Sony DVP-NC675P Multi-disc DVD Player
Problem for Sony DVP-NC675P Multi-disc DVD Player
NOT READING DISC
By SHERDOBERDO on Jan 18, 2008
ALL OF A SUDDEN MY DVD PLAYER DOES NOT READ ANY DISC. IT JUST COMPLETELY PASSES IT LIKE ONE IS NOT IN THERE, "NO DISC" AND IM NOT SURE WHAT THE PROBLEM IS. IS THIS ELECTRONIC FINISHED OR IS IT POSSIBLE TO GET THIS FIXED FOR A REASONABLE PRICE (IE NO MORE THAN I PAID)? IF YOU CAN HELP ME, i WILL GREATLY APPRECIATE IT
MS HARRIS
Same Problem
Feb 19, 2009
-   I have the same problem as mentioned above with the Sony DVP-NC675p. Took the cover off and noticed the spinner motor that spins the dvd was sticking because I gave the centering wheel on top a little spin and the player started working fine. I would like to know if the motor is replaceable at a reasonable price or can I just give it a squirt of lube oil.
DM-   dmitch063
Jan 01, 2009
-   my sony DVP-NC675P has worked fine for a couple of years now and suddenly stopped recognizing the disc..first reading "cannot".  So I purchased a cleaning disk and inserted. It waits about 2 to 3 minutes after the disc is in place on position 1, then advances to the empty 2, then 3, then 4, then 5, then back to 1 where the cleaning disc is located and displays "no disc" and on the screen displays "insert disc".  I have never cleaned it, so believe  this is the likely cause but was surprised when the cleaning disk had no affect.  I would be grateful if someone can share what to do...take it to service?  Not sure what that might cost? -   Guest
Solution #1
posted on Jan 18, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Don't panic, friend. Likely you've had the unit awhile. Get yourself a CD lens cleaner from your nearest music or Hi-Fi store. Run it a couple of times. That should solve your problem.
Popular Solutions for Sony DVP-NC675P Multi-disc DVD
Questions and Unsolved Problems for Sony DVP-NC675P Multi-disc DVD
Do you recommend Sony DVP-NC675P Multi-disc DVD Player?
Answer
Answer
Mi grabador de DVD LG con disco duro no se Puede ni reproducir ni grabar un DVD, solo puedo Utilizar... (More)
Answer
Every time I turn on tv Starts correctly (AX) then automaticly changes to (D-IN 1) cutting off... (More)
Answer
how do you charge a RB li 15 battery pack for a mintek md-5860 portable dvd player
Answer
my dvd player will not power up, and the light in front is amber. Not green or red.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Players Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
