Question about Yamaha RX-V2700 Receiver
Yamaha RX-V2700 skipping when playing a DVD on Toshiba D-R400
I currently have a 1 year old RX-V2700, and just purchased a Toshiba D-R400 DVD-Recorder. I connected the two using an HDMI cable and when watching a DVD, the receiver starts to skip after ten minutes. There is no skipping otherwise.
My current set-up is the RX-V2700 Yamaha Receiver, Toshiba D-R400, Direct TV HD Box (no DVR). The TV is a Sony Bravia 46" XBR3. The 5 speaker inwall are Polk Audio. All components that can use HDMI are using HDMI. I control everything with an 890 Harmony remote.
Please advise.
  • Anonymous Jan 31, 2008
    screen flickers after watching for 1hour through hdmi connected from sony dvd player to yamaha rx v2700 receiver and then to sony 40 inch lcd tv
  • demidemelee Apr 16, 2008
    My problem is, when connecting comcast HDVR cable box to yamaha 2700 receiver and receiver to Samsung HDTV, I only get the image flicking in and out, I can hear the sound and that's about it. The cables are good, they work well when connected directly from Comcast HDVR to HDTV.
    Something in the passthru. Help. Thanks
I have no sound when trying to watch a dvd through my rxv2700. the dvd player is an insigna blue rya player. It worked at first but not now
Posted on Jun 20, 2009
Direct connect works great, pass thru white noise, etc when using more than 10ft of hdmi wire
found 3ft connect will work both cases
the rxv2700 has a bag full of problems, only sound system is good
set was released to early, best bet dump it, why live with this pain
Posted on Apr 27, 2008
    Genius:
  • 1,175 Answers
Sounds like a poor grounding issue between the units OR maybe they're not as compatible as the Mfg's say.
Could be a bad HDMI cable also. Most are made in the land of Nanking
Posted on Feb 24, 2008
Yamaha rx-v2700 digital A/V receiver will not read 3trb external hard drive when it is formatted on nts and also tried with fat32 format and does not read mp3 files. when plugged into usb port the reciever...
Hi. Is the HDD drawing too much power from the receiver (does it have its own power supply)?
You could look at the troubleshooting guide in the user manual here:
Yamaha RX V2700
Feb 14, 2018 | Yamaha RX-V2700 Receiver
Connecting a YAMAHA RX-V2700 receiver to my TV and cable box
why not you use a normal AV cable
instead of hdmi cable
May 22, 2008 | Yamaha RX-V2700 Receiver
I have a yamaha V2700 and its been working fine for a number of years, and recent I change equipment around and now the AMP menu is frozen. You make it pop up and then you can't arrow up and down but you...
You KNOW that it followed a change you made, so retrace your steps. UNdo everything and see if it becomes operational again. Then make changes one step at a time to see where the failure appears.
Apr 09, 2010 | Yamaha RX-V2700 Receiver
What kind of up-grades are for the yamaha
There are no "upgrades" however, if your having problems with HDMI switching or "not working" You can send it to Yamaha and they will replace the HDMI board at n/c. It's still version 1.2 and the current version is 1.3a soon to be 1.4. What is it that you need to have upgraded? Post a comment with what it is you would like your receiver to do and I can help you further. I work with Yamaha daily
Nov 25, 2009 | Yamaha RX-V2700 Receiver
Looking for codes for samsung BD-P1600 blue ray for yamaha remote
Samung's code for DVD to Yamaha remote is "0600" if that does not work, your Yamaha remote is a "Learning" remote and can learn your DVD's remote button by button. If you don't have your Yamaha manual, here it is.
http://www.yamaha.com/yamahavgn/Documents/YEC/AV_Receivers/Manual/RX-V2700_U.pdf Hope this helps, if you still have an issue, post a comment and I can help you some more.
Aug 05, 2009 | Yamaha RX-V2700 Receiver
Yamaha RX-V2700 no sound from any speaker outputs
Make sure that you have the correct input signal selected.
Also, check if the sound is not muted.
If you have a multi-room speaker switch, make sure it is set correctly to main speakers.
Apr 28, 2009 | Yamaha RX-V2700 Receiver
Yamaha RX-V2700
Have you tried to see if there is a fuse connection on the back of your receiver?
Sep 20, 2008 | Yamaha RX-V2700 Receiver
Getting to work your pc music files through the usb connection
how should i connect my yamaha rx-v2700 to my desktop pc and which software i should install on my pc and where to download this software
Feb 12, 2008 | Yamaha RX-V2700 Receiver
Problem with Dolby Digital mode
If it is a new DVD that may be a problem, as signal changes may be frustrating this old machine... but it is likely the cabling from the DVD player to the reciever. Are you on the right channels/settings? is the optical cable and digital cable recieving digital output from your DVD player? Try changing those settings and you should be in good shape Thanks! good luck!
Jul 22, 2007 | Yamaha RX-V3300 Receiver
Yamaha RX-V2700 Receiver Logo
327 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
