Question about Antec Phantom 500 (PHANTOM500) 500-Watt Power Supply
(I have Antec Phantom 500) when I turn on my computer it turns on for about a split second and it goes off ..
I turned my computer off last night and when I woke up in the morning I got this problem. when I turn on my computer it turns on for about a split second and the it turns off.
Anyone might know where the damage is, i.e. which part might be the problem.
  • 1 more comment
  • JustinK Jan 19, 2008
    No I don't see anything on the screen, the system doesn't even beep.
    I installed the power supply to another system and it happened exactly the same thing.
    So this means that the power supply must be the problem.
  • JustinK Jan 20, 2008
    Now this is what happened, I opened the power supply and took it out of the whole case, I started touching everything with the screw driver then I left it open for about a day after that I connected it again just to give it one last try and it WORKED! I used my computer up until 2am. However at 10am I woke up, turned it on and the same thing happened again....
    I'm thinking that probably the capacitor is not fully discharging or something like that, so when I touched it with the screw driver I discharged it.
    Also I'd like to say this see if it might have anything to do with it, I have my Case, Monitor and Speakers 5.1 connected to one connector with 3 plugins so when I turn off the computer before I sleep I take out the main plug from the wall, now when I put the main plug again when I want to turn on the computer the speakers make a sound like BOOM so not sure this might have anything to do with causing the problem.
    Thanks
  • yinleifu May 03, 2009
    Exactly the same has started to happen to me as well. I too have an Antec Phantom 500. The light on the nobo comes on okay but when I start the system the fans start turning for about half a second and then everything goes dead. After this I must yank the AC cable out until the light on the mobo goes out and I can then repeat the whole process.
    /Michael
    Master:
  • 788 Answers
Most likely the power supply but it could be the motherboard.
Do you see anything on the screen when it comes on?
Posted on Jan 18, 2008
  • Dean Joly
    Dean Joly Jan 19, 2008
    Yes it would seem so. Get a replacement rated for at least the same amount of wattage or more. Not too pricey. Make sure it seems like good quality. You can tell if a power supply is decent by it's heft, if it feels heavy and solid then it's probably a good one.
Computer will not start. No fans, hard drive or monitor motion at all. But, a green light on my motherboard blinks.
Out university has hhad a failure rate on antec 450w psu of 40-50% over 4 years (total number of pc:s with this psu was approx. 300). Check your motherboard with a known-to-be-good power supply.
Feb 17, 2011 | Antec Phantom 500 500W ATX Power Supply...
Cant hear audio from my antec asus a8n sli premium computer
Try uninstalling the sound card from the device manager and then restarting the computer.
Let me know if this solves your problem.
Dec 30, 2009 | Antec Phantom 500 (PHANTOM500) 500-Watt...
My monitor showes for a split second then goes black
First, can you attach another monitor to the computer to check to see if it works?
If it does, then your monitor is going bad. Possibly the power supply.
If a second monitor acts the same way, then it's your video card.
Dec 10, 2009 | Computers & Internet
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Can not turn radio up and down
i believed you chose the wrong product, we cant help you.
Apr 25, 2008 | Antec Phantom 500 (PHANTOM500) 500-Watt...
Antec Phantom 500 burned out
u can buy a ps tester on ebay to make sure all rails are ok 5 bucks for it easy to use great tool to have dont have to be bunrt to have bad rail i seen it
Jan 09, 2008 | Antec Phantom 500 (PHANTOM500) 500-Watt...
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Antec Phantom 500 (PHANTOM500) 500-Watt Power Supply Logo
422 people viewed this question
Top Antec Computers & Internet Experts
Steven Wander
Steven Wander
Dimitar Todorov
Wahs Team
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
