I need the code for a toshiba tv for a 3 in 1 radioshack remot control
Hi again, same answer as the other, it looks like they have most of their remotes covered. Good luck, Mechanic
http://www.rcinfo.com/
SOURCE: need code for hitachi tv
Hitachi: 1145, 0145, 0151, 1904, 0032, 0409,
or you can use the general method:
SEARCHING FOR YOUR CODE
If your device does not respond to the remote after
trying all codes listed for your brand, or if your
brand is not listed, try searching for your code. For
example, to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks
twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power.
The remote sends IR codes from its library to
the selected device, starting with the most
popular code first.
5. If the TV responds, go to step 6. If the TV
does not respond, press CH+. The remote will
try the next code. Continue until the TV
responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps
1 to 6, substituting the appropriate device
key.
SOURCE: codes for remote
Hi, my RCA remotes have a code search feature, but it's kind of time consuming, so you might check out this site and see if it's any faster. Good luck,,, mechanic
SOURCE: radioshack 3-in-one remote code
I need a code for a VCR Durabrand (DCV603) for the Sony universal remote control or a the All in one (URC 4220) remote control because the code suggest doesn't work.
Martine F
[email protected]
SOURCE: codes search for a radioshack 15-2147 remote
Here are the codes...1447,0047,0051,0178,1347,1917,1147,1907,1922,1919,.....To program.. Turn the TV on, make sure you have fresh batteries in the remote,and installed correct, Press and hold down the P button until the LED blinks twice, enter one of the four digit codes, the LED will blink twice,it not, repeat the steps using a different code..hope this was helpful...
