Question about Maytag MAH2400A Front Load Washer
Can you tell me what error code 3E means.
  • Anonymous May 26, 2008
    e3 comes on what the ****
How do you install a new control board
Posted on May 11, 2008
    Problem Solver:
  • 5 Answers
If it's still there, pop out the front bottom panel. There is a Technical Information packet stuffed behind it.
3E says:
"Drive System is not working correctly. Bad windings, speed sensor, wiring connections, or Control Board."
Posted on Mar 06, 2008
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ... > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
My Maytag MAH2400A Front Load Washer will not open. Locked inside of the chamber is a load of laundry. How do I open the door without damaging the mechanism that keeps it closed?
As I sit here with my Maytag Neptune MAH8700AWW torn apart, I can tell you it is impossible to unlock and the 800 number is no help. They tell you to unplug it for 5 minutes. Some web posts talk about a "magical release cord" under the top cover but it does not exist.
Nov 24, 2010 | Maytag MAH2400A Front Load Washer
Code 3E
what does 3E mean on a
Maytag Neptune front load washer
Apr 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
What does a 3E error code mean? i have a maytag
Trouble shooting guild for this machine indicates this means Motor Failure. Over current is detected
Feb 08, 2010 | Maytag MAH8700A Front Load Washer
Maytag mah2400aww 3E error and it will not spin
I have this problem with my unit. Called Maytag and got blown off. Unplugged the unit for 24 hours and it reset. Ran fine for a while but the problem comes back.
Jan 14, 2010 | Maytag MAH2400A Front Load Washer
ND Error code
Error code "nd" means it is not draining. Click on this link to get the user manual:
Then click on "GET THIS MANUAL" to download the manual.
Not draining can be caused by the controller, pump, solenoid valve, or clogged drain.
If this information was useful, please select YES to the first to rating questios. Good Luck and thank you!
Oct 22, 2009 | Maytag MAH2400A Front Load Washer
Cycle stops 3E code appears
Well the error code 3E means that the overcurrent is detected at the moter.
Please check it if you have some overcurrent problem!
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAH 2400 AWW flashing error code "dc"
Hi Pepsi,
"dc" means that the control board is trying to ramp up (that is, send a signal to the motor controller), but has encountered an unbalanced load and so shuts down. Specifically, "dc" means "distribute clothes".
I took this opportunity to upload a Tech and Troubleshooting manual for you. Here is the link for it. Read it carefully. You will be required to perform a "board output" test after placing the machine in "Service Mode".
I gotta tell ya, though. Based on my history with these, I highly suspect that the machine control board has failed. Let me know what you find, OK?
(And don't forget to rate this solution as "FixYA!", deal?
Apr 11, 2009 | Maytag MAH2400A Front Load Washer
Maytag front loading washing machine
3E = Drive system is not working correctly. Bad windings, speed sensor, wiring connections or Control Board.
Jun 12, 2008 | Maytag MAH2400A Front Load Washer
Maytag MAH2400A Front Load Washer Logo
752 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
