Question about Daewoo DTQ-20U9SC TV
Fuse blowing what can i d if my tv has no power?
  • Anonymous Jul 26, 2008
    TV is dead ,fuse is good voltage @ FUSE but tv fail to come on.RCA model CT-25G7F Power on/off switch is good where is the problem?
  • lenrosenberg Aug 26, 2008
    I have a Daewoo model DTQ-20u9sc built August '05, serial # BGR533Ye1011766. I believe it failed from a lightning strike. It is totally dead, unresponsive. I opened the unit and saw that the fuse on the board was blown and replaced it, but still nothing. Your thoughts?
    Scholar:
  • 57 Answers
If you know something about TV repair then you can try to fix it yourself. In which case, you can get help here by giving the exact make and model of the TV; if on the other hand you know next to nothing, then the safest route is to take it down to your nearest TV repair shop. Good luck.
Posted on Jan 18, 2008
Panasonis 50" plasma, both fuses keep blowing when
This is a dead short, check power supply for diodes bad or zeners
Mar 08, 2011 | Panasonic Viera TH-50PX80U Plasma TV
No power blowing fuses
    According to the symptom if the TV blowing fuse repeatedly then there must be a short circuit in the power supply, Check the PTC it must be short and blowing fuse due to it.
    Hope this will fix your problem.
    Thanks.
Jan 10, 2010 | Sylvania 6432GG 32" TV
TV won't turn on
take the back off the tv and inspect the glass fuse off the ac power cord, it will probably be black and open, this is a common problem, it blows because the degaussing circuit works too slow, the original fuse is an 6.3 amp fuse, you need to replace it with a 6.3 amp slow blow or a 7 or 8 amp fuse to keep it from blowing, if you put an original 6.3 amp fast blow fuse in it, it will work for a while, but will blow again someday.
Sep 07, 2009 | Panasonic CT-32SX12 32" TV
Proscan lcd tv model 26lb30h blows fuse on power board
If the fuse blows again after replacing it, there's a shorted diode, bridge rectifier, capacitor or transistor in the power supply.
I repair these power supplies. If you need furhter assistance, write to jah2mil@hotmail.com
Jun 20, 2009 | Proscan 26LB30H 26 in. LCD TV
Won't switch on
yes it could be a fuse but moust of the time
the fuse is blowing because power suger/or bad flyback/hozoutput/or power supply whent bad. unplug the tv .take off the back and look for the fuse you see the power cord it by the powercord if the fuse is black it a hard blow.
if you can see thur it .it a sofe blow you can try to chang it.6.1amp fuse125v or it could be 250v fuse6.1amp and if the fuse blow agon you have a short powersupply
Jun 02, 2009 | Televison & Video
I had a power outage and now the tv will not power on. This is for a 55" Mitsubishi WS-55511. no green blinking lights.
You may have a blown fuse. Unplug the TV and remove the back. Look for a small fuse near where the power cord goes in.
If it is blown that may be the problem.
Use a magnifying glass to read the AMP rating.
replace the fuse and plug it in. If the fuse blows again you need expert repair services.
If the fuse doesn't blow then try to turn it on.
If it turns on then check the operation of the TV.
If the fuse blows again or the TV won't work correctly then you need expert repair service to fix your TV.
You may be able to have your household insurance pay if it is damaged by lightening or a power surge.
Lee
May 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Blown fuse
Most likely there was a power event (surge, brownout, ect) that caused the power supply to fail in the TV causing the fuse to blow. you will need to have someone come and look at the unit and give you an estimate. If you keep putting fuses in and blowing them you could actually be causing more damage.
Mar 10, 2008 | Televison & Video
TV Blows internal fuse
You will have to find the source of a major short in your power supply.Since it's a 5A i assume i imagine that's where the short is.
Oct 23, 2007 | Samsung SlimFit TX-S2783 TV
Fuse blows.
Please check for shorted diode or condenser at power section.
May 29, 2006 | Panasonic CT-27G14 27" TV
Daewoo DTQ-20U9SC TV Logo
101 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
