Question about HP Officejet 5610 All-In-One InkJet Printer
Error 0xd05d010d on hp 5610
The on,copy,fax,scan and error keys blink continuoslly after power on and reset. It says reset power but there is no + key to use in reseting it.
  • 6 more comments
  • sumitdamrani Jun 11, 2008
    i m having hp officejet 5679 .it is not working showing the error 0xd05d010d.kindly help.
  • Anonymous Jul 06, 2008
  • MRDAUGUSTE Jul 06, 2008
  • blackhat_123 Sep 05, 2008
    i tried pressing #and 9 ,i also tried pressing at same time but no luck any other advise
  • Anonymous Jan 20, 2009
    blinking copy, scan, fax buttons. with error code
  • Slayn Mar 09, 2009
    What should I do? I tired to do the reset thing but it doesn't work. All I did was move the printer to my other pc to print something and then when I put it back to this one, this message keeps popping up.
  • Anonymous Apr 27, 2009
    error 0xd0620130
    loong beep
  • Anonymous Mar 15, 2014
    HP 5610 ERROR 0XD05D010D
Hp officejet 5610 error codes + 0xd05d010d
Posted on Mar 18, 2008
    Genius:
  • 1,003 Answers
UNPLUG PRINTER FROM WALL SOCKET PRESS # AND 9 AS YOU PLUG PRINTER BACK IN TO DO A FULL RESET
Posted on Jan 18, 2008
Error 0xd05d010d on hp 5610help me......!
Posted on Feb 17, 2010
    Problem Solver:
Posted on Jun 05, 2009
  • Nikesh Mehta Nov 01, 2011
    i sovle the problem carrage pcb is bad
  • 30 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
747
Posted on Feb 27, 2009
Pressing 9 and # don't work what is the next now?
Posted on Jun 25, 2011
Look at Courtdate solution above from Jan 18, 2008.
This fixed it and I am happy. Unplug the printer, as it says, plug printer back in and press # then 9 (on the printer). I tried turning printer off and unplugging...I think it worked when the printer remained turned on and then I just unplugged it and plugged it back in, then pressed # then pressed 9 (on the printer).
There was a line on the display of the printer that looked like ---------------- when it started back up. That was real quick. I think it was resetting itself. It works just fine now. Thanks to whomever gave this tip.
Posted on Oct 19, 2008
Tried #+9, #, 9 doesnt work
Posted on Nov 04, 2008
Tried #+9, #, 9 doesnt work..
Posted on Oct 18, 2008
HP officejet 5610 All in one printer cannot print or work because power button,Alert button,copy,fax,scan button all were blinking on and off with message on screen Error:0xd05d010d please help, also reset...
Try to reset the printer:
Unplug the printer from power
Hold the # and 9 together while plugging it back
If still not working try again with a # and 3 combination
Oct 04, 2011 | HP Officejet 5610 All-In-One InkJet...
Message on HP officejet 5610 All in one Error 0xd05d010d and on button,copy,fax,scan and alert yellow light keeps blinking on and off "tried reset the power cord still givwing same problem.Please help
Hello; I have an hp officejet 5610n all in one, when I turn on my printer i have this message on the printer "Error:0xd05d010d Reset power." and some buttons are blinking many thanks
lets start uninstalling your hp oj 5610 software from the uninstall program to remove it properly. Second is to install the software again... if the problem occurs the best thing to do is to go to the nearest HP Service Center in your area... i hope it helped.
Dec 22, 2010 | HP Officejet 5610 All-In-One InkJet...
When press # and 9 key while turning power on, the hp5610 should perform a full reset, however the "power on", "fax", "copy", "fax", "scan" and "!" all flash at the same time. How do I correct?
You can't. A reset is a #6. A #9 resets the NVM - the NVM is the firmware that makes the printer function. If you have reset the NVM there is no way to bring it back again unfortunately. It should only be used by HP in their repair department when they are seeking to replace the firmware components.
Feb 21, 2010 | HP Officejet 5610 All-In-One InkJet...
Error code 0xd05d010d reset power
Unplug the power cord from the All-In-One as well as the power outlet.
Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Then check and see
Good Luck
Sep 16, 2008 | HP Officejet 5610 All-In-One InkJet...
Product Not Working - HP5610 ALL IN ONE
I would like you to try other way of resetting your printer.
PERFORMING SEMI-FULL RESET
  1. Ensure that you have a two contact phone cable connected to line 1 socket of the printer and that the other end of the cable is connected to the phone jack in the wall.
  2. Perform a partial reset on the printer. To do this first remove the power supply from the back of the printer. With the power off press and hold the # and 3 keys.
  3. Plug the power back into the printer, keep holding the # and 6 keys till you see “ SEMI-FULL Reset ” displayed on the printer screen. Sometimes, the printer will just turn off, if it happen just released the two buttons then press the power ON button to turn the printer ON.
  4. After turning it ON, you will see the message "NVM SEMI-FULL" reset.
  5. If this does not resolve the issue contact HP at 1-800-474-6836
THank you so much.
adonscott
Jul 22, 2008 | HP Officejet 5610 All-In-One InkJet...
Reset Power Error 0xd05d010d
First power cycle the printer and then reset the printer.
May 21, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
6,301 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
