Back to:
Tags:
Refrigerators
Generic problem for all Refrigerators
Unit not running (cooling)
posted by Harry821 on Jan 18, 2008
My 75BWC is 10 years old. The unit is getting power because the inside light comes on. However, the refrigerator is not running. No sound, no heat, nothing.
I've not a great job of keeping it clean behind the bottom grate. Did I kill it? Would it be the motor or condenser? How could I tell?
We have a kenmore wine refrigerator that is running but not cooling below 65 degrees. This has been like this for the past 6 weeks. Am unsure what may be the problem. Any suggestions?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 18, 2008
Not Rated (0)
siju
Rank:Wiz Wiz
Rating: 80%, 45 votes
  1. check the motor relay and circuit, fuse, supply line break, motor coil burnout
  2. i think refridgerator not cooling below less than 65 degree, check your question
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Unit not running (cooling):
I don't want to Accept this solution
Can you Help with these Refrigerators problems?
Refrigerators
the fridge is constantly leaking water from inside. Just...
Refrigerators
Freezer TF775a, Ser No 6450085, Prod No 9224814. Upon...
Smeg FC40RX Bottom Freezer Refrigerator
I have a smeg FC40RX frigerator and on the frame where the...
Refrigerators
i need to replace an internal glass shelf
Refrigerators
no power from top circuit board
Loading problems.
Repair Service
Find Refrigerator Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
