Question about Kenmore 73952 Gas Dryer
Rust marks from a stainless steel drum?
These drums are supposed to be stainless steel, why are we getting rust marks?
  • lovemex Jul 13, 2008
    I have the same problem with a reversible drum, so there is a seal at the front and back. I will replace both seals. Could you provide step-by-step instructions for me? It is a Kenmore 110.74952300 model. Thanks!
  • 5,911 Answers
If you are talking about brownish colored stains on your clothes, this is actually caused by the drum seal going bad. The drum seal fits around the perimeter of the drum where it meets the rear bulkhead (wall) of the dryer and is a felt type material. One some dryers the drum is reversible and there is a seal on both ends of the drum. When the seal gets old, it becomes brittle and starts to crack and come apart. There's usually a brownish colored pigment that comes off the seal and can get on your clothes. If the seal is worn too much, your clothes could actually be getting caught in the drum between the seal and being dragged. This will also caused brown streaks on your clothes. Now...what causes the seal the wear prematurely are high temperatures. If you do not routinely clean your dryer ducting, your dryer could actually be overheating. This can cause the seal to become too hot and make it brittle over a period of time. Any appliance repair dealer will carry the drum seals for the dryer as it is a common part that requires replacement. If you could post back with your EXACT model number (located around the door opening) I could find a part number and price for you. In addition, I could give you step-by-step instructions on how to replace the seal if you wish to tackle this on your own. It's not a difficult repair and the average consumer should be able to accomplish this task. It will also save you $$ on the long run if you don't want to pay high labor charges of the appliance repair guy. Let me know if I can assist you further.
Posted on Jan 18, 2008
  • tripieper Jul 26, 2011
    We have the same problems with stains. Frigidaire Gas dryer Model# FSG748GFS0, can you provide instructions on how to perform the seal replacement?
How do I clean, what appears to be, rust marks on my stainless steel refrigerator
DO NOT use anything but a dedicated stainless steel cleaner. Some types of Windex have ammonia as one of the ingredients and you can imagine what that will do to your stainless steel finish.
Mar 23, 2014 | Samsung RFG297HDRS Stainless Steel
How to repair stainless steel on a dryer drum
For my Frigidaire manufactured Kenmore dryer, the stainless steel drum is part ordinary painted steel (front flange). That flange is part of the suspension for the drum. The flange rides on a nylon wear pad above the door. On both sides of the pad, there is a felt that is glued to the dryer front panel to act as a seal. What happens is that the paint on the ordinary steel flange rubs through and rusts, staining clothes during the drying cycle. I have to replace the nylon pad and felts every few years to combat the rusting issue. The felt and nylong pad assembly is glued to the cabinet flange using heat resistant adhesive.
Feb 25, 2012 | Dryers
We have a Maytag Electric Dryer, Model LDE512 , which leaves black marks on clothes while drying them. The dryer is about 18 yrs. old and has been working great except for this one problem. We have...
HI The drum is mostly stainless steel; The end that contacts the drum guide is just painted steel. After years of rubbing, some rust can form after the paint wears away,thus, causing the stain. Painting the bare metal (after removing all rust) and replacing the tumbler bearings,roller and roller shafts, will correct this issue and prevent it form happening in the future. You should also replace the tumbler seal while the unit is disassembled. Part numbers are below:
Tumbler bearings/Glides(You need two)- 306508
Roller - 12001541
Roller shaft - 6-3129480
Tumbler seal - 314820
Roller Shaft washer - 312535
Retaining Ring(shaft)- 410233
Jul 16, 2010 | Dryers
Dryer is leaving brown marks on clothes. it is either a burn mark or they are getting caught between dryer drum and shell, not the door
I had the same problem. Unfortunately, it is caused by a rusting drum edges, if you can believe it. My dryer was only 6 years old when this problem occured. There are felt gaskets on the front and back of the drums where it contacts and rotates on the frame of the dryer. You can take a white cloth and run it around the rim of the front and back of the drum and I suspect you will end up with some discoloration on the cloth. I had these felt gaskets replaced, but that is only a temp solution. When the drum is taken out and the old felt gaskets are removed, you can clean the edges of the drum and get a lot of rust/brown off the drum. New gaskets are only a temp fix. I did it about 1 1/2 yr ago, and I think the problem is starting again. Probably time for a new dryer or time to pull the drum and clean it. New drum probably cost prohibitive if you can get one. What a bunch of **** for a 7 1/2 old dryer. Next dryer will have a stainless steel drum. Hope this explanation helps you with your problem.
Mar 29, 2010 | Amana ALG331RAW Gas Dryer
Brown stains in the drum of my whirlpool dryer
Apparently a common problem with 4-5 year old Kenmore and Whirlpool dryers. The paint is rubbed off the back panel by the felt seal attached to the rotating drum. The bare metal gets rusty from the damp clothes. The rust is rubbed off by the felt seal. The entire felt seal will turn brown. The stains are transfered to the clothes. The rust stains can generally be removed by additional cleaning.
I'm going to replace the felt seal on the drum, clean the rust off the back panel and see how long it lasts. Seal w/ adhesive is $30-40.
Some have suggested painting the back panel, but i don't think fresh paint is going to last long. The original paint was probably electrostatically applied and maybe baked on.
Nov 05, 2009 | Dryers
Rusty holes on drum
If you find a good plasticizing epoxy it should work great for this most plastic epoxies can withstand temperatures up to 500 degrees F. I dont see the hot water supply feeding the machine getting any warmer than this. Another option would be to find someone with a plastic fusion and filler welder and just weld the hole shut with a base material.
Follow this easy steps...
Unplug the dryer from the electrical socket to avoid accidental electrocution.
Sand or scrub the rust spots using steel wool or sandpaper. Rust creates pits and these pits need to be smooth, like the rest of the drum areas, to prevent the rust from getting worse and to allow touch-up paint to stick.
Clean the entire inside of the drum to remove all the dust left from sanding/scrubbing. Mild soap and water will work well. Use old rags that can be thrown away.
Let the drum dry completely. You can run your dryer on the fluff dry cycle for a few minutes to dry the drum faster. If you use a heat cycle, the drum will become too hot and you will have to wait while it cools
Apply an appliance paint (see Resources) in the color that most closely matches your drum. Use the applicator that comes with the paint to dab the paint on the rust spots. You may need to add more than one coat, but make sure that you are letting the first coat dry before adding more to avoid drip marks. Allow all coats of paint to dry thoroughly before using the dryer.
Thanks for contacting
Sep 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Do I have a stainless steel drum in my washing machine?
If the drum is unpainted and a magnet is able to stick to it, the drum is steel. If there it is shiny and uncoated, more than likely it is stainless. Checxk web site documentation
Mar 01, 2009 | Washing Machines
Kenmore 80 Series Washer/Dryer
Jan 26, 2009 | Washing Machines
Makes a noise like there are rocks or coins when it spins
If it is thumping... you have a broken spider on the inner stainless steel drum. Major defect with this machine. You'll need to call to get a new washer tub assembly... comes complete with inner stainless steel drum and outer plastic drum already assembled and ready to install. Good luck.!
Jul 01, 2008 | Frigidaire GLTF1670A Front Load Washer
Kenmore 73952 Gas Dryer Logo
374 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
