Question about Polaroid 3211TLXB 32 in. LCD Television
Dvd stuck in the dvd / tv
We just bought a polaroid tv that has a built in dvd player on the side but the dvd won't come out and we tried to unplug and re plug but it still won't work or play the dvd
  • Treyh180 Aug 21, 2008
    i have the same problem i put in a movie it did not work so i tried to eject it but now its stuck in the dvd player making a buzzing sound as if it was trying to come out!!!!!!!!!!!!!!!!
    Problem Solver:
  • 8 Answers
I had this same problem and fixed it too. It was from a flat torsion spring on the loading mechanism that had moved position. It hits against the chassis of the DVD housing preventing the mechanism from seating the disk on the spindle. Result is a stuck disk and/or constantly running loading motor.
Remove the one black machine screw behind the DVD player. DVD player will slide out of TV with its black plastic trim fascia from bay.
Remove two screws that hold fascia panel, remove fascia and lift off top metal cover.
With CD loading slot facing you, the problem spring (in our situation) was at the left. Also identical spring on the right side too. These are the two torsion springs near the front on sides of chassis. The helical loop on the left should be towards the top. If it shifted to the bottom, it can hit the tab with screw used to secure DVD chassis. When this happens, CD loading mech can't complete loading disk onto the spindle. If spring flips when the CD is on the spindle.... disk can't eject.
I used a pair of tweezers to gently grab the spring and "flip" it upwards by pulling it upwards. Spring will work for mechanism in up or down position, but needs to be up to avoid interence.
Solved my problem and DVD has been great since. If it flips back for some reason, then I will try attaching a small piece of plastic to the side of the chassis to contain spring in upright position only.
Posted on Feb 24, 2009
I can solve your problem. just call this number.0626403255.name.sam
Posted on Apr 05, 2009
Same TV, same problem. This TV is terrible. Anyway, I tried the afore mentioned solution, got no results. So then I hit the back of the DVD player. Hard. That worked. Woohoo! That always works.
Posted on Jun 16, 2008
    Genius:
  • 1,003 Answers
UNPLUG TV HOLD EJECT BUTTON DOWN AND HAVE ANOTHER PERSON PLUG IN TV AS YOU CONTINUE TO HOLD DOWN BUTTON AND TURN ON POWER
Posted on Jan 18, 2008
How to play dvd
If you are using the built-in DVD tray, press TV (in case you have a Cable Set-top box). Then press Input and navigate with the up/down keys to the line labeled DVD. Then press OK. Finally press play on the Polaroid TDA-03211C remote or on the side of the TV. The remote play button is in the center of the row below the row with skip reverse and skip forward buttons.
If you are using a different DVD player, press the input button and then the up/down arrows to get to the input for your DVD player. Then press the DVD button to control the DVD player.
If you are using a universal remote control, then you may need to program it to the TV and the DVD player separately. (Some universal remotes may only support the TV functions of this TV.) Make sure that your universal remote has an input button that works. You may need to try multiple codes for Polaroid TVs.
I hope this helps.
(note: the DVD must be correctly installed so that the printed side (label) is facing the front of the TV. If you do not get a response, try the disc in another DVD player. The DVD player laser tracking can fail without warning. If the disc plays in other units, this may be the problem.)
Mar 02, 2013 | Polaroid TDA-03211C 32 in. LCD HDTV
I have a Polaroid TV/DVD combo. It took the DVD in, won't play it nor will it eject now. How do I get the DVD back?
Tries the tv unplug/replug the tv back for about an hour later for the tv power to reset itself.At this time u will able to eject the DVD disc out.Don't tries to used the tv intergrated DVD player anymore.The tv intergrated DVD player laser head and the spin motor for the dvd disc spinner it is defective now.Buy a portable cheap or a moderate unit of a outer DVD player and hook up to the tv AV input.Play it through the tv input video 1,2,3 u should have a DVD player capatablities again.
Nov 30, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
I need a power cord for a polaroid HD TV 81.5 INCH
Try using the power cord from your PC. NEMA5-15P to IEC C13.
Jul 12, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
My mother-in-law has a Polaroid HDTV woth built-in
I can help you with your Polaroid HDTV.
If the DVD doesn't start when you place it in the player, look for the Play button on the remote control. There may be a TV/DVD switch on the remote that would need to be changed to DVD.
If the manual below doesn't match your TV, please post the model number of your Polaroid HDTV/DVD combo for more specific help.
I hope that helps.
________________________________________
Polaroid FLM-2632 Manual Download
Polaroid FLM-2632 Service Manual Download
Apr 04, 2010 | Polaroid FLM-2632 Television
There is a DVD stuck in the built in DVD player in
try unpluging set while tv is on and plug it back in it should come out
Feb 03, 2010 | LG Televison & Video
I have a Polaroid 19 inch TV/DVD Combo. I put a DVD in the other day and now it's stuck. It keeps showing a blue screen and says ''NO SIGNAL''. Everything is plugged in . I have unplugged and plugged and...
Go to YouTube.. search how to get a stuck DVD out...
I would do this first then see if everything is working again..Also some DVD's that are boot leg don't work to good...not saying you have one but the paper label sometimes is thicker and they get stuck
Nov 11, 2017 | Polaroid Televison & Video
DVD stuck in DVD player, TV/DVD player combo
I have had this before, get yourself a butter knife, slide it gently into the space, and try to maneurver the dvd back a little, and while you have the butter knife in, push your open/close button, hope this works for you it did for me!
Mar 21, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Have a Polaroid TDA-03211C tv with dvd player. Won't play DVDs
As long as you know a disc is not stuck inside I recommend taking it to your local svc center to be looked at.
Feb 28, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid 3211TLXB 32 in. LCD Television Logo
546 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
