Question about Onkyo TX-SR502 Receiver
No sound when first turned on.
Unit comes on but there is no sound for 2-5 minutes after turning it on when it is cold. After warm up it is fine.
  • Knightro2 Mar 03, 2008
    I just posted in a different thread but I just found this one and I'm having the EXACT same issue. It just started yesterday after 3+ years of flawless operation. Everything looks fine on the display when I turn it on and I can even hear it click twice like it normally does. But no sound. Then after about 5 minutes it will just start working. Any ideas?
  • _dkor_ Mar 27, 2009
    Basic same problem here except I'm getting severe distortion after warm-up. Powering down, then up will remedy the problem though.
    Original post:
    "I'm getting no output from this unit on power up (from all sources.)
    After cycling through a "test tone", the amp will output a distorted
    white noise signal on 'some' channels. After the "test", the amp will
    either work properly or produce severely distorted sound. This can be
    "fixed" by powering down, then back on. Until recently, amp has worked
    without issue for at least three years with only medium usage and very
    little use for about a year.
    Thanks,
    Dave
  • 88 Answers
I have an amplifier ONKIO too and my generation is older than yours but i'm the same probleme and it's normal if you use this amplifier to your speakers. the internal switch must be heat to give a normal sound without distorsion. it's the principal problem of the onkio amplifier but after the quality of thr sound is great
so take the time and be patient now you know you have to start on your amplifier 5mn before use :)
Posted on Mar 31, 2008
Renault scenic problems 2002 53 plate 1.6 takes about 3-4 minutes to start when cold
yea sounds like a bad starter, in the cold it will not make complete contact when soleniod triggered.. this is due to worn contacts inside, when warm it makes a better contact, if you replace the starter this will solve your problem, also have the battery and alternator tested
Dec 01, 2013 | Cars & Trucks
Heating unit blows warm air then turns to cold air
it sounds like unit could be kicking out the low pressure switch or if it is a electric furnace it could be the sequincers
Jan 11, 2010 | Ruud UBHC Air Conditioner
When powering from full shut-down, takes about 30
whenever you want to turn it off, put it on hibernate.
Jan 02, 2010 | Toshiba Satellite M35X-S161 Notebook
Sharp 10000 BTU 38db portable air conditioner blows cold air for 2 minutes then blows warm air for 5 minutes then turns off for 20 minutes then repeats this process. How can I fix this problem to blowing...
sounds like the unit has a low charge and is cutting out on a low press safety. This is more then likey not something you can fit yourself most of this units are not really serviceable with out cutting the lines open and adding a valve. If the unit is still somewhat new you can try for a warranty repair, if not you are better off to replace it.
Aug 30, 2009 | Heating & Cooling
Hoover windtunnel..runs fine for 5 minutes then stops?
OK - sounds like your machine has a blockage somewhere. Follow manufacturer's instructions for clearing blockages and all should be well. If you no longer have the manual, you can download it from the Hoover website.
Mar 08, 2009 | Hoover U6630-900 WindTunnel Bagless...
No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Jun 09, 2008 | Frigidaire FAH085N1T Air Conditioner
Sound goes off after 5 minutes
hi there, yes it can be fixed, hitting the unit means that you have a cold solder on the board. the sound is in the amplifier section, check some connection at the speakers and amplifier, a cleanning and a reheat of cold solder to the baord is required. ty
Dec 14, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Starting system cold, no sound for 2-3 minutes
Its not worth having it looked at. $100.00 for a new 400.00 unit? My unit is doing the same thing. Turn it on and 2 to 5 minutes later it may come on. Change to video 3 4 5 etc it stop again. Only works with a cold start. Something in the unit has failed and is heat related. My original Kenwood 20/20 recevier still works. Must be 40 years old. New products just last 5 to ten years max if your lucky.
Dec 17, 2006 | Kenwood VR-6070 Receiver
Onkyo TX-SR502 Receiver Logo
371 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
