Back to:
Tags:
LG WM-2277HW Front Load Washer
Smell on towels (by 2 users)
posted by mitch9097 on Jan 18, 2008
Why do my towels never smell fresh no matter what i use tide he also fab softer downy and bleach and they still have a smell to them
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by bremily, posted on Mar 25, 2008
i have a problem with towels too. i have checked around the door rubber seal and cleaned it. it did not look bad. still have the smell. they smell good when i take them out of the washer and when i remove them from the dryer. when i dry off with one after a shower is when it smells NOT clean!
i always leave the door open after washing. the washer itself does not smell bad. HELP!
Best Solution
posted on Jan 24, 2008
Helpful (85)
chem-prof
Rank:Guide Guide
Rating: 96%, 30 votes
I also have had issues with a bad smelling LG Tromm 2277 washer when we leave the door closed after using it. One note on the LG site mentions that soap/scum buildup on the washer drum can encourage mold growth. They suggested running an empty wash load and then pause it after the water fills and add a hot tub cleaning product (Whirl Out - I got it at Lowe's) and restart the load. This stuff should help remove the soap scum and limit the smelly mold growth. My washer does not smell as bad after using it. I also have run an empty cycle with only bleach using the very hot sanitary load setting.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on smell on towels:
I don't want to Accept this solution
Solution #2
posted on Jan 18, 2008
Helpful (85)
mark1963
Rank:Guru Guru
Rating: 88%, 81 votes
It's good that you are using HE detergent but you're probably using way too much. To test this run the washer empty (no soap) and if you see bubbles inside that's left over soap that's still in the unit. If so, keep running it empty until the bubbles are gone then start using only about 1 tablespoon of soap per load. The washer uses about 1/10 of the water so you need to use 1/10 of the soap. Use the same amount of softner. The excess soap and softner build up in the unit and cause the smell.
Rating Locked! (?) mitch9097 has rated this solution as Helpful
Thank You!
Can you Help with these Washing Machines problems?
Washing Machines
I need a manual for the Quietline washer/dryer. My email...
Washing Machines
Washer IW810 AU CODE 43.
So while trying to remove the filter from the rear of the...
sir i hav purchased lg mobile ie c2500 ..while purchasing...
Wolfster- Thanks for providing the perfect solution. I...
Loading problems.
Repair Service
Find Washing Machine Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
