Question about Dell Precision Workstation 670 PC Desktop
Dell precision 670
I have trouble trying to boot my precision 670! i have everything going but i can't seem to get pass the screen that says boot press f-1 i used a regular SATA hard drive only! what kind of hard drive do i need in order to make it work? do i need the SCSI ULTRA U320 hard drive?
  • suikski Jan 19, 2008
    yeah..sorry but i tweeked with it..
    i got it start up and running now!!
    all i did was change some of my settings which was defaulting all of the bios and stuff..
    thanks anyways for the advice
  • oldpapa Feb 02, 2008
    i have trouble trying to boot my dell precision 670,
    i am using the SATA hard drive but when i boot my system there seem to be a blue screen error and when i try to do a new installation, my machine doesn't see the SATA hard drive to receive the insatallation files.
    Genius:
  • 1,226 Answers
Ok go to bios setup and then "load bios default" and press "F10" to save and exit. i will tell you in case this not work just tell me.
Posted on Jan 18, 2008
Upgrade hard drives on 670
There is a 2TB limit with MBR (Master Boot Record), but even a larger drive can be partitioned. So a single 4TB (biggest on the market) drive will look like several drives.
External drives that are bigger than 4TB are really several physical drives combined by an array.
RAID 1 requires optional SCSI drives, cables, and even software?
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/before.htm
Add on SATA 3 cards to PCI are not a good idea if you are looking for speed. They just bottlenecks the throughput.
Oct 22, 2012 | Dell Precision Workstation 670 PC Desktop
I have a Precision 670 that I put two 512MB DDR CL3 ECC REG ram sticks in and it will start up but when it reboots, it beeps two slow, two fast, two slow and stops. lights on front turn: AC are...
The issue seems to be that your PC can not handle the supported memory. After review of your system specs on dell's website, I see that you're computer would require DDR2 Memory. This seems to be what is causing the beeping. Please check to ensure you are using the correct memory stick. I hope this has helped
Jul 05, 2011 | Dell Precision Workstation 670 PC Desktop
Dell precision 670. Adding 8 gb total memory. Using Kingston KX1563-NAB; DDR2 2gb 2Rx4 PC3200 EEC, registered. Accepts 4 gb in dimms 1 and 2 (2 gb modules) and boots fine. Adding 4 more gb in dimms 3...
glenn_mullin
From what I can tell the Dell Precision Workstation 670 does support over 4GB of RAM. However when you have over 4GB of RAM installed in the system you have to have the Memory Cooling Shroud connected to keep the memory cool. Also this is only shipped out when the system is ordered with over 4GB of RAM originally. If you do not have this part you can order it from Dell buy calling 877-671-3355.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jan 27, 2011 | Dell Precision Workstation 670 PC Desktop
Computer wont find hard drive to reboot dell percision 670 not sure what settings to have on in bios
go bios press by f 2 or f 1 >change the boot sequence >first boot cd rom >2nd boot hdd.
ensure that *********** has recocknise the hdd if not ,should change the cable for hdd.Or can fit it tightly.you can see the hdd from driver configaration.
think it will you
Nov 24, 2010 | Dell Precision Workstation 670 PC Desktop
My Dell 670 had a blue screen when the c drive
try to remove or detach any newly hardware.and check the Ram
Feb 03, 2010 | Dell Precision Workstation 670 PC Desktop
With my Dell precision 670 the USB ports do not initailze
You can try updating the bios firmware but more than likely it's a hardware problem since you've experienced it with two separate operating systems.
If you've got one usb port that works really well you can get a powered usb hub and that will "solve" some of your problems.
Nov 20, 2009 | Dell Precision Workstation 670 PC Desktop
Dell Precision 670 throws "BIOS not installed!" message
i think this means that the harddrive needs to be refoarmated as the bios sees no logical drive in which the boot.ini file resides
Sep 01, 2008 | Dell Precision Workstation 670 PC Desktop
Dell 670 BIOS not installed
If you are installing a new hard drive, it is possible that you have not connected the cables correctly. Check if these are seated firmly in the corresponding pins.
Aug 31, 2008 | Dell Precision Workstation 670 PC Desktop
DELL PRECISION WORKSTATION 670
Have you tried a differnt video card?  Also disconnect everything including the hard drive to see if the system will POST.  If it does, them start connecting 1 item at a time.
Oct 25, 2007 | Dell Precision Workstation 670 PC Desktop
Dell Precision Workstation 670 PC Desktop Logo
632 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
