Question about Trendware TEW-432BRP Wireless Router (TEW432BRP)
Problem in installing TEW-432BRP
During installing the message always saying "bad IP address" and some time "fail to connect"
I have tried to reset it couple time...
many thanks...
Dylan
  • dylan1 Jan 30, 2008
    no solution yet....
  • Acadie53 May 02, 2008
    Can't reset my Trendware TEW-432BRP Wireless Router config to factory setting.
    Found this information on the Internet?
    The reset botton at the back will not reset the config back to factory setting. If you type in a wrong MAC address for the very first machine, you can NEVER gain access to the router ever again. Be careful. Other then that this is a good router for general use with average signal strength.
Ive the same problem
Posted on Jan 28, 2008
Hello. I have a TEW-432BRP D1.3R and I usually get close to 10 minutes of connection then it drops the connection and I can't browse the internet. I have to turn the power off and wait 15-20 seconds...
First, check to see if the connection to the TEW-432BRP is not what is dropping signal. If the ethernet line is functioning and you don't lose connection, re-attach the router and try performing a factory default reset on the device. Otherwise, you may want to contact Trendnet support for assistance in determining if the router is faulty. From a hardware standpoint, there are several things on the mainboard of the router that could cause your symptom.
Nov 29, 2017 | Trendware TEW-432BRP Wireless Router...
I dont have installation driver
Router does not require driver to be used, all you have to do is to install the hardware and configure it.
1. You have to know your hardware version, so you can download your materials.
There are 5 version of your TEW-432BRP.
2. Click the link below, If you already know the version.
(Main).
(TEW-432BRP D1.2R/D1.3R)
(TEW-432BRP D1.OR/D1.1R)
(TEW-432BRP C1.xR)
(TEW-432BRP Bx.x)
(TEW-432BRP A1)
3. Download User Guide and Easy Go CD Files.
4. User Guide will help you to configure your router from start to end.
If problem persist just post and give a brief explanation on the problem.
Hopefully this helps
Thank you for posting.
Jul 09, 2011 | Trendware TEW-432BRP Wireless Router...
I can not browse: http//192.168.10.1
Most routers have a default address on a local network of 192.168.1.1. Try connecting to that first.
Sep 21, 2010 | Trendware TRENDnet TEW-432BRP Cable/DSL...
No SOftware Driver for TEW-432BRP
What brand is your router? Check for the IP address of the router and default password (should be written on the back of the device). Then type the IP address into the web browser on your main desctop in the kitchen like that for example http://192.168.0.1 enter the default username and pasword and you are in the router's menu.
Set up wireless connection SSID is the name of your network that will apear when you search it, do not change any of the default settings exept the SSID , enable, and select password. Use the WPA2 and type in your desired password and press SAVE . Then go to your bedroom and try to find the wireless network you've just created. And connect. Good Luck
Jul 23, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
I have a trendnet wireless router tew 432brp, a new hp windows 7 laptop, and old xp laptop and i want to share the connection with my verizon um175 aircard. this has worked for several years with the old...
The router connects computers together . You are using a windows 7 p.c and connecting it to an internet connection via a usb verizon um175 aircard.
I think you need to share the internet connection with the rest of the network and may need to feed the ethernet cable into the feed port of the router. I have not done this before but logically the windows 7 computer would have to act as a gateway to the internet.
http://www.dummies.com/computers/operating-systems/windows-7/how-to-share-an-internet-connection-in-windows-7/
https://www.ibvpn.com/billing/knowledgebase/53/Internet-Connection-Sharing-on-Windows-7.html
Note the default gateway is going to have to be the windows 7 ip address on the other computers
You may need to set the ip address on windows 7 to a static address and then change the dhcp server settings default gateway and also increase the first address to not include the windows 7 ip address or the routers ip address in the lease range for shcp.
Mar 17, 2017 | Trendware TEW-432BRP 54Mbps Wireless...
Vista ultimate 32 not connecting to wireless
169.254.x.x IP suggests that your NIC is not communicating with the DHCP server of your Router. Try disabling/enabling the NIC card and in the TCP/IP properties, make sure that the IP address is configured as "Bobtain IP address automatically"
Also try installing the latest drivers for your NIC card.
May 13, 2009 | Trendware TRENDnet 4-port Switch - 54 Mbps...
I have a Pre-owned TEW-432BRP router, when i hook it up to comcast modem i cannot accsess internet. My PC says i have a connectivity problem. The button on front of router seems to do nothing, The lights...
There is a reset button on the back of the router. Push in with a paper clip, till the lights flash. This will reset it to the factory defaults.
Then shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line.
Here is the user guide:
http://downloads.trendnet.com/tew-432brp/manual/ug_tew-432brp.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 09, 2009 | Trendware TEW-432BRP Wireless Router...
Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
Apr 24, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
TRENDnet TEW-432BRP router cannot obtain IP through DHCP
it seems that ur PC & cable modem configuration is ok, now the problem is with ur router WAN interface configuration. the problem would be one out of 2 - first to check whether ur router wan interface is configured properly to obtain IP address from DHCP (if possible, u can give the static ip address with same series as cable modem) second to check with ur ISP.
Mar 19, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Manual Setup of Trendnet Router
1. Open Internet Explorer 5.0 or above Internet browser.
2. Enter IP address http://192.168.10.1 (the factory-default IP address setting) to
the URL web address location.
3. When the following dialog box appears, enter the user name and password to
login to the main configuration window, the default username and password is “admin”.
Jan 12, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Trendware TEW-432BRP Wireless Router (TEW432BRP) Logo
252 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
alex metro
alex metro
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
