Question about Sony Cyber-Shot DSC-F828 Digital Camera
Lens is loose from body
The lens seems to be separating from the body. Is it easy to take apart and tighten?
  • Anonymous Mar 15, 2008
    I have the same problen and that solution did nothing to solve the problem.
  • JCShroyer May 08, 2009
    Just an FYI, I had a early production model of the DSC-F828 and the screws that need tightening were actually installed backwards. The screwheads are not visible on my camera and it took some extra work to get the lens tightened.
One note on this fix. There are four screws that need to be tightened on the lens. With the cover off and the lens pointing straight forward, there are three small screws visible. After tightening them, rotate the lens upward to expose the fourth screww. After that one is tightened, you can then replace the cover and six cover screws.
Posted on Jun 05, 2008
How did you order the replacements screws?
Posted on Feb 10, 2008
I had the same problem very recently. If you are careful and have a screw driver the size of the phillips screws on the camera body you can fix the looseness. There are 6 screws that you need to remove to access three screws on the left side of the camera body that need to be tightened (your left as if viewing through the camera view finder). On the left side of the lens by the function button are 4 screws. A 5th is at the underside by the tripod hole, the 6th is at the rear of the lens just aft of the name "Cybershot". Unscrew all 6 short screws. Carefully pry off the left side cover that has the functions buttons (focus, nightshot, ect). You need to support the lens and cover as they are connected with a thin copper strip. Once off you tighten the 3 screws on the left side of the camera body. Reinstall the removed side and off you go. Lock tight on the screws would have been good as even my camera body screws get loose. I had to order replacements after looseing 3 of them. Cheers.
Posted on Jan 23, 2008
Steam is not coming out of my Euro steam. Why?
The iron needs to be taken apart and cleaned,the thermostat switch contacts need resurfacing for better contact and the sole plate needs unblocking and a good clean out,at this time any deteriorated seals can be replaced and the spray pump can be checked for blockages,any loose sole plate screws can be tightened and that should do it,good as new all that's left is to reassemble''
Oct 14, 2014 | Irons
Moen banbury faucet repair
I had a look at the installation guide and exploded diagram, It seems that the whole assembly will be tightened when the mounting nut is put on.
The links to the installation guide and exploded diagram are:
Jan 18, 2014 | Plumbing
I need your help please, I fell with my Nikon camera, the body still works, but the 55-200mm lens does not work again, for seeing through the viewfinder the image is dark. The lens does not hit with...
Okay if you have luck all that's happened is you have jarred the lens contact between the camera body and lens. Make sure the camera is turned off then remove the lens and clean the gold contacts on both the lens and camera body. Remove the battery, install the lens and replace the battery, turn the camera on. If it still doesn't work shut the camera off and try another lens and see if it work properly this will tell you if it's the camera at fault or the lens. Switch lenses between known working cameras. I'm sure you will find the lens has come loose. I only once had a lens come apart from a jar (not impact) and it actual popped apart in pieces.
Dec 10, 2010 | Nikon D60 Digital Camera with 18-55mm +...
Cant put my mavic back together properly
It sounds like you lost the washer that sits between the bearing in the nose and the freehub bearing. If you lose that washer, when you re-tighten the axle, the two bearings will bind and prevent the freewheel from spinning easily.
Take your freehub off again and see if that washer is there. If it isn't, you'll have to get a new one and replace it. It's easy to lose that thing if you don't know it's there when you take the wheel apart, because it'll just fall out.
When I reassemble those wheels. I thread the drive-side axle through the freehub body, then place the washer over the axle on the inside of the bearing, then thread the axle through the nose.
Also note that if your freehub seemed loose, it probably needs to be replaced. The FTS-L freehub body used on the Ksyrium wheels uses a nylon bushing as the friction interface to the nose, and this bushing wears down over time even with good lubrication.
Feb 10, 2010 | Mavic Ksyrium Elite Wheelset
Lens dropped and now it is tilted inside and won't focus
I had a camera with the very same problem and decided to take it apart. After all what was there to loose.
It sounds like you have more to do than I did. after undoing many screws I was able to take out the zoom lens housing. I was able to disconnect the motor from the main body. I also removed the CCD board.
I then removed the rear cover which housed most of the mechanics for the focusing and shutter operation. This was quite tricky as it is a very tight fit, and had to be wiggled out very carefully.
When I looked inside the main body I could see several metal pins which were wedged between the outer shell and the lens holder... a bit of force was required to seperate these. Unfortunatley the holders for the metal pins were broken, and there seemed to be nothing I could do. But I decided to try and super glue them in place. A bit of trial and error and i managed to get them all back into place. This bit is really tricky as there are several tracks for these little rods to fit into and not getting them right will make the lens not function.
Your model may be different but I suspect you will find that the metal rods which move the lens back and forth are loose and that the holders for same are broken. If you have a lot of time and patience you can get it working as I did mine.
Feel free to contact me if you need more info. (I knew I should have take some photos whilst I was doing it.
Jan 15, 2009 | Cameras
Canon digital rebel xti - lens misaligned after it was dropped
I just stripped the body of my rebel xt apart and put it back together. be forewarned, there are six different size and thread pitch screws in the body, so take notes and keep them separate.
Jump in, you'll probably learn something
Jan 11, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
EF 24-70 lens droop...
The zoom creep is an easy fix for Canon. I really do not recommend trying to tighten it yourself, since that would void your warranty.
It is usually free to tighten the zoom ring.
Dec 13, 2008 | Canon EF 24-70mm f/2.8L USM Lens
Lens has become Loose
If it is at all like my C8080, there are 4 screws that hold the lens guard in place, accesible only when the case is opened. This is the fixed tube that the lens extends out of. The knurled coller is a screw on piece that allows a lens tube to be screwed on, that can be tightened by hand. If the lens itself seems kinda wobbly, that is normal and is just showing a little sign of age. It wont affect the picture. The lens rides on helical rails on a rotating inner barrel and these rails and bushings get a little worn over time.
Oct 27, 2008 | Fuji FinePix S5000 Digital Camera
Mechanical problem
Undo the six M2 screws that hold the left housing assemble (control panel for flash & focus etc) and remove You will see that there are 3 srews that hold the hinge assembly together all 3 wiil be loose and require tightening (you will neeed to tilt the lens up to see and tighten the third screw.
Reassemble the housing making sure not to trap thw flexible cable
Easy 5 min job
Jul 29, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
Lens does not extend
If you drop one of the Coolpix cameras, the case can get jammed up against the lens. The lens may not extend at all, and you are probably getting SYSTEM ERROR messages. The motor that extends the lens isn't powerful. By loosening the screws that hold the case together, you may be able to move the case slightly and get everything back into alignment. This task is for the mechanically inclined and who can be gentle and patient. Brute strength is NOT called for here. Also, if your camera is under warranty, do not do this!
Removing the case screws will require a jewelers phillips head screwdriver and a well-lit workspace that will prevent losing the screws (they are tiny). Not all the screws are exactly the same. You have to keep track of where they came from so that they go back into the same hole. Get a clean sheet of paper and draw a map of the camera body showing where the screws go. There are 11 screws all together two of which are under the battery cover.
Shut off the camera and remove the battery. As you remove the screws, place them on the corresponding spot on the map. When all the screws are removed, the case may not want to come apart. GENTLY move the two halves of the case apart at the bottom of the camera (For some reason, the camera wants to come apart at the base before the top). It probably isn't necessary to take the body apart. If the body does come apart, note that the OFF/ON dial is connected to the circuit board by a thin ribbon cable, so the halves cannot be separated completely in any case. DO not pull on this cable.
What you are trying to do is loosen the two halves of the case and give them a chance to get back into the original position. Note that the tripod mount is a separate piece and will shift slightly if you separate the case halves at the bottom.
If the case halves are loose and they have moved, you've may have fixed the problem. Replace the screws. You may need a pair of needle nosed pliers to get the screws back into the holes. Put the battery in and turn on the camera. If you moved the body correctly, then the lens should pop out. Don't be afraid to try a couple of times.
I may have been lucky in that this worked for me, but if your camera isn't working at all (mine wasn't), this may be worth a try. Just be extremely careful of those screws.
Mar 29, 2008 | Nikon Coolpix 4300 Digital Camera
Sony Cyber-Shot DSC-F828 Digital Camera Logo
533 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
