Question about Konica Minolta DiMAGE 2300 Digital Camera
Formatting problems I have a minolta dimage 2300 that I can't get it to format.I put a new compact flash card in the camera and the screen keeps reading not formated,so I went throught the steps to format it and it keeps freezing up on the final step which reads FORMAT ? YES NO OK ENTER I highlite yes an press the enter button and the camera just freezes up,I can't even turn it off I have to wait untill it goes off by itself in 3 minutes.Can you give me a hint of what I can do???
  • 68 Answers
Try formatting the card on a computer than again on the camera. If you don't have success formatting the card with a computer than it is a pretty sure thing that there may be something wrong with the card.
Posted on Jan 18, 2008
What is the biggest size memory card for my Dimage A1 Minolta Camera?
An older camera, the DiMage A1 came with a 16mb card. Some cameras are picky about which cards work best. Compact Flash cards are sold in different speeds and your camera may work faster with a faster card. This camera can use Compact Flash type I or type II, and is compatible with the microdrive card. Since this camera was introduced the capacities of Compact Flash cards have increased dramatically so I believe you should be able to use a larger card with no problems but I would check out some of the online photography sites to read about other's experiences. Here is one good resource:
http://www.imaging-resource.com/
Hope this helps!
Sep 13, 2016 | Minolta Cameras
Camera won't format media
Here is the link to the user manual if you need it; http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-a/dimage_a200/A200_Eb.pdf First thing to try is cleaning the electrical contacts on the card, gently with a soft dry cotton cloth. Check page 138 of the manual for instructions to reset to factory default settings - also worth trying. Have you tried formatting the card on a PC instead of the camera? What type of card are you using? The camera is compatible directly with CF cards and Microdrives, and with an adaptor can use SD and MMC cards. Possible problems are generally different for each type of card. That said, if the card will not format on a pc, then unless it is somehow password protected or write protected (depends on card type), the fault must lie with the card. Only way to be absolutely sure is to try a new card in the camera, if that also doesn't format then there is a more serious problem. From what you have described so far, it sounds as if you have a CF card, and it is faulty - these cards do have a tendency to do this. Please post back with some more details so I can be more certain. Hope this helps :)
Jul 08, 2007 | Konica Minolta DiMAGE A200 Digital Camera
Can't format a memory card for my minolta damage
Some brands cannot be used by some cameras. You should stick with the big brand names like Sandisk.
Sep 28, 2009 | Konica Minolta DiMAGE A200 Digital Camera
Minolta Dimage S414 camera doesn't like a new 4GB CF card
Check your manual to see if your camera accepts a card that large.
Aug 30, 2009 | Konica Minolta DiMAGE S414 Digital Camera
Konica Minolta Z2 SDHC reading card
Spare yourself the trouble. I had researched it (I thought) and got one, and stuck it in. The screen read: "Unable to use," It continued to read this, even after I formatted the card, so I ended up giving it to my brother, who has a Kodak camera. Sorry!
Jan 08, 2009 | Konica Minolta DiMAGE Z2 Digital Camera
KONICA MINOLTA DiMAGE 7i COMPATIBLE COMPACT FLASH CARD
go to www.memorysuppliers.com order the below item
1 SDCFB-1024-A10 - SanDisk 1GB / 1024MB Compact Flash card
Sep 22, 2008 | Konica Minolta DiMAGE 7i Digital Camera
Card for above camera
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I used the procedure set out by dwafellman and it worked for me too! His translations from the French are, in English: Control Panel (configuration panel)>Administrative Tools (administrator utility)>Computer Management (computer utility )> Disk Management (disk utility) in Storage (stockage). I. e., Control Panel>Administrative Tools>Computer Management>Storage>Disk Management.
Mille merci, dwafellman. Vouz m’avez sauvé un voyage á Office Depot pour retourner mon mémoire Flash.
imallan
Aug 22, 2008 | Konica Minolta DiMAGE 7 Digital Camera
What is the difference between Type-I and Type-II Compact Flash?
The size of Type-I is 36.4 (H) x 42.8 (W) x 3.3 (D) mm, which is the most popular type of Compact Flash card. On contrary, Type-II is 5.0mm in thickness. Some Type-II is designed not only for data storage including hard disk memory, but also for special purposes such as LAN or MODEM card, or parallel or serial connection.
Sep 15, 2005 | Konica Minolta DiMAGE 2300 Digital Camera
Konica Minolta DiMAGE 2300 Digital Camera Logo
57 people viewed this question
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
