Back to:
Tags:
ASUS P5GD1-VM Motherboard
Installed GeForce 8500 GT PCI-E video card and pc...
posted by pinglauncher on Jan 18, 2008
I purchased an AXLE GeForce 8500GT PCI Express 512 MB video card for my PC. Motherboard is an ASUS P5GD1-VM. The PSU is 430W
After installing the card in the PCI Express 16 slot the PC does not turn on. With the card removed everything is fine.
I have tried removing other cards and power from hard drives etc with no success.
Are there known issues with this combination.
Comment by pinglauncher, posted on Jan 18, 2008
The problem I have is that the system will not start at all with the new card in. It simply does not power up.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
melnavz
Rank:Guru Guru
Rating: 85%, 557 votes
If your mboard has a builtin video card you should configure that b4 u can use that add on card.
1. connect the add on card.
2. connect the monitor to the built in VGA.
3. start system and press "F2 or Delete" to go to bios setup.
4. on bios setup " refer to the manual on installing addon PCI express card".
you find it here: http://support.asus.com/download/download.aspx?SLanguage=en-us.
or enlosed in the board.
After configuring your system restart and unplug in the wall outlet and then connect the monitor in the add on card.
Hope you find in order.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Installed GeForce 8500 GT PCI-E video card and pc will not turn on:
I don't want to Accept this solution
Can you Help with these Motherboards problems?
Motherboards
does not seem any power have tried numerous things
Hi Jeff, I think you may be getting somewhere. Just...
Mercury Chipset Mother Board Number : BT8237R+ Problem is...
Loading problems.
Repair Service
Find Motherboard Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
