Kenmore Calypso Washing Machine
Machine cycles normally until it has 6 minutes left, Then after 5 minutes
of being stuck in the spin/ autofluff cycle, an " Ld " ( long drain ) code
is displayed on the LED board. I checked the drain hose, pump for lint
blockage, and the pump suction and discharge hoses. Sears has replaced both electronic control panals, the pump two times, the
u-joint. This machine has had more problems, than I can count.
The machine is 6 years old, we kept on renewing the warranty, but
this time the cost to extend the warranty was more than the machine
is worth. We had another Kenmore washer ( an inexpensive one ) that
lasted 15 years. This "advanced" model, The Calypso is CRAP.
SOURCE: Kenmore 44072 Front Load Washer help
my kenmore washing machine has the timer out of time
Posted on Dec 23, 2007
  • 1028 Answers
SOURCE: Kenmore Elite Washing Machine with Calypso Wash Motion Model # 110.22066102
have you removed bottom panel and cleaned pump..old style pump was held om with clips but the splined shaft in the pump would strip out and never pump properly only solution was replace pump/motor assembly..new style pump had 4 screws in bottom and could be removed and cleaned
Posted on Aug 22, 2008
SOURCE: Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Posted on Nov 11, 2008
SOURCE: Kenmore HE4T Elite F06 problems
I'm not handy but for $30 and an hour of time I fixed my F11 Error code myself.
I took hi-res pics and created a step by step guide to help other folks in this predicament.
http://he4tf11.blogspot.com/
Posted on Jan 15, 2009
samson39
  • 32 Answers
SOURCE: Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Posted on Jul 24, 2009
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Kenmore elite washer
    hi
    unfortunately the programmer is faulty
    Dec 31, 2017 | Kenmore Washing Machines
    Calypso kenmore washing machine faulty spin cycle ''CA'' code
    This code signifies that there may be a problem with the motor, thermal protector or motor controller. Overloading the appliance may cause such an error code. Try using a smaller load. If the code reappears, contact an appliance service company.
    Apr 13, 2010 | Kenmore Washing Machines
    Spin cycle doesn't spin clothes well
    pump stuck with the lint just tille the washer open 5 or 6 screws on the pump clean the lint wrap around the wheel pump it will fix the problem good luck.this machine is a lemon get sue by some other state the company make it already lost the case why they still sell in cali
    Jul 09, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Kenmore HE2 won't finish spin cycle
    you have blockage in you drain plug. to solve this problem you'll have to remove the lower front panel of your machine by removing the 3 (1/4") screws on the vary bottom of the machine. once the panel is removed you'll see a 1 1/2" white PVC drainage plug. turn the inner plug to the left in till open. (WARNING ALL THE WATER IN THE DRUM WILL DRAIN THOUGH THIS PLUG) remove debris likes socks or everything that's there replace the panel and your all set.
    May 28, 2009 | Kenmore HE2 Plus Front Load Washer
    Whirlpool Calypso Cycle Problem
    The FL error code means:
    Flood Condition:
    FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
    With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
    Press STOP/CANCEL to clear the display.
    This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
    There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
    Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#%!^
    Mar 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Plastic in drum
    REMEMBER IN 4- 6 -8 MINUTES IS YOUR DRAIN AND SPIN CYCLE, PLZ INSPECT PUMP,,, AND SUMP THAT WILL RESOLVE YOUR PROBLEM
    Nov 25, 2008 | Kenmore Elite 45986 Front Load Washer
    Whirlpool Calypso - Will not start
    You ever hear of dog years? Well Calypso follows those same guidelines. So your machine is 35 years old. These are the Edsel's of washing machine fame. I had a Calypso for 6 1/2 years. 3 pumps, numerous circuit boards, drive motors, phone calls and arguements with Whirlpool, along with machine downtime. I finally junked it and bought a Whirlpool Duet 9200 HT (get the made in Germany machine). A world of difference in wash quality. Fresh smelling unballed clean clothes. The Calypso was removed from the market and the subject of a class action lawsuit. Just Google it and start reading. Get comfortable first. There's a lot to read.
    Nov 06, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
    Aug 08, 2007 | Kenmore 44072 Front Load Washer
    Washing Machines Logo
    149 people viewed this question
    Top Washing Machines Experts
