Question about Zebra 105Se Thermal Printer
Increasing fonts on Zebra 105SE
Anyone know what are the control panel key combinations, to increase the fonts?
  • 38 Answers
Sorry, not possible.
Fonts are controlled only by your software.
Posted on Mar 05, 2008
How to change font size
Would be helpful to know a little specifics about where you would want to change font size but generally to increase or reduce font size do the following
1. Select the text you want to increase or reduce
2. Use the key combination SHIFT + CTRL + (> OR <) to increase or reduce the font size on a PC. If youre using a MAC
use step 3
3. Use the key combination SHIFT + CMD + (> OR <) to increase or reduce font size on a Mac.
Hope this helps
Jan 17, 2018 | Computers & Internet
Darker print
Enter the Setup Menu from control panel and modify the Darkness value. You have to increase the value and then Save the changes and exit the menu. On control panel Buttons you find the role of each button in the control panel. You can use the User Manual. There is an User Manual available for download from Zebra website. You will find there precious information. The manual is very explicit and you will learn how to maintain your printer and how to troubleshoot some common errors. Eventually clean your printer, assure to put the supplies on the right path, close the printhead and press Pause to enter in Ready state.
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/105sl-ug-en.pdf
Dec 05, 2013 | Zebra 105Se Thermal Printer
Darker printe for 105se printer
Enter the Setup Menu from control panel and modify the Darkness value. You have to increase the value and then Save the changes and exit the menu. On control panel Buttons you find the role of each button in the control panel. You can use the User Manual. There is an User Manual available for download from Zebra website. You will find there precious information. The manual is very explicit and you will learn how to maintain your printer and how to troubleshoot some common errors. Eventually clean your printer, assure to put the supplies on the right path, close the printhead and press Pause to enter in Ready state. You can try to tighten the 2 pressure screws from the top of the printhead assambly. This will bring the printhead surface closer to the platten roller. The screws can also be moved left and right and correct the wear of the platten roller.
Here is the link to the English version of User manual:
My Zebra 105SE is printing fine on the left
I think the 105 has an adjustment on the printhead. There are left and right hand adjusters just above the printhead. It sounds as if the right hand one does not have enough pressure on it, try increasing the RH one and see the effect on the print.
Jan 06, 2010 | Zebra 105Se Thermal Printer
Label peeling
Sometimes the peel bar gets worn out and isn't very sharp anymore (replace). This will affect the peeling. Also try increasing the printhead pressure with the printhead toggle.
Jun 03, 2009 | Zebra 105Se Thermal Printer
Driver for Zebra 105se
Hi spydo...
Zebra 105se drivers (xp/vista/win7/win8) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Mar 03, 2009 | Zebra 105Se Thermal Printer
Zebra 105SE configuration settings
Please scroll the printer parameter untill you fine LEFT POSITION parameter and adjust as you needed.
Nov 03, 2008 | Zebra 105Se Thermal Printer
Zebra 105se printhead issue
The controller thinks the printhead is still open. If it is open, close it.
If it's closed, it's likely that the sensor flag on the rear of the shaft has come loose and is no longer interrupting the photosensor. Remove the rear panel and inspect the flag while you move the printhead handle. The flag is supposed to be in the opening of the sensor when the printhead is closed and latched.
Steve Weinrich
LazerTek, LLC
Mar 23, 2008 | Zebra 105Se Thermal Printer
Zebra 105 SE Printing Blank Labels
You need the correct driver for the 105Se. The 300 dpi SL driver is not compatible.
Unfortunately, Zebra does not make it's older drivers available online. You will need to locacte someone with the correct driver for whichever version of Windows you are using.
Steve
Feb 13, 2008 | Zebra 105Se Thermal Printer
Need to increase my font on Zebra 105SE
All fonts are controlled by software. You cannot change them throught the front panel.
Steve W
LazerTek, LLC
Jan 18, 2008 | Zebra 105Se Thermal Printer
Zebra 105Se Thermal Printer Logo
96 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
