Installation DVD Installed on SATA port not recognized by BIOS
  • KMOQ Jan 18, 2008
    ASUS DVDE616A3T DVD ROM is the actual unit. I have already loaded defaults. Device not recognized on any SATA port. Thanx. K.
  • KMOQ Jan 18, 2008
    I have an ATA/IDE DVDRW already installed. My HDD is seated on SATA0 or SATA1, I can't remember. I have downloaded the drivers for that specific DVD ROM and the "device is not found" error message appears. But the drive is not found on the BIOS, not found on the Device Manager, either. K.
    Genius:
  • 1,226 Answers
Connect your DVD rom to sata2 and then fixed it well after that
try to go to bios setup and then load bios setup default.
Posted on Jan 18, 2008
  • Emelio Navaja
    Emelio Navaja Jan 18, 2008
    is the DVD not found on bios? if found in bios maybe you need a drivers of that DVD ROM . If not found,
    try that DVD rom in other computer. if this work in other computer maybe your Mboard cannot support Sata DVD Rom.
    If not work also then examine the DVD ROM maybe it has a factory defect.
  • Emelio Navaja
    Emelio Navaja Jan 21, 2008
    this means either that you have no connection both Mainboard and and the device attached. So the problem is either your mainboard and your sata device are not compatible. please verify your mainboard manual maybe some jumper setting on it accidentally remove and causing the not to function well.
Dell Optiplex 755 - 2 sata ports (2&3) not working on motherboard. They have been switched to "on" in the bios, but will not recognize sata HDD or sata DVD. Only ports 1 & 2 are working, so I now have a...
hi There.
this is all i could find out from the internet so not sure if this will help you out.
(I went into BIOs again after I looked the SATA port over on the motherboard. The SATA ports on the motherboard are listed as 0,1,4,&5. In BIOS the SATA ports are 0.1.2.3.4. & 5. I have been trying to turn on 2 or 3 as they are the next ports and never tried 4 or 5.
When I turned on 4 and 5 everything is working fine.
Why do they list SATA ports 2 and 3 when they are not present on the motherboard)
or see if this link helps you.
Dell Optiplex 755 2 sata ports 2 3 not working on motherboard Google Search
Dec 15, 2017 | Computers & Internet
Pavillion P6000 won't recognize any drives
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jun 15, 2012 | HP Computers & Internet
I have a HP Asterope Motherboard The Sata HDD or the Sata CD/DVD cannot in not detected in the BIOS and the computer can not boot-up When I use a IDE drive on the Ide port, It works But I have a...
Reasons a sata device might not be recognized in BIOS:
(1)Serial ATA disabled, enter bios and enable SATA.
(2)Serial ATA cable defective
(3)Serial ATA drive defective
(4)Serial ATA cable defective
(5)Serial ATA device not plugged into power.
(6)Serial ATA power adapter defective.
Feb 26, 2011 | Computers & Internet
I have sata dvd writer.when i connect it my computer does not boot.does intel D102ggc2 supports sata dvd writer?
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports.
The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports.
You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so;
First boot device: [Floppy disk] drive; if one is connected.
Second Boot device: [Primary Hard Disk] drive.
(The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information).
Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart.
You're windows operating system should load correctly after the auto re-start.
The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose.
Here is the link to Intel for you're motherboard;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D102GGC2+%22
Mike
May 12, 2010 | Intel D102GGC2 Motherboard
Installed new dvd drive installation disk not recognized
I need alot more info than this to solve. Like model,year,kind of drive(ide or sata),operating system & any other relevant info.
Jul 14, 2009 | HP Computers & Internet
How to install Redhat Linux 4.0 on Acer Power Series with SATA.
So did you try to install with and IDE dvd drive? Might be a BIOS issue, update bios or get a ide dvd drive somehow...
May 06, 2009 | Acer Computers & Internet
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Computer won't recognize sata dvd burner
is jumpers on corect cant u just use ide cable instaed u said your going from ide to sata cable ?
Jan 19, 2008 | EliteGroup P4VXMS (P4VXMS-R) Motherboard
Installation
check your BIOS settings, make the sata supporting option enabled.
check sata cable loose contact, reconnect its or replace cable
also check sata power supply cable
Jan 17, 2008 | Computers & Internet
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
