Question about Toshiba Satellite A15-S157 Notebook
Shut-Down Hi guys, well I tried replacing the heat sink, and the cooling tube and fan seeming to be good...I finally took the computer apart and looked at the motherboard and capacitors and all looked ok...It looks like I might have to replace the motherboard...in which is around $500+.Well if anyone has any other suggestions to try out Please let me know...to those who gave me there solutions to try...I really appreciate the help...Thanks, Michael
  • Michael Gallegos
    Michael Gallegos Jan 21, 2008
    Thanks for the help. Unfortunetly I'm not too experienced in the electronic department..I did remove the board and looked at it and didn't seem to find any abnormal colors or leakage..I really can't afford to replace the board at this time...Your help was a great help and once again thanks...Michael
    Scholar:
  • 57 Answers
Thermal runway occurs when a semiconductor component heats up thereby allowing more current to flow through it, leading to even more heat, which quickly builts up. It seems that the best place to focus your attention is the switched mode power supply unit (the power switch tends to be right on it), since it is there that current limiters and over-voltage protection circuits will be found. Clearly, these protective measures are kicking in when a fault is detected. Check for any surface mounted transistors on this module that are getting unduly hot; sometimes even a largish electrolytic capacitor will cause such a power fault, since they tend to dry out with age and heavy usage. If you can get your hands on a similar module try swapping it in. If not, then try replacing the SMPS board components that are heating up. Experience in electronics definitely needed.
Posted on Jan 18, 2008
Hp pavavillion dv6 overheating issue
Following are the reasons for overheating, just take care of these things::
Stop Overclocking your CPU
Make sure your Heat Sink is placed properly above the processor
Clean the Processor fan, Heat Sink and other peripherals
Use High Speed fans
Use CPU Heat Sink Paste in the processor
Use Additional Cooling Units
Shut down your computer at least two hour a day
Finally i will suggest you to get system utility program like PC Fresher to maintain your system performance
Sep 15, 2013 | HP 417136-001 PAVILLION DV8000 MOTHERBOARD
Tip
Rebuild the fan when it stops working!
Caframo advertises a feature in this fan which will shut the fan down if it gets too hot, and then start it again when the fan cools down. In fact, this feature is heat sink compound between the two halves of the body (which are each heat sinks) and the power plate between them. That compound breaks down over time and use. If the fan stops working, take it apart and scrape that compound off (it was silver on my fan), and replace the compound with a thin coat of CPU heat sink compound from an electronics store. Put the fan back together and let the compound set up over night before placing the fan back on your stove. Should work like new!
on Nov 01, 2009 | Cfm 802 Ecofan Table
Msi computer turns of while playing
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Oct 28, 2012 | MSI GX630-028US Notebook
My pc unexpectedly shut down.i feel problem seems to be motherboard display.how can i repair motherboard display problem
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Aug 20, 2011 | MSI 945GCM5 Motherboard
Hi yah i have been experiencing my computer to shut down regurlary at random times without any warnings could you maybe help
Aug 14, 2011 | DFI LANPARTY UT NF590 SLI-M2R/G...
Sony Vaio has started shutting down unexpectedly. Restart in safe mode and run event log with no results returned. Shutdown and restart. Starts normally but then shuts down within 2 min. Repeat process,...
Your pc CPU FAN is not working, you need open it and clean fan,, and under fan, on CPU there is termo cream, don't frgot about it, you need clean it and put new termocream. it is nessasary for cool CPU, that Cpu can not be warm.
Jun 11, 2011 | Sony VAIO Laptop
My computer was making loud noises, then shut down and won't restart. Could it be the fan went out?
It could be the cooling fan to the power supply but it sounds like that went completely out and blew the Zenor Diode or something in the power supply. You can test the voltages coming off the power supply to make sure. If that is what happened you are better off simply replacing it. You can get them at Best Buy for about $40 and it is a simple 4 screws to remove in order to trade them out. Make sure you have the correct connectors for the motherboard. If the Power supply is good then you lost the CPU fan. If the CPU fan went out and the computer will no longer start up you may have cooked the CPU. Again, this is something you can replace fairly easily. The fan should run about $12 to $20 depending on what model you get and what type of CPU it has to mount to. The hard part will be the CPU itself. If it has overheated to the point of burning a connection inside the CPU will have to be replaced and while it should not be soldered on the board the heat sink will be very difficult to get off and when you put the new heat sink on to the old CPU or a new one you will need heat sink compound. Runs about $1 a tube. If the CPU just overheated and shut down the PC should restart once it has cooled if nothing else till the CPU heats back up. Usually takes a couple of minutes but not long. This is actually good news if this is what is happening as it means the CPU is most likely operational and that is the expensive part to repair in an over heat situation. The problem does sound like a blown power supply though. If you have to replace the heat sink and CPU fan once you get the old stuff off and as much of the old heat sink compound off as possible make sure you apply new compound to the CPU. You do this by applying a small amount to the center of the CPU and pressing the heat sink into place, this should spread the compound evenly and thinly over the CPU area and form a bond between the heat sink and the CPU to transfer heat between them. The fan normally attaches to the heat sink and locks down on the CPU. Connect the Fan power wires into one of the power supply sockets and everything should come on when you power on the computer. While you have the case open you should take the opportunity to use canned air to blow the dust out of the case and air circulation holes. Heat and Dust are not your friends in computers. Good luck with your repair.
Nov 11, 2010 | Computers & Internet
I've had a bad dust problem and my cpu fan began making a loud whirring noise and finally the computer shut down altogether. Took the cover off totally cleaned out the dust and turned the power back on....
If the computer detects overheating or fan failure it will shut down automatically. If you replace the fan you should be fine. Remove your old fan and try to get one that connects the same way, some of them connect directly to the heat sink, others to the motherboard.
Apr 16, 2009 | Sony CPU FAN CPU Fan
Shut down
check coooling fan too. or replace the heat sink.
the problem that i see in your case is overheating.
Jan 15, 2008 | Toshiba Satellite A15-S157 Notebook
Processor overheating
Hi have you cleaned the heatsink? Also replace the paste on the CPU, also you could try installing an extra fan on the case to increase air flow. Also check that your RAM is seated properly and any other chip and card on your board is firmly plugged in. If all this fails replace your CPU. Regards mistyman
Sep 10, 2007 | Intel Pentium 4, 2.8 GHz (bx80546pg2800e)...
Toshiba Satellite A15-S157 Notebook Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
