Question about Flat Panel Televisions
High pitch noise RCA 52 inch HDTV
Turns on great pic. but has a high pitched noise to it. TV 2 and a half years old. Is it worth fixing.
4 Suggested Answers
  • 52 Answers
SOURCE: High pitch noise
Hello there, You have to specify where the noise is coming from. Is it coming from the speaker or from the back of the unit. SMPS power supply powering your unit create this kind of noise when some capacitor gone out of their value.
Good Luck.
Posted on Jan 29, 2008
  • 207 Answers
SOURCE: High Pitch Noise on 42" PLasma Gateway TV
how old is your plasma TV? try check the switch / volume of the sound settings.. Sometimes, when you always increase the volume, it will tend to alter the limit of sound and causing the sound to provide sound undesiredness. I suggest to check it with a liscensed technician.
Posted on Feb 05, 2008
  • 476 Answers
SOURCE: Hi: My Magnavox flat screen turns
Hello, what's the model or size of screen for the magnavox, the high pitch noise could be an audio power amp starting to get intermittent, and the power on/off could be due to the over current sensor circuit detecting the audio problem. Depending on the model number you would have a seperate power, audio and signal board in the TV. If he TV is 27" or smaller all these circuits are part of a mother board.
Posted on Jul 28, 2010
  • 5138 Answers
SOURCE: I have a 52 inch
What is the model number that is printed on back of TV? If it is the one Im thinking it is problem will be coil causing squealing noise. I can tell you more once I know which Model your TV is. Thank You
Posted on Jun 26, 2011
0 characters
1 Points
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ... > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2 > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Flat Panel Televisions
`How do I fix my LG tv? It's making a high pitched noise and there is a black screen, is it fixable?
Get it to a tv dealer but my guess is its died. It may not be economical to repair but you may be pleasantly surprised and its a small job. LG are usually pretty good so I'm surprised its gone at this age.
Mar 30, 2015 | LG Flat Panel Televisions
My RCA 50'LCD HDTV screen crack,I'm looking for a new sreen.
It is not worth getting a new one, ewith the 4K UHD TV you are able to get 60 inch for less that the price of the screen with warantee
Sep 28, 2014 | RCA Flat Panel Televisions
Panasonic TX32POL1 high pitched noise
The high pitch sound is comming from a power supply transformer that will resonate (or vibrate) at the operating frequency (12-14KHz).
This is usually affordable to repair -at least worth the estimate.
Oct 14, 2009 | Flat Panel Televisions
Buzzing sound after only 2-1/2 years of service
I suspect you have a bad set of capacitors in the control module. This problem usually starts out as a high pitched noise but can lead to the TV not turning on. Please see the link below, posted by StivO. It gives step by step instructions on how to replace the capacitors. This is a very inexpensive fix.
Apr 13, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
High pitched noise
I am about to post a in depth guide about how to fix this problem. It's because a capacitor inside the TV has blown which causes the buzzing high pitched noise. It's really easy to fix however and only costs about £1 / $2 to sort out.
You can read a similar guide here but I will shortly be uploading a guide on the buzzing problem!
Dec 22, 2008 | Polaroid FLM-3732 Television
High pitched noise on Polaroid HDTV
It appears like your power supply is not filtering the voltage properly and that is why you are hearing that high pitched noise. If your LCD is less then a year old, you can call Polaroid to have it repair under warranty.
If more then a year old, check the info from this link to replace the capacitors.
Let me know if you need further assistance.
Oct 07, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
High pitched noise
The power supply is starting to fail on your LCD. The noise you hear is because the circuit is trying to provide the proper power to the rest of the circuitry and is forcing itself.
The noise does increase if you tune to an HD channel because of more demand for power for a brighter picture.
Sep 18, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
High pitch noise
Good Luck.
Jan 26, 2008 | Samsung LW26A33W 26 in. HD-Ready LCD...
Flat Panel Televisions Logo
195 people viewed this question
Top Flat Panel Televisions Experts
Jaime Hernandez
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
