Question about Sony Cyber-shot DSC-W55 Digital Camera
Sony Camera I got a sony camera 6 months ago and now it will not turn on. I've tried several batteries but still nothing. Please let me know how i can fix this Thank You
  • 1 more comment
  • Anonymous Jan 18, 2008
    i also have the same problem as alshenka.
    i purchased my camera in July and worked fine until the end of December. i tried to turn it on and nothing happened. my sister has the same camera, and also is experiencing the same problem. we've tried many different batteries, but nothing seems to work.
    Can anyone help?
  • calas Jan 18, 2008
    my sister and I also have the same problem. Both of our cameras were purchased in July and stopped working around the same time near the end of December. We have charged and recharged our batteries but nothing is working. can somebody help?
  • teknit Jan 22, 2008
    Yes my daugther have exactly the same problem. The camera is from august 07 - and it stopped working a few day ago. Her battery works fine in her friends matching camera, and a new battery is not a solution.
  • 23 Answers
Try to use nickle metal hydrid type of batteries.
Posted on Jan 30, 2008
  • von mar alovera
    von mar alovera Jan 30, 2008
    1.turn the unit on the menu button
    3. select setup
    4. inside setup and search for setup 1 (option with a toolbox icon with a number at the bottom.)
    5. inside setup1, pls select initialize and reply with OK to evety prompt(using the center button)
    6.if succesfull(you'll get clock settings)
    7.set the date and time then try the camera again.
    if this does not work.... call sony cust service 1800-222-7669
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
My screen on my camera is pink. All pictures are PINK!!!
I seem to remember seeing something about this and I think it was on youtube, though at only 6 months old it should still be covered by the warranty and should be returned to the retailer for repair or replacement and no attempt made to repair it or fiddle around with it.
Mar 24, 2017 | Sony Cyber-Shot DSC-T1 Digital Camera
Power button problem
As you said, its 4 months old and assumed under warranty cover. Contact Sony Service Center for repair because if you try yourself, will void warranty.
Aug 15, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
There is a built-in rechargeable battery in the camera and after approx 3 months it will be completely discharged if the camcorder is not used. To recharge: Connect camcorder to wall outlet using the supplied AC Adapter with the power switch turned OFF for more than 24 hours. (To keep the internal batter charged, try to plug the camera in every couple of months or attach a fully charged external battery for at least 24hrs). To set the clock: Set the power switch to CAMERA and then press MENU. Turn the dial to select CLOCK SET, scroll to the toolbox looking icon -it may say DEMO MODE next to it. Then press the dial. Turn the dial to select the desired year, month, day and then pressing the dial to set each as you go. For the tape speed go to Menu settings scroll to find Tape settings (TAPE SET), select REC MODE and from there you can change the tape speed from SP to LP. Hope this helps. I have the Sony Digital 8 Handycam DCR-TRV250 I purchased about 3 or 4 years ago (700x digital zoom etc).
May 21, 2008 | Sony Handycam DCR-TR7000 Digital Camcorder
i think the firmware is corrupted ..... you must install new firmware ....
just visit the nearby showroom or technician he will install the new firmware ..........
for installing firmware it may costs some 300 to 400 bugs ....
how ever there may be other problems too may be the battery is dead just change battery and check....
check whether it is detecting in pc or not..........
Feb 11, 2008 | Cameras
well, i just chcked my camera, and you have the right could be the battery is just bad, though i don't know how to check this without trying it in another camera.
Oct 16, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-Shot (DSC-W50) Access Problem
did you try to reset the camera or call sony?
Aug 31, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Cyber-Shot DSC-S500
We had similiar problems with ours until we started making sure the camera was kept warm when it was shut off. For some reason, it and the batteries don't like the cold...we were able to extend the battery life if we kept it covered when we weren't using it.
May 10, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Camera won't turn ON
First off, everything was not fine until this morning. You had this occur a month ago. Frankly, I would have done exactly as you did a month ago and nothing more. I have seen too many electrical problems permanently solved by turning a device off and then on, or by rebooting. Here is what I would generally recommend: 1. See what the camera manual suggests. 2. Charge the batteries fully before using them. New ones are often not charged up. They could have been in a warehouse for months. 3. The electrical contacts on your camera, the ones that interface with the batteries, may be a little corroded. If you can access them easily, try cleaning them with the eraser on the end of a pencil. Same with the batteries themselves. 4. If exposed to prolonged high humidity, electrical problems may include not only the power supply, but other electrical switches, such as the reset button., which you cannot address on your own. 5. Call Sony.
Sep 13, 2005 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
95 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
