Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Defy Dishmaid Dishwasher (12 place), 2 yea...
By ilana smit on Jan 18, 2008
If I put it on, all lights are working, water can come in, but wash cycle never starts? Can you pleeze help and advice accordingly?
Same Problem
Mar 17, 2009
-   IT does not want to rinse agian, makes the cycle start all over agian-   rroberts410
Jan 17, 2009
-   Yep, I have the same problem. Except mine is intermittent. Sometimes the wash cycle starts and sometimes not. Mostly not. I think it is either one of the sensors that might be clogged or faulty, or perhaps a fault in the controller unit, which is behind the settings dial. I am looking into it myself, but if anyone has solved this one or knows what it might be, please post a solution.-   chrisvale
Jan 27, 2008
-   I have the same problem with my Defy Dishmaid DW-12. It switches on & starts taking in water but wash cycle never starts. Is there a way of resetting it or something, please advise?-   WKok
Best Solution
posted on Jan 18, 2009
Very Helpful)
chrisvale
Rank: Apprentice
Rating: 100%, 3 votes
Well, I fixed it in my case, by opening it up and taking a look. It seems that water was leaking out of the main compartment into the guts of the machine and shorting out a solenoid (I think). In my case, the water was leaking at the location where the 'water hardness adjustment' knob/screw is. This is in the middle of the left inside wall. (Take a look at your manual)
This may or may not be the problem in your cases, but it certainly produced the same symptoms. You need to be somewhat technically inclined to do this, and ABOVE ALL, make sure the dishwasher is off, unplugged and the water supply is turned off before going any further...
You start by taking off the top 'preparation surface' o the dishwasher by lifting two plastic clips at the back of the machine and sliding the top backwards and off. Next, by removing the left cover plate of the dishwasher (there are screws at the back, top and front of the machine), you expose a large flatish plastic device about 150x300x15mm that is responsible for dividing up the incoming water to add salt to one portion and then presumably recombine the water. This is held in place by two clips on the left side and the large ring around the water hardness adjustment screw on the inside of the machine. Twist off the ring and give the plastic thing a good pull to loosen it from the black tar-like stuff. Once it is free, you'll see a black o-ring that seals the joint between the plastic device and the main compartment. In my case, this was full of gunk and not sealing properly. I gave it a good clean and refitted the whole assembly. For good measure I also checked the clips securing the hoses connecting to the plastic device and made sure they were sound.
There is an electrical connection to what I think is a solenoid below the plastic device described above at the bottom of the machine. In my case, water was dripping down on top of the electrics when the machine took in water and I guess must have shorted out the solenoid, bringing the whole water delivery process to a halt. This created the mpression that the machine would fill up with water and go no further. I gave the whole area a good dry with a cloth. I also had to tilt the whole machine and allow the water that had, over the last few days acumulated inside, to drain out.
When everything was dry, I put back the cover plate, plugged the machine in and turned the water on and tested with a rinse, then a number 3 wash another three times. Everything worked fine.
Please be very careful when working with machines like this. Electricity and water don't really mix. I advise if you are not qualified that you ask a suitably qualified person to do the job for you.
Good luck.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
I have a countertop dishwasher, The problem is excessive water remains in the dishwasher and it wont... (More)
Answer
Hi, I have a built in whirlpool dishwasher with an electronic control panel and the 'normal' and... (More)
Answer
My GE Nautilus dishwasher takes water in and then stops and nothing happens. I tried flusing it with... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwashers Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
