Question about Ramp Networks WebRamp M3 Router
I can't reset my webramp m3
Ho do i reset my Webramp coz i can't login and the reset button is not working
0 characters
1 Points
I have lost my login & password
Did you change it when you first set it up? If not the default login information will still work.
If not. Reset the router by holding in the reset button for about 5 seconds then login with the default/factory login and password
Nov 19, 2013 | Routers
I don't know how to hook it up?
A PDF manual here---->LINK.
Pleas post and thumb back!
Oct 04, 2010 | Ramp Networks WebRamp 315i (385) Router
Which mobel router MC68EN360EM25C
I would be searching the Microsoft Knowledge Base for this answer. But 1st, I would look on the Motorola website for the answer.
NOTE: If the Router is physically connected to the Server (PC), via an Ethernet cable and you want to set it up, then
1. Check the manual for the IP No. of the Router (i,e., and then type into your Browsers navigation field (http://).
1. Search Motorola's website for the IP No. for the Router model :
1.1 Navigate to
1.2 Select where you want to go, for Consumers OR for Business
1.3 Click Support.
1.4 Click the Get Product Manuals link, from the Business Support section.
1.5 Type the Product description into the Search field. Press <Go>.
1.6 Download the product Manual and open it.
1.7 Find the area in the Manual where it tells you the IP No. of the Modem (to access the Modems Settings).
2. Then type it into your Browsers navigation field (http://).
This connects you to the Setup / Installation menu of the Modem Router itself and enables you to configure it's settings. Generally, you are able to access help from within this area.
I hope this helps. Regards,
Feb 09, 2010 | Motorola Routers
I formated my computer and my wirless network wont work coz i dont kno the wpa key and i cant acess the settings wenever i go on router login itsays page cannot be displayed i have tryed reseting the...
If you did not have a key try:
(the default wpa login password)
This may work for you if the first did not work...
Type this in the address bar exactly:
If the login screen pops up
login with: admin
Type in your password
normally: pass
Goto the tab "wan" and replace your current security key.
I hope this helps, best of luck.
Dec 30, 2009 | NetGear WGR614 Wireless Router
Security code problem
reset the router by pressing and holding the reset button down for 10 seconds. Then you just have to enter in the default login details.
For this particular model:
Login: Administrator
(leave password blank)
Dec 16, 2009 | Belkin (F5D7230-4) Router (587009)
I want to make my house wireless compatable
Your wireless router should reach a max of 300 feet. Obviously, there is minimum distance as you are finding out.
You may want to try another wireless router in place of the one you are using.
You can put another device in the attic, but who is to say you will have any better success.
Things for you to consider: Wireless runs at 10, wire runs at 100 or 1000. Wire is secure, not subject to hacking.
If you put a wireless router in the attic, you will still have to run a wire from that device to your www connection.
I hope I have helped you with your problem. Post concerns or comments to this question if required
thanks for using
please vote
Dec 15, 2009 | Ramp Networks WebRamp 361i (411) Router
Unable to login on the configuration page
If you have forgotten the username and password you can pres in the little reset button on the back of the device. Pressing the reset button will reset the device to the manufacturer settings.
Jun 26, 2009 | D-Link DI-524 High Speed 2.4GHz (802.11g)...
Belkin wireless router f5d6230-3 login error.
Because default password is not working.... Please Re-set your router in order to re configure it. Press the re set button for 1 min (tiny hole at the bottom)
Hope this info hrlps
Mar 21, 2009 | Belkin (F5D6230-3) Wireless Router
Hooking up a router is often more that just hooking up cables. Some internet service providers ISP's (phone/cable/internet companies) have requirements to be configured into the router to allow for communication with their networks. Unless you are sure you understand the ISP's requirements perhaps you could provide a link to the ISP's support website or his name. Confirming the manufacturer and model of the router would be good too just in case the one in the heading of this message in incorrect. If you provide the required information in a comment to this message I will attempt to provide steps to hook up your router.
Generally starting with either a cable or a phone wire out of a phone jack a connection is made to a modem (often supplied by the ISP) the modem is generally connected with an ethernet cable to the wan side of a router and the router is connected from one of 4 lan ports with an ethernet cable to a computer's network adapter. There are variations on this cabling that substitute USB cables or Wireless communications.
Dec 20, 2007 | Ramp Networks WebRamp 700s Router
Network between two remote location within City limits
well...first problem is you're going to have big network problems with both sites on the same network/subnet. Based on what you typed above, you will not be able to route packets between the offices since the router won't know which way to go...they must be different networks/subnets...e.g. You have quite a question there...I think you need to have a consultant talk with you over the phone at the minimum. If you can't find one locally you're welcome to work with us. Good luck
Sep 09, 2007 | Routers
Ramp Networks WebRamp M3 Router Logo
64 people viewed this question
Top Ramp Networks Routers Experts
 C. Dante
C. Dante
Are you a Ramp Networks Router Expert? Answer questions, earn points and help others
