Question about Radio Communications
Fault on my Transceiver
Display screen flashes rapidly and no audio or TX. Any ideas please?
    Brigadier General:
  • 6,966 Answers
You posted your concern as generic with no specific brand or model. Flashing displays can mean a variety of things to different makes. Some of which are:
1. Low battery. Low memory battery;
2. Error in programming;
3. Error in firmware;
4. Fatal error in self-test/diagnosis;
5. Major component defect detected; and/or
6. Out of range/band.
In the same token, corrective measures can likewise be anything:
a. Recharge/replace battery;
b. Reprogram/reload program;
c. Update firmware/clone;
d. Run diagnostics using an external device (often a PC);
e. Determine which is at fault (finals, VCO, PLL, voltage regulator, replace);
f. Tune back to standard freq.
Most often (but not always), it can be also be corrected by doing a reset of the radio which can be:
i. Pressing FUNC (or some other button) while powering up;
ii. Pressing a recessed/hidden reset button;
iii. Placing a temporary jumper/shorting two (2) points (internally on the logic board);
iv. Remove battery/power (including internal if any);
v. Pressing a sequence of buttons to enter MENU/SETUP mode.
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information. Would appreciate also if you can specify brand/model/region.
Good luck and kind regards.
Posted on Jan 18, 2008
No video but have audio
Sounds like display panel fault. If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
How can I program the Kenwood TM-G707 A/E transceiver to our new repeater with a REC. of 151.1225 TX of 159.015 with DPL of 172 and 134?
I believe that your transceiver requires a simple mod which involves removing a surface mount diode or resistor usually found in the front display head.This allows the device to operate out of the intended frequency band.You may Google Transceiver TM-G707 A/E Modific ations for further info.
Oct 30, 2014 | Radio Communications
Howe to wire a 4 pin coard on a astatic d 104
must know the pin out of the transceiver your wiring it too.
like cobras 1.ground 2.audio 3. TX 4. RX... then wire accordingly.
use a ohm meter to find the correct wires on you mic switch.
then you know how to wire any mic to any transceiver.
Sep 02, 2014 | Radio Communications
Magnum delta force radio wiring diagram for Mic turner 2pluse 2
Must know the pin out of the transceiver your wiring it too.
like cobras 1.ground 2.audio 3. TX 4. RX... then wire accordingly.(same as the 4 pin exports)..
Use a ohm meter to find the correct wires on your mic switch.
This will work for the turner 2+2
Aug 24, 2014 | Radio Communications
Why does my kenwood TH-K2 fm transceiver will not transmit
Users Manual (download if you don't have it)
TX I
NHIBIT
You can inhibit the transmission to prevent unauthorized
individuals from transmitting, or to eliminate accidental
transmissions while carrying the transceiver.
1 Press [MENU].
2 Turn the Tuning control to select Menu No. 25 (TXI).
3 Press [MENU].
4 Turn the Tuning control to select "ON".
5 Press [MENU] to store the setting or [PTT] to cancel.
"TX INH" appears and an error beep sounds if the
transceiver tries to transmit while TX Inhibit is ON
May 11, 2014 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Assinging coaxial 1 to dvd
hi.
Do the following to assign COAXIAL 1 to dvd.
1. Press the DVD button on frond panel ( will display the current setting).
2. Press and hold DVD button for 3 seconds ( will display the selections ).
3. Press DVD button rapidly and select COAX 1 ( will sect COAXIAL 1 as DVD input).
ok
Feb 18, 2011 | Onkyo TX-DS484 Receiver
TXSR875 reciever display
Hi and welcome to FixYa,
Two possibilities:
  • the Pure Audio feature has been engaged. This turns off the receiver's front panel display;
  • heat related issue. A common fault that develops is component failure, specifically, R9304, a 10 ohms dropping resistor connected inline with the +44V display supply.
Should you be considering a DIY (do-it-yourself) repair, please postback for procedures. Otherwise you may have to seek the services of an authorized service center (specially if under warranty) or a qualified professional
Hope that this be of initial help/idea. Good luck and thank you for using FixYa.
Mar 31, 2009 | Onkyo TX-SR875 Receiver
Open gurage door with the built in remote in the car
To Reprogram A Single Button
1. Press & hold the desired universal transceiver button. Do not release the button until Step 4 has been completed.
2. When the dot(s) under the HomeLink icon being to flash slowly (after 20 seconds), position the hand-held transmitter 1-3" away from the universal transceiver surface.
3. Press & hold the hand held transmitter button.
4. The universal transceiver light will flash, first slowly and then rapidly. When the indicator light begins to flash rapidly, release both buttons.
The previous programming for the button has now been erased and a new device has been programmed to the button.
Repeat for any other buttons you want to do for other devices.
Dec 20, 2008 | 2001 Chrysler Town & Country
Receiver lcd display doesnot work
Does the 605 have the "pure audio" setting (my 705 does)? If that is selected, it cuts out the lcd display on the front.
Jan 04, 2008 | Onkyo TX-SR605 Receiver
Radio Communications Logo
122 people viewed this question
Top Radio Communications Experts
Steve
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
