Question about Philips WMM142211 Turntable
Pioneer PL516 turntable
Hello my strobe ajust doesnt slow tt enough to play 33's
  • 515 Answers
You have a faulty IC inside. You will need to take to a service center for repair, unless you have knowledge in testing and removing Integrated Circuits.
DJPROAUDIO
TWEAK AV LAB
Posted on Jan 19, 2008
Adjust pitch not working on PS T1 Sony
Try looking underneath the turntable. There might be two speed presets one for 45 and one for 33. They could be covered up by stickers.
Jun 04, 2014 | Sony Audio Players & Recorders
Motor stutter
yes you reLly are a dj, only doesn't know how you have to maintain simple gear , pioneer amp a assume?
You don't need new tt, just knowledge and being a 'dj' , search and finf on google
Nov 28, 2013 | Stanton Audio Players & Recorders
Technics sl d303
I have the same problem as mentioned above, does anyone know how to fix this pls. The 33 and 45 lights have stopped illuminating, hence cannot get the record to start playing. There not burnt out as the 33 has flickered off once powered on. Start / Stop button does nothing. Strobe still works, it's in mint condition and has had little use but suspect the kids have been messing with it.
Dec 31, 2012 | Technics Audio Players & Recorders
I just recently bought a new turntable, and when it plays my LPs, the LPs sound somewhat slower than the original. Does the slowness have to do with the belt of the turntable? Is there anyway I can fi
If the 45's play OK then your belt might not be fitted in the right place. If they are both slow, then either the belt is slack or the drive is faulty.
Dec 09, 2012 | Audio Players & Recorders
What's the correct way to use the strobe light to set turntable speed?
The turntable may have a pattern on the edge of the turntable. If not you need a turntable strobe disk that you place on the turntable like a record. The pattern on the disk or on the edge of the turntable will be marked for 50 Hz or 60 Hz frequency.
The strobe marks on the disk or on the turntable are for 33 RPM and 45 RPM and for both 50 & 60 Hz mains frequency.
To adjust the turntable for the correct RPM, turn on the strobe light and the turntable set it to 33 RPM and shine the strobe light on these marks and adjust the speed setting until the 33 RPM marks appear steady and not moving. You may want to check it for 45 RPM as well.
Make sure you use the correct mains frequency marks ie. the 50 or 60 Hz that your electricity system uses.
Feb 25, 2011 | Audio Players & Recorders
I suddenly heard alot of distortion when playing the Pioneer PL-990 turntable. Wonder if replacing the needle may take care of the problem.
Depends on the circumstances. Is it only when you play it loud? Air- or room-borne vibrations will feed back through the TT to the speakers. Keep the volume down to avoid it.
If you call the stylus a 'needle', replacing it maybe beyond your capabilities. There are lots of reasons for TT sound to be less than perfect and arbitrarily replacing things can do more harm or introduce new problems. Take it to someone experienced and equipped to evaluate the issue.
Tonearm balance, antiskating, dirty stylus, feedback.
Dec 28, 2010 | Pioneer PL-990 Turntable
Going too slow
You might try cleaning the motor shaft and belt with isopropilic alcool to remove any trace of grease that might make tre belt slip.
Apr 23, 2009 | Audio Players & Recorders
Cd malfunction
Lens cleaners aren't enough. You might have to take it to a service center to have it opened up and professionally cleaned.
If there is no damage to the cd traverse assembly, then the issue might be with either the quality of your burned CDs, or method used to burn.
I always tell people to burn at slow speeds - 4x is ideal. Yes, I know it's slow, but it will burn your cds at a better quality.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Jul 01, 2008 | Pioneer CDJ-800MK2 Turntable
Strange speed
Well, there isn't much on this unit that controls the speed. It's either your belt or your motor that's gone or going bad. Try replacing the belt first. If you still have the same issue, you might need to have a tech look at it. The 33/45 switches might have also gone out, but it doesn't like this is the issue.
Hope this helps.
- TWEAK AV LAB
Dec 03, 2007 | Audio Technica AT-PL50 Turntable
Open Questions:
Philips WMM142211 Turntable Logo
693 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
