Question about Acer Aspire 3680 Laptop
Feed back from speaker
There is a humming sound when the built in mic is turned on. What can be done to solve this problem. The laptop is only a year old.
Regards, John
  • 689 Answers
Obviously it will make feedback. Microphone should be put on mute. Putting microphone on mute will not stop it working for recording sound or talking on voice chat. All you need to do is double click on speaker icon on system tray check the mute box of the Mic channel.
Good Luck
Posted on Jan 18, 2008
6ya staff
SOURCE:
Hum noise on laptop
May be feed back. Check mic options and mute. Also use a power surge protector.
Sep 25, 2012 | Toshiba Satellite Computers & Internet
No sound
You may have a laptop with a built in mic or headphones with built in mic and webcam with built in mic
You need to set your webcam mic as default
Vista
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to your chat program
May 23, 2010 | Logitech QuickCam Deluxe for Notebooks
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
Speakers sound hollow. mic in sounds like squirrel
i think you're driver did not do the right setting for you. try searching drivers from this site http://www.rudytarigan.com/laptop/toshiba-satellite-l310-drivers.htm or search realtex HD manager. They will do all the work for you
Aug 02, 2009 | Toshiba Satellite A355-S6935 Laptop
Acer aspire 5735 mic problem
Go to control panel and sound devices and unmute the mic under record options. To avoid feed back use headphones or mute the mic in the play back option. Audacity is a good open source application to use to record on your PC.
Jul 25, 2009 | Acer Aspire 5735 Notebook
Lenovo G3000 38Q - built-in mic not working under Windows XP but built=in speakers are working fine. How do i solve
I believe the problem is that your mic isn't working properly so follow these instructions:
1: Go to control panel and click on "sound"
2: When the sound window opens click on "recording" you should find the built in mic there in the dialog.
3: Click on your built in mic and click on configure.
4: Then, click on "levels" and set the microphone level to 50 and the microphone boost to +20.0dB
If that doesn't work try doing a system restore.Or you could try restoring the defaults on the sound pref.
Jun 26, 2009 | Lenovo Computers & Internet
Vaio laptop sound problem
actually that problem should be solve by you checking whether your mic is either faulty or not connected well at the back of your system and not only that and post the understanding message to me well so i can deliver the right solution thanks .
Aug 31, 2008 | Sony VAIO VGN-S460 Notebook
Headphone and mic
my presario c700 has a built in mic try just connecting headphones in and using the built i mic
Jul 23, 2008 | Compaq Presario 700 470024-192 Notebook
Audio feedis crossing with my speaker feed with and without the microphone plugged in.
Your mic still picks up sound when it's unplugged ?
As far as the other prob goes that sounds like howl round ( feedback ), mute the mic when not talking through it or get a mic with a cardioid polar response pattern ( just ask for a cardioid mic, can get a hypercardioid or supercardioid too but a cardioid would be best for your application, point the mic right at your speaking position with the back of the mic pointing at the speakers wich ideally should be behind the mic, this will help cancel out their sound, puting a limiter on the mic and setting it where it only starts picking up sound when you talk directly into it will help too, but the sure fire way to solve the prob is to mute the mic when not speaking into it. What you definitely don't want is an omnidirectional mic, for what you are using a mic for.
Jun 10, 2008 | Logitech Labtech Verse 524 Microphone
Sound feedback
Are those add-on speakers, not clear on that? Feedback is almost always a problem involving speakers and microphone being to close together or mic being to hightly modulated. It is possible that power lines being to close could induce a hum of varying severity.
Dec 21, 2007 | Philips SPC 900NC Webcam
Acer Aspire 3680 Laptop Logo
112 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
