Question about LaCie (300966U) 1024 GB Hard Drive
Fatal error sir, my system give a message fatal error. What is the meaning it.
0 characters
1 Points
Fatal device hardware error
It means your Hard Drive is dead or about to be dead.
You have a few choices. If it is still running you can try to back it up. But in doing this you may destroy all your data on the hard drive.
If you are somewhat mechanically inclined you can take the Hard Drive out and send it in to have the Data recovered. But mind you it may cost $1k to get it done. Just look for data recovery online at western digitals website. They will tell you of companies that they recommend.
The down side is if your Operating system is on it and you don't have a back up of that operating system you are going to have to go buy a new one. Also you WILL need a new hard drive.
Sorry but I hope this helps you out.
Apr 09, 2014 | Western Digital Hard Drives
On start up,there is a message that pops up,which says that,THERE IS A DISK READ ERROR.What does this means and how do I solve this?
I understand that you are having DISK READ error on startup. This error message may be due to BAD HARD DRIVE or a DEFECTIVE HARD DRIVE.
To do a work around, you can try to use a new IDE cable on the hard and try to boot the system again.
Jun 30, 2011 | Dell Latitude E6410 Laptop Computer (Intel...
My pendrive not pick up by my system and not
You need to certain things.
  • If your pen drive is not being picked by any system, it is vital to see what the error message it gives.
  • If it says: USB device not recognized there is nothing more you can do. It means that the device driver installed in the pen drive is either missing or is corrupt or even was not installed (if you purchased it recently). What you can do is to get it replaced from your retailer.
If it says something else, please inform me, I will be following up your problem.
We are always there to help you out.
Jul 21, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Won't go into internet, and it says Fatal System Error.system process terminated unexpectedly.
well this is because of viral infection(bad software) on pc it might have corrupted some important system files so it better if u try to restore the pc to previous settings and if that not work try reinstalling the browser next reinstall OS.
Jan 05, 2010 | Hard Drives
Weird folder/filenames that will not delete There is a folder on my WD 250 GB Passport Flash drive who's properties show it to be using 157 GB of memory. The Read Only attribute was set, unchecked it. I...
Problem: Folders / files in USB flash drive got named with weird strange characters & those folder / files cannot be copied or deleted.
Reason: Virus infected
1. Click on "Computer"
2. Right click on the drive that contains USB flash drive
3. Select "properties"
4. Click on "Tools"
5. Click on "Check Now"
6. Check disc options will appear on screen, put a tick mark in the box in front of Automatically fix file system errors
7. Tick mark in the box in front of Scan for & attempt recovery of bad sectors is not necessary.
8. Click on "Start"
9. Upon finishing of this task, screen will show message "Your device disc was successfully scanned" and bla bla. Close it.
10. After this process the undeletable folder in USB flash drive can be deleted by selecting it & deleting it. The contents of affected folders files cannot be recovered.
After lot of struggle I got this solution on my own by the grace of God.
Sure it will work for others too.
Thanks and regards Raju
Nov 25, 2009 | Western Digital Passport 320GB External...
Philips laptop has fatal error message - system
Hello Vixen,
Sorry about the problem.
I will try as much as possible to give you a detailed steps you can try.
And they are going to be two Options.
First options is this:
If you have a Windows Installations CD.
Insert it into your CDROM Drive, then when you put on your system,
Go into the system BIOS/Setup by pressing 'Del' key or any other key (e.g F10) required to enter setup, while the system is booting.
Now look for where you have Boot Sequence or Boot Order.
Select the CDROM to be the one where the system will boot from.
then follow the On-Screen instruction and select repair.
Next Option is if you don't have the Windows Installation CD.
Put on your Computer,
While it is booting, Keep tapping the F8 Key, and this will bring up the Menu where you will have to select the different options of booting.
First of all try out "Last Known Good Configuration".
If it doesn't work, then try booting into safe mode.
If it boots in Safe Mode, then click on start---> Accesories--->System tools---> then System restore. Then restore you system to an earlier time.
Now, If all that still doesn't work, then Select Safe mode Command prompt.
When you get to command prompt, type: chkdsk or chkdsk /p and press enter.
This will scan your system for errors and correct it.
If this does not work, type scanreg .
This will scan your systems registry for errors and fix it.
If Trying All these does not work, then Go back to Option 1.
Which means you will have to get a Windows Installation CD.
I am giving you all this trouble-shooting steps with the assumption that you are using Windows XP. (Because you did not specify your type of OS).
But In case you are using Windows Vista,
then under option 1, after inserting the CD, and booting from it,
just follow the on-screen instructions and select:
"Fix what is preventing my Windows to boot Properly" , under the options.
All these are the FULL trouble-shooting steps you will need to get your system working.
But if after trying all of them out it still does not work,
Then you will have to take them system to a good technician.
Kindly keep me posted and let me know how it goes.
Thank you for using FixYa.
Good luck
Nov 25, 2009 | Hard Drives
Error in loading Operting System
you can download and create a "repair" disk that will be able to scan your hardware without the need of windows. click here to download the disk, unzip it and create a disk.
follow the directions in the setup menus.
from the sounds of it your boot sector has become corrupt
good luck
Mar 12, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Error message: HD521-2W
this error is basically a fatal error. you will endd up needing to replace your hard drive soon but if you dont like doing a recovery every few days and loosing your information all the time replace the hard drive
Mar 30, 2008 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
LaCie (300966U) 1024 GB Hard Drive Logo
Top LaCie Hard Drives Experts
Brian Sullivan
Brian Sullivan
Are you a LaCie Hard Drive Expert? Answer questions, earn points and help others
