seems to be no reason for it the machine is operating. Is it the same as a car air con where there may be a gas leak and needs re-gassing? know very little about them and am hoping for an easy fix.
-   Externally Wall Mounted Compressor Unit Cooling Fan not working - Unit is operating but will not cool - System is 12 months old.-   BoB CPBLL
same as car aircon, but uses different kinds of freon. check first the thermostat setting, may be it set too high. set it to 20'c. if still not cooling, check wiring on ACCU, check capacitor too.
Remote control functions do not work. I can only turn the unit on and off. I have already changed...
(More)
Remote control functions do not work. I can only turn the unit on and off. I have already changed the batteries and put in 4 new ones. None of the instructions in the operating manual work.
everything is hooked up i have 2 12,0000 units in seperate rooms and i hooked up wires 1,2, and...
(More)
everything is hooked up i have 2 12,0000 units in seperate rooms and i hooked up wires 1,2, and 3.same on each unit but it wont kick on and flashes11 times please help im desperate!!!!!!!!!
My remote got damaged and I need to order a new one. I could also use a new owner's manual, as mine...
(More)
My remote got damaged and I need to order a new one. I could also use a new owner's manual, as mine was misplaced. By the way, the unit is great and cools off a very large area of the house. Thanks in advance for your help.
