HELP!!! What webcam will work with xp. I have a logitech quickcam express
and when I purchased my new computer with Windows xp, I couldnot install the
quickcam express software. Logitech came out wiht new software, I
downloaded tried to install but it wont install. So I will look for a new
webcam made especially for windows xp
Does anyone have any recommendations
8 Other Users Have The Same Problem
Comment by Guest, posted on May 25, 2008
i have the problem while installing my cam in system without CD. please let me know the link so that i can instal my cam.
Naresh Bhatt
Comment by potter_117, posted on Apr 10, 2008
Have a webcam can't find the disc and want to have my cam on
Comment by Guest, posted on Apr 07, 2008
i want to install logitech software by net
Comment by Guest, posted on Feb 24, 2008
I have this logitech camera but I don't know how to get it accessed and going for aim or stickham or even set up for my computer...
Comment by Guest, posted on Feb 21, 2008
i need a logitech quick cam driver to run my web cam as i lost cd given with it.a suitable driver enable of windows xp is required.
Rating: 0%, 0 votes
about 3 seconds then freezes. This happens with Both with the XP driver
(native) and the Logitech driver.
Other than this XP's been great so far
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
I have a Logitech Quick Cam Express (USB) attached to my PC.
Everything went fine - XP upgrade found the cam and installed drivers.
When I went to use "Windows Movie Maker" I constantly got a "Device
does not respond", etc. error - yet, other cam-networking software
worked fine! I couldn't figure out what the problem was until I went
into "Connect To" off the start menu. When I clicked "Show All
Connections", I had something called Microsoft TV/LAN (or similar
wording) connection running - I didn't know what this was, so I didn't
touch it. I read some info on the newsgroups and others mentioned this
program running - also mentioning that deleting the 'connection'
caused no ill affects. I decided I would do the same.
After rebooting, it worked! Windows Movie Maker works fine with my cam
and my other software does too.
I *think* that the XP upgrade trips up somehow if the cam is already
installed and installs this phantom "TV/LAN" connection - which leads
to no where.
See if you have it too - click on "Connect To" - Show all Connections.
If you have it (something like Microsoft TV/LAN), delete it and
reboot.
I hope this helps!
atd1999
Rating: 0%, 0 votes
Rating: 0%, 0 votes
in 98 SE. Device Manager shows a USB device with problems in XP. I
stuck in the disk that came with it which says it is also for NT 4.0 and
it told me that version only supported parallel connections in NT. So I
went to Logitech's web site thinking surely they would have updates.
They said that since they are producing new models now, they would not
support the camera I bought about a year and a half ago. They said I
should buy a new Logitech camera.
I wrote them and told them that since they didn't support this camera
under the new operating system, why should I buy a new one from them
that they won't support when XPii comes out because they have new models
by next year.
No way no how.
I've loved my Logitech trackball that I've had for maybe 5 years and my
camera ( which still works fine under 98 ). But I'm not going to buy any
more products from a company that doesn't support past products. Other
companies are supporting their old printers and video cards and all kind
of hardware. Just because they now have newer models doesn't mean they
don't support the old one for at least a reasonable period of time. Just
a few months ago I saw Logitech advertising the very camera I have, on
their site, and now they refuse to support it.
They should move to Afganistan.
Rating: 0%, 0 votes
great and the icon is displayed in my Scanners and Cameras.
David A. Spicer
www.ds96427.50megs.com
Rating: 0%, 0 votes
installed. Finally solved the problem by removing all Intel camera .inf
files from the WINDOWS\INF folder.
Rating: 0%, 0 votes
uninstalled the 'official' Kodak WINXP driver twice(unplugging and
replugging in the USB cable as directed). Camera works fine as long as I
don't try and adjust any of its parameters(like brightness, contrast, etc.).
After moving the adjusting slider bars once or twice, application to which
the camera is feeding a picture, locks up(this happens with NetMeeting and
MS Photo Draw). It is repeatable.
No other problems with XP.
It would appear from this thread that there are numorous problems with USB
webcam drivers, in general. The vendors and MS need to get hot and get these
problems sorted out.
Rating: 0%, 0 votes
Quickcam Express and it works fine on XP, although Windows do not yet
support the drivers I'm using.
Rating: 0%, 0 votes
My QuickCam Pro is recognized by system/hardware/device manager but there is
no web cam icon in Scanners and Cameras. Any help?
Thanks Gary
"John Barnett - MVP" <john_freelanc @hotmail.com> wrote in message
Rating: 0%, 0 votes
positive experience with Windows XP (upgrade home edition). Secondly, I
had a Logitech Webcam Express cam attached to my system. When I
upgraded the system, XP picked up the cam as hardware as it was listed
in the device hardware list. When I went to to Scanner & Camera wizard
it picked it up and yes there was a cam pic; however, about 5 seconds
later, the cam would freeze. This happened several times.
Later, I discovered that www.logitech.com had a driver update for
Windows XP. I downloaded the update and was careful to read all
instructions. When re-booted the system and loaded the new updated
software, from Logitech, I experienced such a crashed that I had to just
completely turn the computer off. Something I don't like. My cam did
not work with XP driver before nor the updated drivers from Logitech.
Presently, I have discarded the cam - seeing I threw it in the corner of
my study. When I get the bitter taste out of my mouth, I will attempt
to re-consider a cam under Windows XP.
Other than that I'm very impressed with Windows XP. All other hardware
and update are working fine.
Wayne D. Alligood
w @net-magic.net
Rating: 0%, 0 votes
drivers. Have you tried the camera without loading the Logitech disk? I know
that you will not have Logitech's software, but IMHO the software built into
XP is superior anyhow.
Patrick J Lines Sr
Technical Beta Test Site - Microsoft
Rating: 0%, 0 votes
Outgoing mail is certified Virus Free.
No emails please, reply to group only.
Private emails WILL bounce
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.295 / Virus Database: 159 - Release Date: 01/11/2001
Rating: 0%, 0 votes
Hardware, Scanners and Cameras, in the upper left click on
Add and Imaging Device, click Next on the Wizard, and
under the manufacturer is a list of all Webcam
manufactures and to the right specific models which are
digitally signed for Windows XP and that contain drivers
inside Windows XP. Good Luck!
Rating: 0%, 0 votes
quickcam express software doesn't work. We are talking
software here not web-cam. I suggest that you first go to
control panel/system icon/hardware/device manager. Once
there check that your web cam has been recognised by XP.
If so then exit the system window and click on the
Scanners and Cameras icon. There should be an icon which
represents your web cam. Click on this. The scanner and
camera wizard will appear. Click next and you should see
a picture from your camera. If you have got that far then
your camera is working perfectly.
The software you are using allows you to use your cam as
a video link etc. You don't need this software. To video
conference you can use either windows messenger (assuming
the other person you are talking to has windows xp) or
alternatively Netmeeting. Netmeeting isn't always visible
by default so i suggest you click on the Start button
then click on Run. At the command prompt type Conf.exe
Netmeeting will then start and you can set things up from
there.
I haven't tried logitech web cams. I much prefer Intel. I
have two cams by Intel CS340 and YR76 both of them work
perfectly with XP. When i want to video conference i use
messenger or netmeeting. Why bother with the software
bundled with the cam when you already have the facilities
available on XP, Me 98, 95 etc.
Hope this helps
John Barnett - MS MVP
Associate Expert
Post a New problem for Logitech QuickCam Express Personal
Email this problem
Can you Help with these Web Cameras problems?
no sound on internet
logitech quick cam express
logitech sound problem
cant install without service...
8 Other Users Have The Same Problem - Continued
Comment by chinkee, posted on Jan 28, 2008
i need to install of the driver on this product coz i lost my cd driver and i tried to find the installation here but can't find it..help me pls
Comment by Guest, posted on Dec 16, 2007
My Computer is not recognizing this software.
Comment by Guest, posted on Nov 22, 2007
I also have a web cam Logitech express. recently i have changed my hard disk, and since i'm working on the new hard disk i wasn't able to install the express software to run my camera. In addition, when i connect my camera to the usb stick i get the masagge: a problem happened while hardware installation, your new hardware might not work properly.
