Question about Goodman GMS90703BXA Heater
Where does the Oxygen for combustion come from- Indoor or outdoor?
Is there a separate feeder tube that feeds oxygen from outside for combustion or does the speace heater take indoor oxygen for conbustion?
I live in an apartment in Buffalo and I think I got a Goodman natural gas heater with model number U-18L.
I've been having a little shortness of breath that is concerning me. I would appreciate your answer.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 112 Answers
Where does the Oxygen for combustion come from- In - condensing_furnace_diagram.png
Gas heater normally get air for combustion from the outside as seen in this diagram.
Hope this helps...and hope you feel better soon!
Posted on Jan 18, 2008
I live in the south the temperature has been below 20 past week my heat pump will not get above 67 no matter what i place temperature on is something wrong with the unit
Nothing is wrong with unit ,that's how heat pump work ,you should also have a 2 stage heat which most likely electric heat so when heat pump cannot keep up with temperature the electric heat should kick in and heat up the space
Jan 06, 2018 | Heating & Cooling
My furnace is putting out a fuel smell and my filter is black what could be wrong
If the black is soot and you have a odd smell then it may need a service .
Jan 19, 2017 | Heating & Cooling
Is the monitor 422 heater considered a direct vent wall heater
Yes, the Monitor 422 heater is direct vent type.
You must install the supplied double-walled vent tube between the heater and outdoors. Failure to properly install the vent tube will quickly deplete oxygen from the space it is operating in. That is a potentially deadly situation.
The pipe is special. The inner pipe is for hot exhaust gasses to be sent outside and the outer walled pipe is for fresh combustion air to be brought into the heater. This set up is why the heater does not create drafts in the home.
Apr 17, 2015 | Heating & Cooling
Raypak pool heater model 406A fault code rollut sw open
you had a flame roll out. thermal fuse is blown. you can buy one for about 10 bucks. then you need to clean the burners and inspect the heat exchanger and venting
Aug 17, 2014 | Raypak 406A Digital ASME Natural Gas IID...
Error code 14
This is the latest I have. recommend calling Rheem customer service. They are very good
14 Overheat Wrap Fault
Ensure high fire and low fire manifold pressure are correct.
Check gas type of unit and ensure it matches gas type being used.
Check heat exchanger for cracks and/or separations.
Ohm out safety circuit.
Check for improper conversion of product.
Check for restrictions in air flow around unit and vent terminal.
Check for a foreign materials in combustion chamber and/or exhaust piping.
Jul 14, 2014 | Rheem RTG-84DVP Indoor Propane Tankless...
My rinai gas heater is not reallly lighting up though gas flow seems alright
Gas also requires oxygen to burn, perhaps there is an issue in an air feeder or mixing valve some where in your piping or if there is an inlet for air ensure that it is not obstructed. Using any combustion device in a confined space can be problematic for health reasons and the combustion process due to a finite oxygen supply. I hope this helps your investigation.
Apr 17, 2014 | Heating & Cooling
My 606 reliance gas water heater run for 5min and pilot goes out
If the pilot will light and stay lit, then ECO is not tripped, and thermocouple is probably good.
If ECO is tripped, then pilot will have no gas.
Usually if thermocouple is bad or installed incorrectly, the pilot goes out immediately after releasing the pilot knob during lighting.
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
First thing is to clean water heater air intake and get more fresh air to the water heater and see if that solves problem. Combustion of hydrocarbon requires oxygen that must be pulled into the water heater from surrounding rooms. If water heater is closed off, or located in hot attic that is not correctly vented, or house is tightly sealed, or air intake is clogged, then there is not enough oxygen to support combustion.
Next thing to check is color and size of pilot flame.
If color of flame is NOT clear blue, or if flame is weak, then that says the pilot orifice and burner tubes and burner should be removed and cleaned, along with cleaning combustion chamber.
Additional suspects include combination of things, including: , bad gas control valve, low gas pressure, air in gas line, water dripping down vent and putting out pilot, reverse air flow or backdraft down the vent that blows out pilot, damaged burner parts because of exposure to trace chemicals such as bleach and wax.
Open following link to see various images and read resources.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 30, 2011 | Water Heaters
Pilot light will not stay light
1) Open following link for how-to resources, illustrations, and service manuals for some brands of heater.
2) Many things can cause pilot problems, including bad thermocouple, air in gas line, low gas pressure, negative pressure in house, bad venting, very hot attic, lack of combustion air, dirty combustion parts and dirty pilot tube, bad gas control, reversed polarity on electrical outlet.
3) If pilot flame is clear blue and strong, then next step is check that thermocouple sits in the flame, and then change thermocouple. This is start point. Following step would be reading service manual for exact troubleshoot and testing steps.
4) If pilot flame is yellow-or-orange or weak, then clean dirty combustion parts including pilot tube and air intake. Might want to change thermocouple while combustion parts are removed for cleaning.
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
Pilot light will not stay lit on GE 40 gal. gas water heater tank
You have tank-type gas water heater:
Gas water heaters need working thermocouple, adequate incoming fresh combustion air with no trace amounts of chemical, open vent to outside that drafts poison combustion product upward, clean burner tubes and combustion parts, correct gas pressure with no air in line, working gas control valve thermostat, no lockout condition such as tripped ECO caused by runaway heating and dirty combustion parts, and no lockout condition such as exposure to flammable vapors.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
Jul 30, 2011 | General Electric Water Heaters
Opened pool. Rheem heater has the service light blinking
rollout switch is open, and sns is a sensor failure. replace rollout switch, clean out vents, inspect heat exchanger. water sensor senses too cold or too hot water
May 28, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Goodman GMS90703BXA Heater Logo
60 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
