Control panel lights ALL flashing on hotpoint aquarius washing ma
I have a hotpoint aquarius washing machine. when i turn on the machine i get all the lights on the control panel flashing rapidly for about 20 seconds. i'm not sure if its safe to use or how to fix. any help gratefully appriciated.
Hotpoint / indesit wont give you any technical support dump the machine and get a refurbished Miele you wont be worse offHotpoint / indesit wont give you any technical support dump the machine and get a refurbished Miele you wont be worse off
You can't post conmments that contain an email address.
Re: control panel lights ALL flashing on hotpoint...
My lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
FLASHING LIGHTS 2,3,4 PLUS POWER...
TAKE THE TOP OFF, CHECK THE CONNECTOR ON THE SUPPRESSOR LOCATED TOP RIGHT OR WHERE THE MAINS RUNS IN. IT COULD LOOK BURN LIKE MINE WAS.
CLEAN CONNECTORS AND REPLACE SUPPRESSOR..
Have you lost complete control of your washing machine? ... If your PCB assembly (printed circuit board) is faulty then replace today for an efficient and effective ...
8 Jun 2010 - Replacing any of the front panel controls on a washing machine is ... how to replace any of the knobs, buttons, printed circuit boards that sit ...
14 Nov 2013 - Watch Josh explain how to diagnose washing machine control and program problems. ... If you then suspect that the problem still lies in the circuit board ... to test the board and you'll actually just need to replace it altogether.
31 Oct 2009 - 15 posts - 11 authors
hotpoint aquarius wf530 washing machine flash like Christmas tree when ... After reading this forum I took the PCB board out and the C17 ...
19 Mar 2011 - 14 posts - 9 authors
Just took the board out of the washing machine to check the c17 cap ... was gonna cost £150 just for a replacement board without fitting.
This is the Mark 6 board fitted to late Hotpoint washing machines. The module will be programmed to your model number - ready to fit. Typical models are WF550P WF560G .... Hotpoint Arcadia PCB Modules. SKU: 256. Hotpoint Arcadia PCB ...
Adwww.hotpoint.co.uk/SparePartsrating for hotpoint.co.uk
Save £5 When You Spend £35 or More! Low Cost and Next Day Delivery.
Price Match Guarantee · Spend £35 & Save £5
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
The flashing door lock light is indicating that the door is not closed proerly.
This can be caused by a weak or broken spring in the door handle.
Another reason for this to happen, is a faulty control board at the top of the washer, a blown track will cause this.
This in turn, is usally caused by a fault on the motor.
Hope this helps.
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
I have a fairly new Hotpoint Aquarius machine (out of guarantee).
When it is switched on, all of the red lights flash and it will not operate.
Can you help please ??
