mindstate can lead someone too. I'm sure you all know what I mean if you are in any kind of repair business. Any knowledge would be appreciated. Thanks.
  • brian352 May 11, 2010
    What is flyback. My TV is doing something similar? If left unplugged for a day or two, it will turn on briefly and then just turn off. Then if I unplug and plug back in it just does NOTHING!
    President:
  • 4,402 Answers
Sure sounds like flyback to me
Posted on Jan 18, 2008
I have Nissan Tiida Latio 2005. Engine gives scratchy sound on start up in morning and after long time being off. Sound is so scratchy.
ot may be a belt noise
before starting put a bit of soap detergent on the belt
after starting if the noise is gone , there are spray on belt quietening products on the market
if it is still there have the running bearings checked by an accredited mechanic.
Jun 06, 2015 | Nissan Tiida Cars & Trucks
Scratchy noise at the back of defender
You need to have a look at your rear suspension bushes, they make a clunking, knocking sound that sounds a lot like a trailer when empty bouncing around.
Mar 06, 2012 | 1993 Land Rover Defender
What causes the static background noise in my keyboard?
It sounds as though you have a static electricity problem in your volume pot. Although there are sprays on the market that you can use for all of the electrical switches on your keyboard which removes and suppresses static electricity, one way to make sure this is the problem is to slide your volume slider to maximum, then minimum, up and down about 10 to 20 times, if the scratchy sound begins to diminish, you knwo the problem lies there. As a matter of fact, if you do it long enough, the sound may go away altogether, although without a good spray of electronics cleaner or electrical contact cleaner (which you can find at stores like home depot or online, even eBay), the sound will return.
If this is not the case, and the scratchy static sound does not go away or depreciate, it could be your cords or even static on the pc board inside the unit. If you are confident that you can crack the case on your board without causign damage, then get a screwdriver and open the case (all screws are located on teh bottom of the unit) and give it a good spraying with electrical contact cleaner on all of the contacts and even a once over on all of the circuit boards. Do not wet the circuit boards with too much spray, rather, give them a light misting.
For areas where you plug in, like your 1/4 inputs, your midi ins and outs, and headphone jack, spray the contact cleaner inside the holes. You don't have to worry about spraying too much in these areas. Just do not oversaturate.
Hope this helps, and thanks for using FixYa
Jul 18, 2009 | Music
PCL542r convergence
Samsung part number AA95-00706C its available at www.partsstore.com
Mar 13, 2008 | Samsung PCL545R 54" Rear Projection...
Need someone who repairs Samsung PCL542R tv's in the Atlanta area
go to this site and post an email they have sources to obtain hard to find parts. They are in NC so if you click on the contact link list what your needing. I have used them countless times to get parts that no one else can find.
http://servicemanuals.vstore.ca/
Mar 07, 2008 | Samsung PCL542R 54" Rear Projection...
The color on my PCL542R is off...
try turning up the blue drive alittle see if that helps.
Feb 02, 2008 | Samsung PCL542R 54" Rear Projection...
Scratchy noise?
Are the speakers old? The only thing that can make a random scratchy noise on the speakers as far as I know is a dirty volume knob. Try turning it all the way up and all the way down (with nothing playing) and see if that helps. If it does, blow them out with some compressed air. I'm thinking your issue is probably software / driver related though, does the scratchiness happen in other programs? WinAmp? Windows Media Player? .. if it does, you've narrowed it down to a driver-related issue, go to your sound hardware's manufacturer website and download the latest drivers.
Jun 15, 2007 | Altec Lansing 641 Computer Speakers
Sound scratchy
Seems to me that the first thing you want to do is find out if your problem comes from the camera speakers/output, or if it records them scratchy. Take one of the "scratchy" cassettes, and play them on another device to see if it transfers bad audio. If it does, then you're worst off offcourse, more of a repair. If it doesn't you can decide you don't need a repair, as long as it does the job. Good luck
Apr 01, 2006 | Panasonic NV-DS60 Mini DV Digital...
Samsung PCL542R 54" Rear Projection Television Logo
139 people viewed this question
Jerry Greenberg
Jerry Greenberg
