Question about Nintendo NES Console
Need help for my nes
Hello i have just replaced the pin conector for my nes because the power light was turning on and off with no picture now it has a picture but it still flashing on and off. can anyone help me
You must clean your game connector as well. That should stop the blinking. Brand new connector with dirty games will still ...blink...blink.
If you can open your games to clean ...it's even better so you will see how dirty they are. 20+ years they sure need some TLC.
If you can't open the game...take a q-tips and a cleaner and rub the game connector. When I say rub ..put some pressure when you do it.Some use rubbing alcohool which is not my method of cleaning and other use windex. Still not my cleaning solution. Then dry the connector before inserting the game in the system. Good Luck.
Posted on Jan 18, 2008
The red light flashes on my NES and on the TV screen, it keeps on changing colors. Do you know whats wrong?
The NES is touchy like that, sadly-- your problem isn't uncommon. My NES, and the NES of nearly every friend I have who still owns one, plays this little trick on them from time to time. Here's what we do:
1. Turn off the NES console.
2. Blow into bottom of the game, near the chip that connects to the NES.
3. Wipe away any excess dust from the game itself.
4. Blow into the console of the NES.
5. Wipe away any excess dust.
6. Re-insert the game and try again.
If this doesn't work, try placing the game in more delicately, or with more force. It's just a matter of trial and error, and sometimes it will work faster than others. Hope this helped!
Mar 12, 2011 | Nintendo NES Console
I have A NES-001 and I hooked it up to my tv, but when i turn the system on the red light will turn on and off, and when the red light stays on there is no picture on the screen! What should I do?
Hi, probably need a new 72 pin connector, or you have bad capacitors or broken traces. we fix all those, check it out www.consolesolutions.net/nes
Aug 12, 2010 | Nintendo NES Console
NES Console: When ever I try to turn my NES on, the POWER light...
72 pin game cart adaptor needs replacing. they can be purchased for around £10 and make it work like nes
May 16, 2010 | Nintendo NES Console
Nes wonnt turn on, but when it does red light is flashing
Did you replace the 72 pin connector while it was apart? This is the number 1 reason for NES to fail to load or flash. A brief search of "72 pin connector" on eBay should net you a new connector for about $5 US.
If you have already done this, and the problem is really bad then recheck your work and make sure everything is connected tight.
Also consider that allot of nes games were not taken care of very well, so if the problem is specific to a couple cartridges, consider cleaning them as they are probably not connecting well.
Good luck.
Apr 02, 2010 | Nintendo Super NES Console
I hooked up my nes to my tv, the light turns on but I get no picture!
Hi sounds like the common fault found with these old retro consoles. Flashing light is mostly because the system does not make good contact with the game. which may be because of a worn out connector pins in side the console or dirty games recommend cleaning all your games with a game cartridge paste cleaner and replacing the connector pin with a new one, also check that your using a audio video cable not the old RF Cables that came out with these console as cable may be faulty. see http://www.gameoz.com.au/store/nintendo-entertainment-system/nes-accessories/ they carry these items and included photo instructions.
Apr 01, 2010 | Nintendo NES Console
Problem with panel front conector in Dell Dimension 2200 motherbo
The following information is to assist you in performing the right connections. You should take precautionary measures such as grounding yourself and completely disconnecting the PC form any source of power.
This picture shows the connector for the front panel power button, reset button, and power and hard disk lights: an 8x2 pin connector with 1 pin missing:
The table below lists the pinouts for the connector. The orientation of this table is the same as the picture above, this shows the top part of the connector. All the pins below pin 8 appear to be non-connected.
Each pair of pins labeled Power and Reset goes to the 2 wires for the corresponding button. The hard disk and power LED wires connect to the corresponding LEDs, you need to ensure the proper polarity of the + and - wires for each LED or it will not illuminate.
The above information is for your information only.
Mar 01, 2010 | Dell (2M502) Motherboard
NES won't turn on.
Well I think that it has died now so the power deck needs to be replaced I have replaced the power deck for NES before AND ITS EASY TO FIX TAKES ME LESS THAN 60 MINUTES TO REPLACE.
Jul 30, 2009 | Nintendo NES Console
Nes power light oes on and off
The nes does this to stop people from playing pirated games, but it can also be because the game cartridge or console is dirty. Try cleaning inside the game cartridge with a cotton bud dipped in a cleaning product of some kind. it mostly works for me!
Jul 09, 2009 | Nintendo NES Console
NINTENDO NES FRONT LOADER POWER LIGHT FLASHING RED WITHOUT AND WITH GAME IN LOOKS LIKE NEW 72 PIN CONNECTOR INSIDE BOUGHT RECENTLY HAVE NOT SEEN IT WORKING YET IF NEW CONECTOR WHAT OTHER FAUL COULD IT BE...
you should open your nes and disable the regional lockout chip.
a911e61.jpg while in there, check the connector and 1) if it is new, make sure it is properly connected to the board, or 2)if its old, use a very small eyeglasses flathead screwdriver to pull pins closer in (1mm-2mm) to a uniform level.
Aug 16, 2008 | Video Game Consoles & Games
Nintendo NES Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
