Question about Microsoft Xbox 360 Console
XBOX 360 no picture
I have had an XBOX 360 for 2 years. It was working great then I moved into a new home. When I try to connect it to the same tv, i get sound but no picyure. I looked up the trouble shoot with the microsoft site (push "y" button with right trigger as you turn on the console to set it back to default
) but that does not do the trick?! I tried to hook it up to another tv and I get sound but no piture there too. HELP!
  • 64 Answers
Try diffrent connectors composite instead of componant or vis versa. the wireless for the controls doesnt work on mine. I havent been able to find alot of replacement parts for the 360. I think you will end up having to send it in or by a used Core system for $200 from ebgames or ebay.. You could also try holding down the power button for 10 seconds. i heard that resets it as well.
Posted on Jan 18, 2008
Hello, I recently hooked my Xbox 360 up to my surround sound system using a digital optical cable ran from the xbox to the TV (optical cable from 360 to sound system) Sound and video works great for...
HDCP is the "handshake" protocol used by the Xbox to communicate via HDMI to your TV. The optical cable wouldn't have anything to do with this error. So far the only solution that's been found to this issue is to ensure that the HDMI cable is properly plugged in and power off/on both devices and see if the handshake is restored. If this doesn't work you may need a new HDMI cable.
Jun 27, 2011 | Microsoft Xbox 360 Console
I have just bought an xbox 360 conected it to my tv allcables connected picture great but no sound
Hi Douglas
I imagine you have bought the new slim Xbox 360? Did you use a HDMI cable to connect it to your TV or did you use the standard cable? If you used a standard AV cable ensure that you connected the red and white cables into the same AV input as the yellow video cable.
Mar 05, 2011 | Microsoft Xbox 360 Console
How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
May 25, 2010 | Philips HTS-3555 System
The tv will not turn on anymore-have a blinking red light where the power green is located -is a flat screen hdtv connected to an xbox 360, tivo, and cable box. model no. 42PF9431D/37 . The cable is...
internal breaker, hopefully that xbox is plugged into a 3prong ac outlet. unplug the tv from electricity for a half hour and that circuit breaker inside should auto reset.
Dec 15, 2009 | Philips 42PF9431D/37 TV
NO SOUND ON XBOX ELITE
I would suggest that you turn your CAPS LOCK off, and re-post so people can actually READ what you tried to post!
Apr 20, 2017 | Microsoft Xbox 360 Elite Console
I get sound but no picture on my xbox 360
Wiggle the end of the cord a little bit. same thing happened to me
Jun 27, 2009 | Microsoft Xbox 360 Console
HDMI problem with Xbox 360 to Dell TV
check that the wire coming from the xbox 360 elite to the tv is switched to hd, and the other end of the wire has the red and white for the sound pluged into the tv and that the red green and blue wires are pluged into the tv. also check to see if the hdmi cable to conected to the tv and xbox 360 elite.
Jan 06, 2009 | Microsoft Xbox 360 Elite Console
Xbox 360 hdmi connection to dell W3201C no display
The W3201c IS 720P. You have to adjust the display output on the xbox 360 to 480p then adjust settings up from there...
Jan 03, 2009 | Microsoft Xbox 360 Elite Console
Brand new xboxdoes not play in color on TV set at school.
Does his TV have other RCA in ports? If so, he should try connecting the 360 to the other one as it could be defective. If he connects a DVD player to the same ports, does he get the same problem? What sort of cables is he using? If he's using a component cable (RGB or YPbPr), he should try using a normal RCA cable. Also, when connecting the 360 to the other TV sets, did you use the same cables he used when he connected it to his TV set? If not, you should try switching the cable.
Jan 07, 2008 | Microsoft Xbox 360 Console
Xbox 360 sound problem
HDMI carrys no sound you still need to have the audio cables from the component plugged into the tv. If this doesnt do the trick you should call MS or check your TV's settings maybe there is a special function when using that resolution. Hope this helps.
Jan 02, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
