Question about HP Pavilion dv6000z Notebook
Toshiba Tecra 8000 doesn't see battery
I replaced the battery but my charge light will go out after a few seconds.
If I remove and reinsert the battery the charge light will come on but then just go out again.
The battery meter doesn't see the battery but if I unplug the AC power the laptop stays running so it is being power by the battery.
I cleaned the contacts on the battery and laptop but it didn't help.
  • Anonymous Jan 20, 2008
    I thought that might be it so I updated the BIOS. 9.30 was the newest I could find (I created a bootable CD) but that didn't help.
    I think it is the AC adapter, I hooked the laptop up to a bench supply and it seemed to be drawing more current that my adapter could provide. I have a new adapter on order so I have my fingers crossed. Thanks for the suggestion.
  • Olehenry1 Jan 20, 2008
    Same problem here -- ordered a new battery for the Tecra, which has charged up to a range of 38-42%, after which the light goes out along with Windows Power Management no longer recognizing the battery's presence.
    Did the Bios update or power supply change do anything?
    Jack
    Tempe, AZ
I tested this camera for a client. I didn’t have the light running for more than 15 minutes. The battery lasted approximately 6 hours before recharging. The LCD, however, had a few dead pixels - never saw this before. Tried returning for exchange and had to put up quite a fight. Anyone else seen this? http://www.batteryfast.co.uk
Posted on May 06, 2008
I have the same prob, but mine will not even run on it.
Posted on May 01, 2008
If you need a new battery, I suggest you could purchase one from http://www.batteryfast.com , which would shipping to you fast and the quality is satisfy satisfied.:)
Posted on Apr 04, 2008
Same prblem. udating latest bio did not work
Posted on Apr 03, 2008
I've precisly the same problem, but mu battery reaches 15% or so, but then the orange led goes of, and the laptop says there's no battery present. It is probably a problem with your BIOS, and in needs an update, but you'll need a Floppy drive to update the BIOS.
Grtz. Tom
Posted on Jan 19, 2008
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 18 Answers
SOURCE: Upgrading my tecra 8000 mother board
You don't have to change or replace your motherboard ..
just go to toshiba website........select your model by its serial No. and download the all available Drivers like Sound, Video, bios, management etc.....
install all these Drivers on your Laptop......... your motherboard will be up-to-date.
Posted on Mar 19, 2008
Anonymous
  • 240 Answers
SOURCE: Toshiba tecra 8000 EC/KBC update
go to system setting by pressing F2 when you see the toshiba or bios logo
disable the system setting auto update.
Posted on Mar 16, 2009
Anonymous
  • 24 Answers
SOURCE: my toshiba tecra 8000 doesn`t load windows it just
Hey Mark, The issue could be with the OS itself.., try doing a LKGC or a system restore from the safe mode.., if these do not work OSRI is the only resort.
Posted on Mar 03, 2010
The battery will charge for like 10 sec and then it will not charge. but when i dissconnect the charger, it remains on. so the battery is still good i have to dissconnect the battery then re-connect it to...
No matter what people say it is the batteries fault, after a few years a battery wont be able to hold a charge for long, it happens with all batteries and there is no fix, the only way to solve this is to replace the battery
Mar 22, 2011 | Kingston 64MB Module for Toshiba Tecra...
I have a toshiba tecra laptop that's running winxp and my cursor is frozen in middle of screen what's wrong?
Try to turn off the pc.
Remove the cables and battery on the pc
Press and hold the power button for 5 seconds
Reinsert the cables and the battery on the laptop
Turn on the pc
Check if the screen still freezes...
May 24, 2010 | Toshiba Tecra S1 Notebook
My toshiba tecra 8000 doesn`t load windows it just keeps going back to the screen with safe mode and the likes please can you help? Thanks Mark
Mar 03, 2010 | Toshiba Tecra 8000 Notebook
How do I switch from battery to power on my Toshiba Tecra 8000?
Mama,
You do not have to switch from the battery to power as long as the powwr adapter is plugged intp the wall socket and the laptop. When the battery goes low it starts charging while running the laptop and when not charging it runs the laptop alone. I hope that relieves you of your worries?
Nov 05, 2009 | Toshiba Tecra 8000 Notebook
How do i replace the bios battery on a toshiba tecra 8000 laptop?
Do you wish to replace the BIOS chip or the BIOS software (upgrade the BIOS)?
Oct 30, 2009 | Toshiba Tecra 8000 Notebook
My toshiba tecra 8000 will not power on
What you need to do to test this is the following:
1 - Check if its the battery : Remove the battery, plug in the laptop and try to power on the machine, if it powers on then your battery is dead and the system board is fine
2 - With the batter in and the laptop plugged in you should get a charging LED light up somewhere on the laptop, if you do not then the board is most likley gone.
If removing the battery and plugging the laptop in still fails to start the board of spin the fans and you hear no beeps, then the board is gone.
Hope this helps
May 26, 2009 | Toshiba Tecra 8000 Notebook
When using ac adapter to my Tecra 8000 the power light is yellow
Try a new battery and if the new battery wont charge then its either going to be a bad ac adaptor or a bad motherboad. If the new battery charges then you'll know that the old battery went bad.
Mar 29, 2009 | Toshiba Tecra 8000 Notebook
Toshiba Tecra 8000 keeps switching itself off.
I'd suggest removing the battery. Most laptops can run directly off the AC adapter. If it will boot up OK without the bad battery, you can either leave it like that, or buy a new battery.
If it won't boot, then you have problems other than the battery.
Feb 08, 2009 | Toshiba Tecra 8000 Notebook
Toshiba tecra 8000 boot problem
sounds like the batteries are incompatible..this is an important aspect
Oct 09, 2008 | Toshiba Computers & Internet
HP Pavilion dv6000z Notebook Logo
277 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
